<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Alexa KittAi]]></title><description><![CDATA[<p dir="auto">When I try to start the wake word I get this. Is there a way to reload or check the install of kitt_ai. Alexa works when using the onscreen button otherwise.</p>
<p dir="auto">pi@raspberrypi:~ $ cd ~/Desktop/alexa-avs-sample-app/samples<br />
pi@raspberrypi:~/Desktop/alexa-avs-sample-app/samples $ cd wakeWordAgent/src &amp;&amp; ./wakeWordAgent -e kitt_ai</p>
<p dir="auto">INFO:main: Starting Wake Word Agent<br />
INFO:WakeWordAgent: State set to IDLE(2)<br />
ALSA lib pcm_dmix.c:1052:(snd_pcm_dmix_open) unable to open slave<br />
ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.rear<br />
ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.center_lfe<br />
ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.side<br />
ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.hdmi<br />
ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.modem<br />
ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.phoneline<br />
ALSA lib confmisc.c:1281:(snd_func_refer) Unable to find definition ‘defaults.bluealsa.device’<br />
ALSA lib conf.c:4528:(_snd_config_evaluate) function snd_func_refer returned error: No such file or directory<br />
ALSA lib conf.c:4996:(snd_config_expand) Args evaluate error: No such file or directory<br />
ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM bluealsa<br />
Expression ‘paInvalidSampleRate’ failed in ‘src/hostapi/alsa/pa_linux_alsa.c’, line: 2043<br />
Expression ‘PaAlsaStreamComponent_InitialConfigure( &amp;self-&gt;capture, inParams, self-&gt;primeBuffers, hwParamsCapture, &amp;realSr )’ failed in ‘src/hostapi/alsa/pa_linux_alsa.c’, line: 2714<br />
Expression ‘PaAlsaStream_Configure( stream, inputParameters, outputParameters, sampleRate, framesPerBuffer, &amp;inputLatency, &amp;outputLatency, &amp;hostBufferSizeMode )’ failed in ‘src/hostapi/alsa/pa_linux_alsa.c’, line: 2838<br />
ERROR:Failed to open PortAudio stream.Invalid sample rate<br />
ERROR:KittAiSnowboyWakeWordEngine: Initialization error:Failed to open PortAudio stream.<br />
ERROR:WakeWordAgent: exception in constructor: Failed to open PortAudio stream.<br />
ERROR:main: Exception happened: Failed to open PortAudio stream.<br />
INFO:Shutting down Wake Word Agent<br />
pi@raspberrypi:~/Desktop/alexa-avs-sample-app/samples/wakeWordAgent/src $</p>
]]></description><link>https://forum.magicmirror.builders/topic/6082/alexa-kittai</link><generator>RSS for Node</generator><lastBuildDate>Thu, 14 May 2026 19:07:18 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/6082.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 06 Jan 2018 01:29:55 GMT</pubDate><ttl>60</ttl></channel></rss>
