<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Show a picture infont of everything with a button]]></title><description><![CDATA[<p dir="auto">I want a button connected to my RPI gpio I can turn on and then a picture is shown.</p>
<p dir="auto">PLZ help me out!</p>
]]></description><link>https://forum.magicmirror.builders/topic/6236/show-a-picture-infont-of-everything-with-a-button</link><generator>RSS for Node</generator><lastBuildDate>Thu, 18 Jun 2026 17:39:49 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/6236.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 15 Jan 2018 13:25:01 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Show a picture infont of everything with a button on Wed, 17 Jan 2018 09:46:44 GMT]]></title><description><![CDATA[<p dir="auto">You can check if MMM-Button works by checking the console (not the browser console but where you type in the command to start the MM), it should write <code>"button pressed"</code> when you use the button.</p>
<p dir="auto">In my JS file, add a <code>Log.info("notification: " + notification + "; payload: " + payload + "; sender: " + sender);</code> in line 26 and see if it comes up and what it shows.</p>
<p dir="auto">You can check if the cover works by using the developer tools, finding the module and adding the class <code>show-image</code>.</p>
]]></description><link>https://forum.magicmirror.builders/post/34136</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/34136</guid><dc:creator><![CDATA[doubleT]]></dc:creator><pubDate>Wed, 17 Jan 2018 09:46:44 GMT</pubDate></item><item><title><![CDATA[Reply to Show a picture infont of everything with a button on Wed, 17 Jan 2018 07:25:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/doublet" aria-label="Profile: doubleT">@<bdi>doubleT</bdi></a><br />
I dont feel the MMM-Button is giving some info… i copy paste the config fron readme, dont work…</p>
]]></description><link>https://forum.magicmirror.builders/post/34127</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/34127</guid><dc:creator><![CDATA[duedahlb]]></dc:creator><pubDate>Wed, 17 Jan 2018 07:25:36 GMT</pubDate></item><item><title><![CDATA[Reply to Show a picture infont of everything with a button on Tue, 16 Jan 2018 22:31:28 GMT]]></title><description><![CDATA[<p dir="auto">Ok, I wrote something that <s><em>could</em></s> … <s><em>should</em></s> … I expect to be working with <a href="https://github.com/PtrBld/MMM-Button" target="_blank" rel="noopener noreferrer nofollow ugc">MMM-Button</a>. At the moment I don’t have a button to test it with. I’ll try to get some testing done next weekend.</p>
<p dir="auto"><a href="https://github.com/TTigges/MMM-FullsizeCover" target="_blank" rel="noopener noreferrer nofollow ugc">MMM-FullsizeCover</a><br />
Check the readme and the guide to get it running. Let me know if it works. ;)</p>
]]></description><link>https://forum.magicmirror.builders/post/34096</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/34096</guid><dc:creator><![CDATA[doubleT]]></dc:creator><pubDate>Tue, 16 Jan 2018 22:31:28 GMT</pubDate></item><item><title><![CDATA[Reply to Show a picture infont of everything with a button on Tue, 16 Jan 2018 14:46:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/doublet" aria-label="Profile: doubleT">@<bdi>doubleT</bdi></a><br />
I have everything i need:) just not the code/module:/</p>
<p dir="auto">i want the: A</p>
]]></description><link>https://forum.magicmirror.builders/post/34071</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/34071</guid><dc:creator><![CDATA[duedahlb]]></dc:creator><pubDate>Tue, 16 Jan 2018 14:46:03 GMT</pubDate></item><item><title><![CDATA[Reply to Show a picture infont of everything with a button on Tue, 16 Jan 2018 14:35:28 GMT]]></title><description><![CDATA[<p dir="auto">Did you check MMM-Button and do you want to use it? Is the button already connected?</p>
<p dir="auto">btw.</p>
<p dir="auto">show a picture infront of my magicmirror while their still loading in the background…</p>
<p dir="auto">While what is loading in the background? I see two different things and demands here:<br />
a) image goes on or off on button press<br />
b) mirror starts with image and when everything is loaded, the image goes away</p>
]]></description><link>https://forum.magicmirror.builders/post/34069</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/34069</guid><dc:creator><![CDATA[doubleT]]></dc:creator><pubDate>Tue, 16 Jan 2018 14:35:28 GMT</pubDate></item><item><title><![CDATA[Reply to Show a picture infont of everything with a button on Tue, 16 Jan 2018 14:12:09 GMT]]></title><description><![CDATA[<p dir="auto">Can someone PLZ code it for me? I only do some HTML and CSS…</p>
<p dir="auto">I want to show a picture infront of my magicmirror while their still loading in the background…</p>
<ol>
<li>push once- a picture is shown over the screen</li>
<li>push once again, the picture goes away</li>
</ol>
]]></description><link>https://forum.magicmirror.builders/post/34068</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/34068</guid><dc:creator><![CDATA[duedahlb]]></dc:creator><pubDate>Tue, 16 Jan 2018 14:12:09 GMT</pubDate></item><item><title><![CDATA[Reply to Show a picture infont of everything with a button on Mon, 15 Jan 2018 16:03:14 GMT]]></title><description><![CDATA[<p dir="auto">For the first part you’re probably looking for MMM-Button: <a href="https://github.com/PtrBld/MMM-Button" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/PtrBld/MMM-Button</a><br />
And I think there are several modules to show an image.</p>
]]></description><link>https://forum.magicmirror.builders/post/34010</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/34010</guid><dc:creator><![CDATA[doubleT]]></dc:creator><pubDate>Mon, 15 Jan 2018 16:03:14 GMT</pubDate></item></channel></rss>
