<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Google assistant on magicmirror]]></title><description><![CDATA[<p dir="auto">can anyone help how to do the below steps?</p>
<p dir="auto">Install Pubnub dependencies using pip install ‘pubnub&gt;=4.0.13’<br />
If you get an error while installing Pubnub, try using sudo: ‘sudo pubnub&gt;=4.0.13’<br />
Download the ‘pi/assistant.py’ script on your raspberry pi and launch it via terminal<br />
If you see a ‘No module named google’ error try running it via /home/pi/env/bin/python3 -u<br />
<a href="http://assistant.py" target="_blank" rel="noopener noreferrer nofollow ugc">assistant.py</a></p>
<p dir="auto">Im not good at programming… please help me…</p>
]]></description><link>https://forum.magicmirror.builders/topic/6103/google-assistant-on-magicmirror</link><generator>RSS for Node</generator><lastBuildDate>Sun, 09 Aug 2026 07:47:23 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/6103.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 08 Jan 2018 09:00:02 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Google assistant on magicmirror on Fri, 05 Apr 2019 21:43:56 GMT]]></title><description><![CDATA[<p dir="auto">See MMM-AssistantMk2</p>
<p dir="auto">has GA and can execute actions on mirror</p>
]]></description><link>https://forum.magicmirror.builders/post/55477</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/55477</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 05 Apr 2019 21:43:56 GMT</pubDate></item><item><title><![CDATA[Reply to Google assistant on magicmirror on Fri, 05 Apr 2019 21:35:53 GMT]]></title><description><![CDATA[<p dir="auto">I did all the current steps. GA worked. But the Smart mirror is not active. Only the GA symbol appears. I’m having trouble with <a href="http://assistant.py" target="_blank" rel="noopener noreferrer nofollow ugc">assistant.py</a>. Can you help?</p>
]]></description><link>https://forum.magicmirror.builders/post/55476</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/55476</guid><dc:creator><![CDATA[onurcnbs]]></dc:creator><pubDate>Fri, 05 Apr 2019 21:35:53 GMT</pubDate></item><item><title><![CDATA[Reply to Google assistant on magicmirror on Wed, 21 Mar 2018 17:31:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/hrjmsh" aria-label="Profile: hrjmsh">@<bdi>hrjmsh</bdi></a> sure you want to raise a pull request with this change?</p>
]]></description><link>https://forum.magicmirror.builders/post/37281</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/37281</guid><dc:creator><![CDATA[gauravsacc]]></dc:creator><pubDate>Wed, 21 Mar 2018 17:31:09 GMT</pubDate></item><item><title><![CDATA[Reply to Google assistant on magicmirror on Tue, 20 Mar 2018 22:59:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/gauravsacc" aria-label="Profile: gauravsacc">@<bdi>gauravsacc</bdi></a> Great, thanks. All working fine.<br />
It might be a good idea to include that information in your module page at the end of instructions. It would help a lot to a novice and inexperienced like me!</p>
]]></description><link>https://forum.magicmirror.builders/post/37254</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/37254</guid><dc:creator><![CDATA[hrjmsh]]></dc:creator><pubDate>Tue, 20 Mar 2018 22:59:09 GMT</pubDate></item><item><title><![CDATA[Reply to Google assistant on magicmirror on Mon, 19 Mar 2018 02:47:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/hrjmsh" aria-label="Profile: hrjmsh">@<bdi>hrjmsh</bdi></a> Yes <a href="http://assistant.py" target="_blank" rel="noopener noreferrer nofollow ugc">assistant.py</a> should be running in the background</p>
]]></description><link>https://forum.magicmirror.builders/post/37188</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/37188</guid><dc:creator><![CDATA[gauravsacc]]></dc:creator><pubDate>Mon, 19 Mar 2018 02:47:08 GMT</pubDate></item><item><title><![CDATA[Reply to Google assistant on magicmirror on Sun, 18 Mar 2018 23:01:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/gauravsacc" aria-label="Profile: gauravsacc">@<bdi>gauravsacc</bdi></a> First, many thanks for such an excellent effort. Unfortunately, despite having the latest and updated module version, I am having the same ‘no start’ issue in Magic Mirror as others have mentioned. I can start ‘<a href="http://assistant.py" target="_blank" rel="noopener noreferrer nofollow ugc">assistant.py</a>’ under “source env/bin/activate” and it works absolutely fine while staying in the terminal. But once in Magic Mirror, the google assistant remains unresponsive. Does ‘<a href="http://assistant.py" target="_blank" rel="noopener noreferrer nofollow ugc">assistant.py</a>’ needs to run as a script in the background at startup or is there anything else I am missing?</p>
]]></description><link>https://forum.magicmirror.builders/post/37184</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/37184</guid><dc:creator><![CDATA[hrjmsh]]></dc:creator><pubDate>Sun, 18 Mar 2018 23:01:23 GMT</pubDate></item><item><title><![CDATA[Reply to Google assistant on magicmirror on Sat, 24 Feb 2018 14:15:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/gauravsacc" aria-label="Profile: gauravsacc">@<bdi>gauravsacc</bdi></a></p>
