<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Change default interface colors]]></title><description><![CDATA[<p dir="auto">Just wondering, where would I go to change rgb values for the colors on the screen or if the aren’t rgb values then are they hexidecimal?</p>
]]></description><link>https://forum.magicmirror.builders/topic/61/change-default-interface-colors</link><generator>RSS for Node</generator><lastBuildDate>Thu, 08 Oct 2026 09:31:34 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/61.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 09 May 2016 15:03:37 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Change default interface colors on Tue, 10 May 2016 08:06:48 GMT]]></title><description><![CDATA[<p dir="auto">you can use the <code>/css/custom.css</code> to overwrite all styles. This file is embedded after all other css files, so you should be able to overwrite what you want. Is just a matter of creative CSS usage.</p>
]]></description><link>https://forum.magicmirror.builders/post/381</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/381</guid><dc:creator><![CDATA[MichMich]]></dc:creator><pubDate>Tue, 10 May 2016 08:06:48 GMT</pubDate></item><item><title><![CDATA[Reply to Change default interface colors on Tue, 18 Aug 2020 20:59:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dyard" aria-label="Profile: dyard">@<bdi>dyard</bdi></a> please, just edit the css/custom.css, don’t change the  module code unless u are fixing a bug or adding function (and then don’t tell anyone about it, release a new updated module)</p>
<p dir="auto"><a href="https://forum.magicmirror.builders/topic/6808/css-101-getting-started-with-css-and-understanding-how-css-works?_=1597692865011">https://forum.magicmirror.builders/topic/6808/css-101-getting-started-with-css-and-understanding-how-css-works?_=1597692865011</a></p>
]]></description><link>https://forum.magicmirror.builders/post/80308</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/80308</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 18 Aug 2020 20:59:05 GMT</pubDate></item><item><title><![CDATA[Reply to Change default interface colors on Tue, 18 Aug 2020 20:54:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kirash4" aria-label="Profile: KirAsh4">@<bdi>KirAsh4</bdi></a> Hi I am setting up my first magic mirror, is this old post still valid? This look is great, I tried to follow and add a custom mystyles.css and added to the same calendar module. But I didn’t see it make a change. Thanks for your help</p>
]]></description><link>https://forum.magicmirror.builders/post/80306</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/80306</guid><dc:creator><![CDATA[dyard]]></dc:creator><pubDate>Tue, 18 Aug 2020 20:54:41 GMT</pubDate></item><item><title><![CDATA[Reply to Change default interface colors on Tue, 10 May 2016 11:11:51 GMT]]></title><description><![CDATA[<p dir="auto">Okay thank you guys I’ll have to look into it.</p>
]]></description><link>https://forum.magicmirror.builders/post/391</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/391</guid><dc:creator><![CDATA[00conman]]></dc:creator><pubDate>Tue, 10 May 2016 11:11:51 GMT</pubDate></item><item><title><![CDATA[Reply to Change default interface colors on Tue, 10 May 2016 08:06:48 GMT]]></title><description><![CDATA[<p dir="auto">you can use the <code>/css/custom.css</code> to overwrite all styles. This file is embedded after all other css files, so you should be able to overwrite what you want. Is just a matter of creative CSS usage.</p>
]]></description><link>https://forum.magicmirror.builders/post/381</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/381</guid><dc:creator><![CDATA[MichMich]]></dc:creator><pubDate>Tue, 10 May 2016 08:06:48 GMT</pubDate></item><item><title><![CDATA[Reply to Change default interface colors on Tue, 10 May 2016 01:44:36 GMT]]></title><description><![CDATA[<p dir="auto">Also note the warning as stated on the wiki page:<br />
<strong>Note: If a file can not be loaded, the boot up of the mirror will stall.</strong></p>
<p dir="auto">Meaning, if you tell <code>getStyles</code> to look for a file called <code>'myStyles.css'</code> but in reality it’s called <code>'mystyles.css'</code> (case matters) or <code>'coolcolor.css'</code>, the mirror will stall and not load. So be careful.</p>
]]></description><link>https://forum.magicmirror.builders/post/375</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/375</guid><dc:creator><![CDATA[KirAsh4]]></dc:creator><pubDate>Tue, 10 May 2016 01:44:36 GMT</pubDate></item><item><title><![CDATA[Reply to Change default interface colors on Tue, 10 May 2016 01:33:58 GMT]]></title><description><![CDATA[<p dir="auto">The same approach applies when you’re creating your own custom modules. Keep in mind that if you edit the default files, a future update can overwrite them and you lose your changes.</p>
]]></description><link>https://forum.magicmirror.builders/post/374</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/374</guid><dc:creator><![CDATA[KirAsh4]]></dc:creator><pubDate>Tue, 10 May 2016 01:33:58 GMT</pubDate></item><item><title><![CDATA[Reply to Change default interface colors on Tue, 10 May 2016 01:32:40 GMT]]></title><description><![CDATA[<p dir="auto">By the way, that colorful screen capture was simply demonstrating that if you want to edit the default modules, you can, and you can then color them any way you want. In this case, I opened calendar.js and in the <code>'getStyles'</code> section, I added another file:</p>
<pre><code>        // Define required scripts.
