<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[keep running against a wall]]></title><description><![CDATA[<h2>can someone look at my code and tell me what iam doing wrong?```<br />
//<br />
language: “en”,<br />
–	timeFormat: 24,<br />
–	units: “metric”,</h2>
<p dir="auto">–	modules: [<br />
–		{<br />
–			module: “alert”,<br />
–		},<br />
–		{<br />
–			module: “updatenotification”,<br />
–			position: “top_bar”<br />
–		},<br />
–		{<br />
–			module: “clock”,<br />
–			position: “top_left”<br />
–		},<br />
–		{<br />
–		module: “rainfc”,<br />
–		position: “top_right”,<br />
–            	header: “Rain forecast”,<br />
–		config: {<br />
–			lat: “52.525”,<br />
–			lon: “5.71806”,<br />
–			width: 200,<br />
–			height: 150,<br />
–			lineWidth: 2,<br />
–			lineColor: “#e0ffe0”,<br />
–			fillColor: “#e0ffe0”,<br />
–			maxPower: 300,<br />
–			rainText: "Tot: ",<br />
–			noRainText: "Geen regen tot: ",<br />
–			nrOfTimeLabels: 5 // advised values: 2-5<br />
–		},<br />
–		{<br />
–			module: “calendar”,<br />
–			header: “agenda”,<br />
–			position: “top_left”,<br />
–			config: {<br />
–				calendars: [<br />
–					{<br />
–				symbol:“calendar”,<br />
–				url:“<a href="https://calendar.google.com/calendar/ical/my" target="_blank" rel="noopener noreferrer nofollow ugc">https://calendar.google.com/calendar/ical/my</a> <a href="http://info.calendar.google.com/public/basic.ics" target="_blank" rel="noopener noreferrer nofollow ugc">info.calendar.google.com/public/basic.ics</a>”,<br />
–			},<br />
–						symbol: "calendar-check-o ",<br />
–						url: “<a href="https://calendar.google.com/calendar/ical/myinf%40gmail.com/public/basic.ics" target="_blank" rel="noopener noreferrer nofollow ugc">https://calendar.google.com/calendar/ical/myinf%40gmail.com/public/basic.ics</a>”<br />
–					}<br />
–				]<br />
–			}<br />
–		},</p>
<pre><code></code></pre>
]]></description><link>https://forum.magicmirror.builders/topic/6234/keep-running-against-a-wall</link><generator>RSS for Node</generator><lastBuildDate>Fri, 10 Apr 2026 12:18:01 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/6234.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 15 Jan 2018 11:11:15 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to keep running against a wall on Wed, 17 Jan 2018 12:17:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/noiz13" aria-label="Profile: noiz13">@<bdi>noiz13</bdi></a> said in <a href="/post/34134">keep running against a wall</a>:</p>
<p dir="auto">can i use  normal debian would that be better?</p>
<p dir="auto">You sure can. I use ubuntu on my old laptops. It works perfectly for MM.</p>
]]></description><link>https://forum.magicmirror.builders/post/34145</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/34145</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Wed, 17 Jan 2018 12:17:55 GMT</pubDate></item><item><title><![CDATA[Reply to keep running against a wall on Wed, 17 Jan 2018 09:36:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mykle1" aria-label="Profile: Mykle1">@<bdi>Mykle1</bdi></a> it works  thank you for your code now i can learn more.</p>
<p dir="auto">regarding the os i have put raspian on the laptop because my thought is that works the best.<br />
however MM is seeing my laptop as a raspberry 1 witch is  incompatible with MM can i use  normal debian would that be better?</p>
]]></description><link>https://forum.magicmirror.builders/post/34134</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/34134</guid><dc:creator><![CDATA[noiz13]]></dc:creator><pubDate>Wed, 17 Jan 2018 09:36:16 GMT</pubDate></item><item><title><![CDATA[Reply to keep running against a wall on Tue, 16 Jan 2018 12:14:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/noiz13" aria-label="Profile: noiz13">@<bdi>noiz13</bdi></a></p>
<p dir="auto">Graag gedaan! (I googled that)</p>
<p dir="auto">Old laptops are an excellent choice for getting to know the MM software or for driving the mirror itself. In fact, they are all I use these days. They are widely available, relatively inexpensive and have everything you need built right in. I’ve made 2 mirrors using just a laptop. They perform exceptionally well.</p>
<p dir="auto">Peace.</p>
]]></description><link>https://forum.magicmirror.builders/post/34060</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/34060</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Tue, 16 Jan 2018 12:14:22 GMT</pubDate></item><item><title><![CDATA[Reply to keep running against a wall on Tue, 16 Jan 2018 06:59:09 GMT]]></title><description><![CDATA[<p dir="auto">thank you this is awesome much appreciated. now i  can appropriated  old laptop and use it as my test set.</p>
]]></description><link>https://forum.magicmirror.builders/post/34054</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/34054</guid><dc:creator><![CDATA[noiz13]]></dc:creator><pubDate>Tue, 16 Jan 2018 06:59:09 GMT</pubDate></item><item><title><![CDATA[Reply to keep running against a wall on Mon, 15 Jan 2018 21:38:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/noiz13" aria-label="Profile: noiz13">@<bdi>noiz13</bdi></a> said in <a href="/post/33992">keep running against a wall</a>:</p>
<p dir="auto"><a href="https://www.nu.nl/rss/Algemeen.xml" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.nu.nl/rss/Algemeen.xml</a></p>
<p dir="auto">Ok, I took a look at this at Peter’s request, so you can thank him. A number of things wrong with this config.</p>
