<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-ping]]></title><description><![CDATA[<p dir="auto">To sum up the list here is also an unpublished module I did a while ago</p>
<p dir="auto"><a href="https://github.com/fewieden/MMM-ping" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/fewieden/MMM-ping</a></p>
<p dir="auto"><img src="https://github.com/fewieden/MMM-ping/raw/master/.github/example.png" alt="alt text" class=" img-fluid img-markdown" /> <img src="https://github.com/fewieden/MMM-ping/raw/master/.github/example2.png" alt="alt text" class=" img-fluid img-markdown" /></p>
<p dir="auto">[card:fewieden/MMM-ping]</p>
<p dir="auto">Requested from <a class="plugin-mentions-user plugin-mentions-a" href="/user/amanzimdwini" aria-label="Profile: amanzimdwini">@<bdi>amanzimdwini</bdi></a> <a class="plugin-mentions-user plugin-mentions-a" href="/user/phate" aria-label="Profile: Phate">@<bdi>Phate</bdi></a></p>
]]></description><link>https://forum.magicmirror.builders/topic/610/mmm-ping</link><generator>RSS for Node</generator><lastBuildDate>Sun, 14 Jun 2026 13:33:44 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/610.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 11 Sep 2016 07:22:14 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-ping on Fri, 25 Feb 2022 12:43:37 GMT]]></title><description><![CDATA[<p dir="auto">Could someone give an example how to activate / deactivate the monitor (hdmi) with dependency to the ping order?</p>
<p dir="auto">Like: if pinged device = onlinte then set hdmi :=  online if not hdmi := offline</p>
<p dir="auto">Thanks a lot</p>
]]></description><link>https://forum.magicmirror.builders/post/99927</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/99927</guid><dc:creator><![CDATA[wirthmaster]]></dc:creator><pubDate>Fri, 25 Feb 2022 12:43:37 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-ping on Tue, 12 May 2020 17:23:51 GMT]]></title><description><![CDATA[<h2>[2.0.1]</h2>
<h3>Added</h3>
<ul>
<li>Config option <code>transitionTime</code> <a href="https://github.com/fewieden/MMM-ping/issues/4" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/fewieden/MMM-ping/issues/4</a></li>
</ul>
]]></description><link>https://forum.magicmirror.builders/post/75082</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/75082</guid><dc:creator><![CDATA[strawberry 3.141]]></dc:creator><pubDate>Tue, 12 May 2020 17:23:51 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-ping on Thu, 07 May 2020 19:46:51 GMT]]></title><description><![CDATA[<h2>[2.0.0]</h2>
<h3>Added</h3>
<ul>
<li>Nunjuck templates</li>
<li>Documentation</li>
<li>Contributing guidelines</li>
<li>Issue template</li>
<li>Pull request template</li>
<li>Integration of <a href="https://github.com/fewieden/MMM-voice" target="_blank" rel="noopener noreferrer nofollow ugc">MMM-voice</a> and <a href="https://github.com/fewieden/MMM-Modal" target="_blank" rel="noopener noreferrer nofollow ugc">MMM-Modal</a></li>
</ul>
<h3>Changed</h3>
<ul>
<li>Config files</li>
<li>async/await on the node side of the module.</li>
<li>eslint recommended instead of airbnb ruleset.</li>
</ul>
]]></description><link>https://forum.magicmirror.builders/post/74840</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/74840</guid><dc:creator><![CDATA[strawberry 3.141]]></dc:creator><pubDate>Thu, 07 May 2020 19:46:51 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-ping on Tue, 20 Sep 2016 13:34:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ianperrin" aria-label="Profile: ianperrin">@<bdi>ianperrin</bdi></a> Thanks for the update,eager to see the module.</p>
]]></description><link>https://forum.magicmirror.builders/post/5085</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/5085</guid><dc:creator><![CDATA[shashank]]></dc:creator><pubDate>Tue, 20 Sep 2016 13:34:11 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-ping on Tue, 20 Sep 2016 11:47:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/shashank" aria-label="Profile: shashank">@<bdi>shashank</bdi></a> said in <a href="/post/5069">MMM-ping</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/strawberry-3.141" aria-label="Profile: strawberry-3.141">@<bdi>strawberry-3.141</bdi></a> I got this module installed working fine, I have a request here, I have many devices connected with DHCP in my local network at home, is it possible to get the IP using MAC address of the device. only IP with friendly name has to be displayed on the Mirror. At present i have 5 Rasp pi connected each in a room using as a MultiRoom audio system.</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/shashank" aria-label="Profile: shashank">@<bdi>shashank</bdi></a> I had a similar requirement so I temporarily created another module which scans the network for devices based on their mac address, and then displays their status. I use it to display an indicator of who is home based on the visibility of their smart phone devices…</p>
<p dir="auto">I was planned to see if I could merge this into MMM-Ping and create a pull request. Sadly this is bottom of the pile right now. I could publish it as a separate repository if that helps</p>
]]></description><link>https://forum.magicmirror.builders/post/5083</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/5083</guid><dc:creator><![CDATA[ianperrin]]></dc:creator><pubDate>Tue, 20 Sep 2016 11:47:40 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-ping on Tue, 20 Sep 2016 03:54:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/strawberry-3.141" aria-label="Profile: strawberry-3.141">@<bdi>strawberry-3.141</bdi></a> I got this module installed working fine, I have a request here, I have many devices connected with DHCP in my local network at home, is it possible to get the IP using MAC address of the device. only IP with friendly name has to be displayed on the Mirror. At present i have 5 Rasp pi connected each in a room using as a MultiRoom audio system.</p>
]]></description><link>https://forum.magicmirror.builders/post/5069</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/5069</guid><dc:creator><![CDATA[shashank]]></dc:creator><pubDate>Tue, 20 Sep 2016 03:54:02 GMT</pubDate></item></channel></rss>