        getStyles: function() {
                return ["calendar.css", "font-awesome.css", "mystyles.css"];
<p dir="auto">In this instance, <code>'mystyles.css'</code> is my custom one, which I then created and added my own colors to the various elements:</p>
<pre><code>#module_1_clock .time, #module_1_clock .date {
        color: #99F;
#module_1_clock .dimmed {
        color: #449;
#module_2_calendar header {
        color: #F00;
        border-bottom: 2px solid #600;
#module_2_calendar .title {
        color: #F99;
#module_2_calendar .time {
        color: #FBB;
#module_2_calendar .symbol {
        color: #FF0;
}</code></pre>
]]></description><link>https://forum.magicmirror.builders/post/373</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/373</guid><dc:creator><![CDATA[KirAsh4]]></dc:creator><pubDate>Tue, 10 May 2016 01:32:40 GMT</pubDate></item><item><title><![CDATA[Reply to Change default interface colors on Tue, 10 May 2016 01:20:51 GMT]]></title><description><![CDATA[<p dir="auto">Once I figure out why git(hub) is pulling in all of the erroneous stuff and fix that, I’ll create a pull request so it gets merged.</p>
]]></description><link>https://forum.magicmirror.builders/post/372</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/372</guid><dc:creator><![CDATA[KirAsh4]]></dc:creator><pubDate>Tue, 10 May 2016 01:20:51 GMT</pubDate></item><item><title><![CDATA[Reply to Change default interface colors on Tue, 10 May 2016 01:19:58 GMT]]></title><description><![CDATA[<p dir="auto">Whatever it is it’s awesome. Good on you man.</p>
]]></description><link>https://forum.magicmirror.builders/post/371</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/371</guid><dc:creator><![CDATA[00conman]]></dc:creator><pubDate>Tue, 10 May 2016 01:19:58 GMT</pubDate></item><item><title><![CDATA[Reply to Change default interface colors on Tue, 10 May 2016 01:19:37 GMT]]></title><description><![CDATA[<p dir="auto">A modified one that I haven’t checked into the base code yet. :)</p>
]]></description><link>https://forum.magicmirror.builders/post/370</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/370</guid><dc:creator><![CDATA[KirAsh4]]></dc:creator><pubDate>Tue, 10 May 2016 01:19:37 GMT</pubDate></item><item><title><![CDATA[Reply to Change default interface colors on Tue, 10 May 2016 01:17:58 GMT]]></title><description><![CDATA[<p dir="auto">I’ll look into it. By the way what calendar are you using?</p>
]]></description><link>https://forum.magicmirror.builders/post/369</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/369</guid><dc:creator><![CDATA[00conman]]></dc:creator><pubDate>Tue, 10 May 2016 01:17:58 GMT</pubDate></item><item><title><![CDATA[Reply to Change default interface colors on Tue, 10 May 2016 01:16:37 GMT]]></title><description><![CDATA[<p dir="auto">For custom modules that you create, you can use the getStyles method to assign a custom CSS file so you can override the colors to whatever you want. For the current, default modules, I <em>think</em> those are hard coded styles. I suppose you can always edit those files should you really want to.</p>
<p dir="auto"><img src="/uploads/files/1462842952242-colors.png" alt="0_1462842891241_Colors.png" class="img-markdown  img-fluid" /></p>
]]></description><link>https://forum.magicmirror.builders/post/368</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/368</guid><dc:creator><![CDATA[KirAsh4]]></dc:creator><pubDate>Tue, 10 May 2016 01:16:37 GMT</pubDate></item><item><title><![CDATA[Reply to Change default interface colors on Tue, 10 May 2016 00:27:19 GMT]]></title><description><![CDATA[<p dir="auto">I’m asking in reference to the color of the text.</p>
]]></description><link>https://forum.magicmirror.builders/post/364</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/364</guid><dc:creator><![CDATA[00conman]]></dc:creator><pubDate>Tue, 10 May 2016 00:27:19 GMT</pubDate></item><item><title><![CDATA[Reply to Change default interface colors on Mon, 09 May 2016 17:11:17 GMT]]></title><description><![CDATA[<p dir="auto">Assuming you’re simply talking about the elements on the display, one possible way is to use a custom CSS file, where you over ride the colors of the various elements.</p>
]]></description><link>https://forum.magicmirror.builders/post/353</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/353</guid><dc:creator><![CDATA[KirAsh4]]></dc:creator><pubDate>Mon, 09 May 2016 17:11:17 GMT</pubDate></item><item><title><![CDATA[Reply to Change default interface colors on Tue, 10 May 2016 04:47:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/00conman" aria-label="Profile: 00conman">@<bdi>00conman</bdi></a> what exactly do you mean? Do you want to for example change a text color?</p>
<p dir="auto"><strong>Another note:</strong> Please use a title for new topics that consists of more than just one word so people know what it is about! I chanced it for you this time :)</p>
]]></description><link>https://forum.magicmirror.builders/post/351</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/351</guid><dc:creator><![CDATA[paviro]]></dc:creator><pubDate>Tue, 10 May 2016 04:47:22 GMT</pubDate></item></channel></rss>