<ol>
<li>
<p dir="auto">This calendar url fails to load<br />
<a href="https://calendar.google.com/calendar/ical/8tjs1qac4300edu3evdqsh3gp8%40group.calendar.google.com/public/basic.ics" target="_blank" rel="noopener noreferrer nofollow ugc">https://calendar.google.com/calendar/ical/8tjs1qac4300edu3evdqsh3gp8%40group.calendar.google.com/public/basic.ics</a></p>
</li>
<li>
<p dir="auto">This calendar url:<br />
<a href="https://calendar.google.com/calendar/ical/ferrynoiz%40gmail.com/public/basic.ics" target="_blank" rel="noopener noreferrer nofollow ugc">https://calendar.google.com/calendar/ical/ferrynoiz%40gmail.com/public/basic.ics</a></p>
</li>
</ol>
<p dir="auto">Only returns this<br />
<img src="/assets/uploads/files/1516051367427-1.png" alt="0_1516051365022_1.PNG" class=" img-fluid img-markdown" /></p>
<ol start="3">
<li>
<p dir="auto">This newfeed url is not working<br />
</li>
<li>
<p dir="auto">The author of “rainfc” created the repo in the name of MMM-rainfc. This is a problem because the module files are named “rainfc.js” and “rainfc.css”. So, for now, you can simply rename your MMM-rainfc folder to “rainfc” to coincide with your config.js entry. You can message the author about the error.</p>
</li>
<li>
<p dir="auto">the rainfc module loaded once for me with a black and white graph. The very next time I tried to run it I saw the message “NO DATA” and this:<br />
<img src="/assets/uploads/files/1516052022867-2.png" alt="0_1516052020800_2.PNG" class=" img-fluid img-markdown" /></p>
</li>
</ol>
<p dir="auto">I highly suspect that the API for this module is having troubles, at least at the moment of my testing.</p>
<ol start="6">
<li>I have no idea where all those double dashes in your config came from. Those have to go. If you can simply copy and paste you can use this, saved as a js file and named “config.js”</li>
</ol>
 * MIT Licensed.
var config = {
	port: 8080,
	language: "en",
	timeFormat: 24,
	units: "metric",
			module: "alert",
			module: "updatenotification",
			position: "top_bar"
			module: "clock",
			position: "top_left"
		module: "rainfc",
            	header: "Rain forecast",
			lat: "52.37",
			lon: "4.90",
			width: 200,
			height: 150,
			lineWidth: 2,
			lineColor: "#e0ffe0",
			fillColor: "#e0ffe0",
			maxPower: 300,
			rainText: "Tot: ",
			header: "US Holidaysz",
						url: "https://calendar.google.com/calendar/ical/ferrynoiz%40gmail.com/public/basic.ics"
					//	url: "https://calendar.google.com/calendar/ical/8tjs1qac4300edu3evdqsh3gp8%40group.calendar.google.com/public/basic.ics"
					//	url: "webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics"
			module: "compliments",
			position: "lower_third"
			module: "currentweather",
				locationID: "",  //ID from http://www.openweathermap.org/help/city_list.txt
				appid: "YOUR_OPENWEATHER_API_KEY"
			module: "weatherforecast",
			header: "Weather Forecast",
				locationID: "5128581",  //ID from http://www.openweathermap.org/help/city_list.txt
			module: "newsfeed",
			position: "bottom_bar",
				feeds: [
						title: "New York Times",
					//	url: "https://www.nu.nl/rss/Algemeen.xml",
				showSourceTitle: true,
				showPublishDate: true
]]></description><link>https://forum.magicmirror.builders/post/34035</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/34035</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Mon, 15 Jan 2018 21:38:26 GMT</pubDate></item><item><title><![CDATA[Reply to keep running against a wall on Mon, 15 Jan 2018 13:00:08 GMT]]></title><description><![CDATA[<p dir="auto">I prefer notepad++ on PC and notepadqq on linux but there are others. Sublime is another favorite of many people</p>
]]></description><link>https://forum.magicmirror.builders/post/33995</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/33995</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Mon, 15 Jan 2018 13:00:08 GMT</pubDate></item><item><title><![CDATA[Reply to keep running against a wall on Mon, 15 Jan 2018 12:57:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mykle1" aria-label="Profile: Mykle1">@<bdi>Mykle1</bdi></a> said in <a href="/post/33993">keep running against a wall</a>:</p>
<p dir="auto">“MMM-rainfc”</p>
<p dir="auto">that is so small i did not see it can you recommend a good  text editor for a noob?</p>
]]></description><link>https://forum.magicmirror.builders/post/33994</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/33994</guid><dc:creator><![CDATA[noiz13]]></dc:creator><pubDate>Mon, 15 Jan 2018 12:57:36 GMT</pubDate></item><item><title><![CDATA[Reply to keep running against a wall on Mon, 15 Jan 2018 12:57:17 GMT]]></title><description><![CDATA[<p dir="auto">I’m pretty sure that these type of quotes <code>“MMM-rainfc”</code>will cause syntax errors. Notice the difference between those and these <code>"MMM-rainfc"</code></p>
<p dir="auto">Edit: Nevermind! :-)</p>
]]></description><link>https://forum.magicmirror.builders/post/33993</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/33993</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Mon, 15 Jan 2018 12:57:17 GMT</pubDate></item><item><title><![CDATA[Reply to keep running against a wall on Mon, 15 Jan 2018 12:55:02 GMT]]></title><description><![CDATA[<p dir="auto">i hope i changed it correctly  it is all new for me and english is my second Language</p>
<pre><code>--/* Magic Mirror Config Sample
-- * By Michael Teeuw http://michaelteeuw.nl
-- * MIT Licensed.