<p dir="auto">Hello,<br />
I tried a git pull on the module MMM-Assistant but I still encounter the same problem. The voice is still jerky in English while I wish in French.<br />
there is a good chance that I made a mistake during the installation but I can not find where.<br />
Are you a beginning of track to communicate to me?<br />
Thank you in advance,</p>
<pre><code></code></pre>
]]></description><link>https://forum.magicmirror.builders/post/36211</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/36211</guid><dc:creator><![CDATA[Chris]]></dc:creator><pubDate>Sat, 24 Feb 2018 14:15:04 GMT</pubDate></item><item><title><![CDATA[Reply to Google assistant on magicmirror on Wed, 21 Feb 2018 13:35:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/chris" aria-label="Profile: Chris">@<bdi>Chris</bdi></a> A bit late but the module is updated now. Go ahead and pull the update, let me know if you are still facing issues. Happy to help!</p>
]]></description><link>https://forum.magicmirror.builders/post/36062</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/36062</guid><dc:creator><![CDATA[gauravsacc]]></dc:creator><pubDate>Wed, 21 Feb 2018 13:35:21 GMT</pubDate></item><item><title><![CDATA[Reply to Google assistant on magicmirror on Wed, 10 Jan 2018 08:38:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/clconner09" aria-label="Profile: clconner09">@<bdi>clconner09</bdi></a><br />
Hello,<br />
I was unfortunately forced to give up. After several installations, always the same problem.<br />
I will wait to see if the developer of this great module will update soon.</p>
<p dir="auto">cordially,</p>
]]></description><link>https://forum.magicmirror.builders/post/33729</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/33729</guid><dc:creator><![CDATA[Chris]]></dc:creator><pubDate>Wed, 10 Jan 2018 08:38:20 GMT</pubDate></item><item><title><![CDATA[Reply to Google assistant on magicmirror on Tue, 09 Jan 2018 15:31:59 GMT]]></title><description><![CDATA[<p dir="auto">Same problem here although mine doesn’t appear to trigger at all.  I’ve gotten the sample to run. I can run <a href="http://assistant.py" target="_blank" rel="noopener noreferrer nofollow ugc">assistant.py</a> and interact but when altering the config file and running MM.  Nothing but an icon at the top.</p>
]]></description><link>https://forum.magicmirror.builders/post/33667</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/33667</guid><dc:creator><![CDATA[clconner09]]></dc:creator><pubDate>Tue, 09 Jan 2018 15:31:59 GMT</pubDate></item><item><title><![CDATA[Reply to Google assistant on magicmirror on Mon, 08 Jan 2018 13:40:18 GMT]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">I also have problems with the operation of this module.</p>
<p dir="auto">I posted in another post: <a href="https://forum.magicmirror.builders/topic/5575/assistant-error/8">https://forum.magicmirror.builders/topic/5575/assistant-error/8</a></p>
<p dir="auto">In my case, the google icon appears but only triggers once and I do not get an answer.<br />
I encounter the same problem with the icon of the mirror which remains stuck waiting. I have to restart the mirror.</p>
<p dir="auto">Should you also follow the steps in the link <a href="https://developers.google.com/assistant/sdk/guides/library/python/embed/install-sample" target="_blank" rel="noopener noreferrer nofollow ugc">https://developers.google.com/assistant/sdk/guides/library/python/embed/install-sample</a><br />
despite the fact that it is not mentioned in the wiki?</p>
<p dir="auto">Thanking you in advance for your answers.</p>
]]></description><link>https://forum.magicmirror.builders/post/33586</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/33586</guid><dc:creator><![CDATA[Chris]]></dc:creator><pubDate>Mon, 08 Jan 2018 13:40:18 GMT</pubDate></item><item><title><![CDATA[Reply to Google assistant on magicmirror on Mon, 08 Jan 2018 11:05:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nitrogen73" aria-label="Profile: nitrogen73">@<bdi>nitrogen73</bdi></a> Also, i register the Device Model as instructed in above link. In order for the Google Assistant to respond to commands appropriate to your device and the given context, the Assistant needs information about your particular device.</p>
]]></description><link>https://forum.magicmirror.builders/post/33581</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/33581</guid><dc:creator><![CDATA[aro28]]></dc:creator><pubDate>Mon, 08 Jan 2018 11:05:31 GMT</pubDate></item><item><title><![CDATA[Reply to Google assistant on magicmirror on Mon, 08 Jan 2018 11:03:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nitrogen73" aria-label="Profile: nitrogen73">@<bdi>nitrogen73</bdi></a> said in <a href="/post/33578">Google assistant on magicmirror</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/aro28" aria-label="Profile: aro28">@<bdi>aro28</bdi></a> Could you please tell me what you done after completing the steps in below link?</p>
<p dir="auto">I followed below link: <a href="https://github.com/eouia/MMM-Assistant/wiki" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/eouia/MMM-Assistant/wiki</a></p>
