<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Wake MM with pir Module from the shell...]]></title><description><![CDATA[<p dir="auto">Hi Forum,<br />
i have the Magic Mirror running with the Module “MMM-PIR-Sensor”. Until here no problem.<br />
In the Background there is running the alexa-avs-sample app. Until here even no problem ;)<br />
But no to the Problem:<br />
Alexa heres me via a usb Mikro, so this works at every time. But: Alexa speaks via hdmi and the monitor. So when the pir module puts the monitor off i can’t here anything of course.</p>
<p dir="auto">The alexa wakeword engine runs via a shell console. I can see actions there, every time the wakeword is recognized. I’ve send a request to the alxa Furum, how to send any notification in this moment. I’m shure there is a way ;)</p>
<p dir="auto">And now the real Problem: What command i have to send at this moment? The command has to put the monitor on and to restart the timer in the pir module maybe via a command to the core module? Or can i simulate an Hardware action from the pir Sensor?  Only to put the Moniror on would not be enough. The Pir-Module has to restart the timer, so that the Moniros doesn’t run until anyone stands in front of the mirror.</p>
<p dir="auto">Many thanks for every Tip :)</p>
<p dir="auto">best Regards.</p>
]]></description><link>https://forum.magicmirror.builders/topic/6016/wake-mm-with-pir-module-from-the-shell</link><generator>RSS for Node</generator><lastBuildDate>Tue, 11 Aug 2026 14:20:13 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/6016.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 30 Dec 2017 00:30:17 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Wake MM with pir Module from the shell... on Wed, 17 Jan 2018 00:35:18 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/user/kiki99" aria-label="Profile: kiki99">@<bdi>kiki99</bdi></a>:</p>
<p dir="auto">You can send the <code>SCREEN_WAKEUP</code> notification to <code>MMM-PIR-Sensor</code> via <code>MMM-Remote-Control</code> (some details how to structure the GET request here): <a href="https://forum.magicmirror.builders/topic/6106/use-mmm-buttons-to-hide-show-modules">https://forum.magicmirror.builders/topic/6106/use-mmm-buttons-to-hide-show-modules</a>).</p>
<p dir="auto">If you can get the Alexa wakeword to send the notification, it should wake the monitor as though you triggered the PIR.</p>
]]></description><link>https://forum.magicmirror.builders/post/34109</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/34109</guid><dc:creator><![CDATA[ninjabreadman]]></dc:creator><pubDate>Wed, 17 Jan 2018 00:35:18 GMT</pubDate></item><item><title><![CDATA[Reply to Wake MM with pir Module from the shell... on Wed, 17 Jan 2018 00:05:20 GMT]]></title><description><![CDATA[<p dir="auto">Hello<br />
I think one solution is to hide all modules. Don’t turn off HDMI monitor, your audio on.<br />
<a href="https://github.com/phrazelle/mm-pir-hide-all" target="_blank" rel="noopener noreferrer nofollow ugc">link</a><br />
Anyway I don’t know how to turn on PIR from remote shell.</p>
]]></description><link>https://forum.magicmirror.builders/post/34108</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/34108</guid><dc:creator><![CDATA[saljoke]]></dc:creator><pubDate>Wed, 17 Jan 2018 00:05:20 GMT</pubDate></item></channel></rss>