-- * For more information how you can configurate this file
-- * See https://github.com/MichMich/MagicMirror#configuration
--var config = {
--	address: "localhost", // Address to listen on, can be:
--	                      // - "localhost", "127.0.0.1", "::1" to listen on loopback interface
--	                      // - another specific IPv4/6 to listen on a specific interface
--	                      // - "", "0.0.0.0", "::" to listen on any interface
--	                      // Default, when address config is left out, is "localhost"
--	port: 8080,
--	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"], // Set [] to allow all IP addresses
--	                                                       // or add a specific IPv4 of 192.168.1.5 :
--	                                                       // ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.1.5"],
--	                                                       // or IPv4 range of 192.168.3.0 --&gt; 192.168.3.15 use CIDR format :
--	                                                       // ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.3.0/28"],
--	language:  ';'en",
timeFormat: 24,
units: "metric",
--	modules: [
--			module: "alert",
--			module: "updatenotification",
--			position: "top_bar"
--			module: "clock",
--			position: "top_left"
--		module: "MMM-rainfc",
--		position: “top_right”,
--            	header: “Rain forecast”,
--		config: {
--			lat: "52.525",
--			lon: "5.71806",
--			width: 200,
--			height: 150,
--			lineWidth: 2,
--			lineColor: "#e0ffe0",
--			fillColor: "#e0ffe0",
--			maxPower: 300,
--			rainText: "Tot: ",
--			noRainText: "Geen regen tot: ",
--			nrOfTimeLabels: 5 // advised values: 2-5
--			module: "calendar",
--			header: "agenda",
--			position: "top_left",
--			config: {
--				calendars: [
--				symbol:"calendar",
--				url:"https://calendar.google.com/calendar/ical/8tjs1qac4300edu3evdqsh3gp8%40group.calendar.google.com/public/basic.ics",
--						symbol: "calendar-check-o ",
--						url: "https://calendar.google.com/calendar/ical/ferrynoiz%40gmail.com/public/basic.ics"
--			module: "compliments",
--			position: "lower_third"
--			module: "newsfeed",
--			position: "bottom_bar",
--			config: {
--				feeds: [
--						title: "Nu",
--						url: "https://www.nu.nl/rss/Algemeen.xml"
--				showSourceTitle: true,
--				showPublishDate: true
--/*************** DO NOT EDIT THE LINE BELOW ***************/
--if (typeof module !== "undefined") {module.exports = config;}
]]></description><link>https://forum.magicmirror.builders/post/33992</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/33992</guid><dc:creator><![CDATA[noiz13]]></dc:creator><pubDate>Mon, 15 Jan 2018 12:55:02 GMT</pubDate></item><item><title><![CDATA[Reply to keep running against a wall on Mon, 15 Jan 2018 12:27:49 GMT]]></title><description><![CDATA[<p dir="auto">Please use the <a href="https://github.com/adam-p/markdown-here/wiki/Markdown-Cheatsheet#code" target="_blank" rel="noopener noreferrer nofollow ugc">markdown features</a> to make your code easier to read.</p>
<p dir="auto">The name of the module must match the name of the Github project and (more importantly) the name of the directory where the module resides. Try <code>module: “MMM-rainfc”,</code>. Also, it looks like you closed the config of the rainfc module, but you didn’t close the module itself. So:</p>
<pre><code>{
lat: “52.525”,
lon: “5.71806”,
width: 200,
height: 150,
lineWidth: 2,
maxPower: 300,
rainText: "Tot: ",
]]></description><link>https://forum.magicmirror.builders/post/33989</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/33989</guid><dc:creator><![CDATA[bhepler]]></dc:creator><pubDate>Mon, 15 Jan 2018 12:27:49 GMT</pubDate></item></channel></rss>
