<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Standard module: Clock]]></title><description><![CDATA[<p dir="auto">You could be introduced to the config options to disable showing the date (on top the clock).<br />
When we use the calendar_monthly we have duplicated the date  (and a waste of valuable space :))</p>
<p dir="auto"><img src="/uploads/files/1473503530718-mm-calendar.jpg" alt="0_1473503530927_mm-calendar.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/topic/605/standard-module-clock</link><generator>RSS for Node</generator><lastBuildDate>Sat, 15 Aug 2026 16:08:28 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/605.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 10 Sep 2016 10:46:22 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Standard module: Clock on Tue, 20 Sep 2016 23:02:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/plati" aria-label="Profile: Plati">@<bdi>Plati</bdi></a> The Config has been push to GitHub. You can look at the module page <a href="https://github.com/MichMich/MagicMirror/tree/master/modules/default/clock" target="_blank" rel="noopener noreferrer nofollow ugc">here</a> and It has a new option for showDate. But remember update the magic mirror first by doing <code>Git Pull </code></p>
]]></description><link>https://forum.magicmirror.builders/post/5101</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/5101</guid><dc:creator><![CDATA[andrewchumchal]]></dc:creator><pubDate>Tue, 20 Sep 2016 23:02:33 GMT</pubDate></item><item><title><![CDATA[Reply to Standard module: Clock on Sun, 11 Sep 2016 19:22:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/plati" aria-label="Profile: PLATI">@<bdi>PLATI</bdi></a> I have create a pull request to change the config for the default clock module. Right now the code is sitting the devolve branch of the <a href="https://github.com/MichMich/MagicMirror/tree/develop" target="_blank" rel="noopener noreferrer nofollow ugc">Magic Mirror</a> GitHub once it has been testing and confirm it works. Most likely they will merge it to the master branch.</p>
]]></description><link>https://forum.magicmirror.builders/post/4651</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/4651</guid><dc:creator><![CDATA[andrewchumchal]]></dc:creator><pubDate>Sun, 11 Sep 2016 19:22:41 GMT</pubDate></item></channel></rss>