<p dir="auto">If you are able to launch google-assistant-demo(<a href="https://developers.google.com/assistant/sdk/prototype/getting-started-pi-python/run-sample" target="_blank" rel="noopener noreferrer nofollow ugc">https://developers.google.com/assistant/sdk/prototype/getting-started-pi-python/run-sample</a>) and use the assistant, you should able to use the ‘pi/assistant.py’ script that communicates with the magic mirror module.</p>
]]></description><link>https://forum.magicmirror.builders/post/33580</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/33580</guid><dc:creator><![CDATA[aro28]]></dc:creator><pubDate>Mon, 08 Jan 2018 11:03:31 GMT</pubDate></item><item><title><![CDATA[Reply to Google assistant on magicmirror on Mon, 08 Jan 2018 10:22:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/aro28" aria-label="Profile: aro28">@<bdi>aro28</bdi></a> Could you please tell me what you done after completing the steps in below link?</p>
<p dir="auto"><a href="https://developers.google.com/assistant/sdk/guides/library/python/embed/install-sample" target="_blank" rel="noopener noreferrer nofollow ugc">https://developers.google.com/assistant/sdk/guides/library/python/embed/install-sample</a></p>
]]></description><link>https://forum.magicmirror.builders/post/33578</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/33578</guid><dc:creator><![CDATA[nitrogen73]]></dc:creator><pubDate>Mon, 08 Jan 2018 10:22:55 GMT</pubDate></item><item><title><![CDATA[Reply to Google assistant on magicmirror on Mon, 08 Jan 2018 10:13:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nitrogen73" aria-label="Profile: nitrogen73">@<bdi>nitrogen73</bdi></a> said in <a href="/post/33576">Google assistant on magicmirror</a>:</p>
<p dir="auto">Please let me know once you figure it out… And thank you very much for your reply…</p>
<p dir="auto">I’ve posted my issue on below link. Please feel free and participate in discussion as well.<br />
<a href="https://github.com/gauravsacc/MMM-GoogleAssistant/issues/18" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/gauravsacc/MMM-GoogleAssistant/issues/18</a></p>
]]></description><link>https://forum.magicmirror.builders/post/33577</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/33577</guid><dc:creator><![CDATA[aro28]]></dc:creator><pubDate>Mon, 08 Jan 2018 10:13:57 GMT</pubDate></item><item><title><![CDATA[Reply to Google assistant on magicmirror on Mon, 08 Jan 2018 10:09:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/aro28" aria-label="Profile: aro28">@<bdi>aro28</bdi></a> Please let me know once you figure it out… And thank you very much for your reply…</p>
]]></description><link>https://forum.magicmirror.builders/post/33576</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/33576</guid><dc:creator><![CDATA[nitrogen73]]></dc:creator><pubDate>Mon, 08 Jan 2018 10:09:46 GMT</pubDate></item><item><title><![CDATA[Reply to Google assistant on magicmirror on Mon, 08 Jan 2018 09:58:45 GMT]]></title><description><![CDATA[<p dir="auto">Yes. Same for me. I can see Google Logo and nothing happens on “Ok, google how’s the weather today?” No reaction.</p>
]]></description><link>https://forum.magicmirror.builders/post/33575</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/33575</guid><dc:creator><![CDATA[aro28]]></dc:creator><pubDate>Mon, 08 Jan 2018 09:58:45 GMT</pubDate></item><item><title><![CDATA[Reply to Google assistant on magicmirror on Mon, 08 Jan 2018 09:57:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/aro28" aria-label="Profile: aro28">@<bdi>aro28</bdi></a> i already done all the steps mentioned in the link <a href="https://developers.google.com/assistant/sdk/guides/library/python/embed/install-sample" target="_blank" rel="noopener noreferrer nofollow ugc">https://developers.google.com/assistant/sdk/guides/library/python/embed/install-sample</a></p>
<p dir="auto">and it also worked fine.</p>
<p dir="auto">But the real problem is when i start the magicmirror the google assistant does not start. How to bring the google assistant module in magicmirror? I also add the script in the config.js. In the display it shows only the image of the google assistant.</p>
]]></description><link>https://forum.magicmirror.builders/post/33574</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/33574</guid><dc:creator><![CDATA[nitrogen73]]></dc:creator><pubDate>Mon, 08 Jan 2018 09:57:38 GMT</pubDate></item><item><title><![CDATA[Reply to Google assistant on magicmirror on Mon, 08 Jan 2018 09:37:15 GMT]]></title><description><![CDATA[<p dir="auto">Hi,<br />
I did it in Python virtual environment and it works.<br />
go to "source env/bin/activate " and install Pubnub dependencies using pip install ‘pubnub&gt;=4.0.13’.<br />
see below link<br />
<p dir="auto">Let me know if it works for you.<br />
Best,</p>
]]></description><link>https://forum.magicmirror.builders/post/33572</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/33572</guid><dc:creator><![CDATA[aro28]]></dc:creator><pubDate>Mon, 08 Jan 2018 09:37:15 GMT</pubDate></item></channel></rss>
