<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Blank mirror?]]></title><description><![CDATA[<p dir="auto">Hi! A new setup on a ubuntu server, trying to use server only.</p>
<p dir="auto">This is what i get:</p>
<p dir="auto">node serveronly:</p>
<pre><code>lange@tower:~/MagicMirror$ node serveronly/
Starting MagicMirror: v2.1.3
Loading config ...
Loading module helpers ...
All module helpers loaded.
Server started ...
Starting module: newsfeed
Sockets connected &amp; modules started ...
Ready to go! Please point your browser to: http://192.168.1.123:8080
<p dir="auto">This is what i get when using sh <a href="http://run-start.sh" target="_blank" rel="noopener noreferrer nofollow ugc">run-start.sh</a></p>
<pre><code>lange@tower:~/MagicMirror$ sh run-start.sh
/usr/local/lib/node_modules/electron/dist/electron: error while loading shared libraries: libgtk-x11-2.0.so.0: cannot open shared object file: No such file or directory
<p dir="auto">Help please :)</p>
]]></description><link>https://forum.magicmirror.builders/topic/6022/blank-mirror</link><generator>RSS for Node</generator><lastBuildDate>Sat, 13 Jun 2026 00:08:15 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/6022.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 30 Dec 2017 12:36:24 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Blank mirror? on Mon, 08 Jan 2018 16:12:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/esinem" aria-label="Profile: Esinem">@<bdi>Esinem</bdi></a> said in <a href="/post/33154">Blank mirror?</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lange" aria-label="Profile: Lange">@<bdi>Lange</bdi></a> said in <a href="/post/33042">Blank mirror?</a>:</p>
<pre><code>npm install --unsafe-perm fixed the problem for me.
<p dir="auto">Hurrah! You saved my sanity! Finally, after several days of repeated reinstalls and fiddling, it lives!</p>
<p dir="auto">Ive seen many with the problem, but no one has posted the solution. There for, always visit your old posts :D</p>
]]></description><link>https://forum.magicmirror.builders/post/33598</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/33598</guid><dc:creator><![CDATA[Lange]]></dc:creator><pubDate>Mon, 08 Jan 2018 16:12:49 GMT</pubDate></item><item><title><![CDATA[Reply to Blank mirror? on Tue, 02 Jan 2018 07:06:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lange" aria-label="Profile: Lange">@<bdi>Lange</bdi></a> said in <a href="/post/33042">Blank mirror?</a>:</p>
<p dir="auto">npm install --unsafe-perm fixed the problem for me.</p>
]]></description><link>https://forum.magicmirror.builders/post/33154</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/33154</guid><dc:creator><![CDATA[Esinem]]></dc:creator><pubDate>Tue, 02 Jan 2018 07:06:33 GMT</pubDate></item><item><title><![CDATA[Reply to Blank mirror? on Sat, 30 Dec 2017 16:04:39 GMT]]></title><description><![CDATA[<p dir="auto">npm install --unsafe-perm fixed the problem for me.</p>
]]></description><link>https://forum.magicmirror.builders/post/33042</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/33042</guid><dc:creator><![CDATA[Lange]]></dc:creator><pubDate>Sat, 30 Dec 2017 16:04:39 GMT</pubDate></item><item><title><![CDATA[Reply to Blank mirror? on Sat, 30 Dec 2017 14:47:29 GMT]]></title><description><![CDATA[<p dir="auto">A Black blank page. Like moduls are not loading</p>
]]></description><link>https://forum.magicmirror.builders/post/33039</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/33039</guid><dc:creator><![CDATA[Lange]]></dc:creator><pubDate>Sat, 30 Dec 2017 14:47:29 GMT</pubDate></item><item><title><![CDATA[Reply to Blank mirror? on Sat, 30 Dec 2017 13:03:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lange" aria-label="Profile: Lange">@<bdi>Lange</bdi></a> said in <a href="/post/33034">Blank mirror?</a>:</p>
<p dir="auto">Ready to go! Please point your browser to: <a href="http://192.168.1.123:8080" target="_blank" rel="noopener noreferrer nofollow ugc">http://192.168.1.123:8080</a></p>
<p dir="auto">what happened when you tried to access that in your browser?</p>
]]></description><link>https://forum.magicmirror.builders/post/33036</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/33036</guid><dc:creator><![CDATA[strawberry 3.141]]></dc:creator><pubDate>Sat, 30 Dec 2017 13:03:11 GMT</pubDate></item></channel></rss>
