<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Getting the MagicMirror full-screen resolution]]></title><description><![CDATA[<p dir="auto">Hi!</p>
<p dir="auto">Total noob here, trying to set up the interface for MagicMirror. So far everything has been pretty straightforward, except for one problem:</p>
<p dir="auto">The resolution doesn’t really go full-size. Check out this Image:<br />
<img src="/assets/uploads/files/1516030595761-snapchat-1441988271.jpg" alt="0_1516030593357_Snapchat-1441988271.jpg" class="img-markdown  img-fluid" /></p>
<p dir="auto">Its fit correctly to the left and bottom size, but top and right are not being used. I set the MM css to white background to demonstrate what it looks like in the picture</p>
<p dir="auto">I’ve been playing around with boot/config and trying different overscan options, and disabling overscan but i’m not really sure this is the issue at all… ?</p>
<p dir="auto">The monitor is an LG W2040s and according to the TVService the preferred hdmi mode was 83 (which im running in the boot/config)</p>
<p dir="auto">The monitor is running VGA to HDMI (Via adapter), and i had to force HDMI to boost 11 to remove some flickering (monitor turning on and off after a while) as well…</p>
<p dir="auto">Any help appreciated!</p>
<p dir="auto">Best regards,<br />
Peter</p>
]]></description><link>https://forum.magicmirror.builders/topic/6237/getting-the-magicmirror-full-screen-resolution</link><generator>RSS for Node</generator><lastBuildDate>Wed, 07 Oct 2026 06:25:43 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/6237.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 15 Jan 2018 15:41:42 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Getting the MagicMirror full-screen resolution on Thu, 04 Apr 2019 06:44:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/petrpls" aria-label="Profile: petrpls">@<bdi>petrpls</bdi></a>  I know this is old but did you ever find a solution?</p>
<p dir="auto">Looking at the config you posted…it looks like you have removed the # signs to uncomment you code?</p>
]]></description><link>https://forum.magicmirror.builders/post/55394</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/55394</guid><dc:creator><![CDATA[dxfan227]]></dc:creator><pubDate>Thu, 04 Apr 2019 06:44:46 GMT</pubDate></item><item><title><![CDATA[Reply to Getting the MagicMirror full-screen resolution on Mon, 15 Jan 2018 17:26:35 GMT]]></title><description><![CDATA[<p dir="auto">Otherwise first connect directly via HDMI and see what kind of image this gives.</p>
]]></description><link>https://forum.magicmirror.builders/post/34023</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/34023</guid><dc:creator><![CDATA[pjkoeleman]]></dc:creator><pubDate>Mon, 15 Jan 2018 17:26:35 GMT</pubDate></item><item><title><![CDATA[Reply to Getting the MagicMirror full-screen resolution on Mon, 15 Jan 2018 16:56:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cruunnerr" aria-label="Profile: cruunnerr">@<bdi>cruunnerr</bdi></a> said in <a href="/post/34015">Getting the MagicMirror full-screen resolution</a>:</p>
<p dir="auto">have u tried <code>sudo raspi-config</code> ?<br />
Go to advanced and then to resolution.</p>
<p dir="auto">I tried but it didnt make a difference… i guess its like setting the mode and stuff in the boot/config but through the interface instead ? :|</p>
]]></description><link>https://forum.magicmirror.builders/post/34018</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/34018</guid><dc:creator><![CDATA[petrpls]]></dc:creator><pubDate>Mon, 15 Jan 2018 16:56:43 GMT</pubDate></item><item><title><![CDATA[Reply to Getting the MagicMirror full-screen resolution on Mon, 15 Jan 2018 16:54:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/doublet" aria-label="Profile: doubleT">@<bdi>doubleT</bdi></a> said in <a href="/post/34014">Getting the MagicMirror full-screen resolution</a>:</p>
<blockquote></blockquote>
<p dir="auto">There’s just one option for “resolution” on the physical monitor settings, and that is to move the “frame”. i.e i can make the white drawed surface move around, but i can’t reduce the black frame…  :(</p>
]]></description><link>https://forum.magicmirror.builders/post/34016</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/34016</guid><dc:creator><![CDATA[petrpls]]></dc:creator><pubDate>Mon, 15 Jan 2018 16:54:26 GMT</pubDate></item><item><title><![CDATA[Reply to Getting the MagicMirror full-screen resolution on Mon, 15 Jan 2018 16:49:09 GMT]]></title><description><![CDATA[<p dir="auto">have u tried <code>sudo raspi-config</code> ?<br />
]]></description><link>https://forum.magicmirror.builders/post/34015</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/34015</guid><dc:creator><![CDATA[cruunnerr]]></dc:creator><pubDate>Mon, 15 Jan 2018 16:49:09 GMT</pubDate></item><item><title><![CDATA[Reply to Getting the MagicMirror full-screen resolution on Mon, 15 Jan 2018 16:48:02 GMT]]></title><description><![CDATA[<p dir="auto">Does your monitor itself allow adjustment?</p>
]]></description><link>https://forum.magicmirror.builders/post/34014</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/34014</guid><dc:creator><![CDATA[doubleT]]></dc:creator><pubDate>Mon, 15 Jan 2018 16:48:02 GMT</pubDate></item><item><title><![CDATA[Reply to Getting the MagicMirror full-screen resolution on Mon, 15 Jan 2018 16:38:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/pjkoeleman" aria-label="Profile: pjkoeleman">@<bdi>pjkoeleman</bdi></a> I saw that forum post a while back, and tried both manually overscaning to get the black board out, and also running disable_overscan 1 but it still ends up the same. This is my current  boot/config</p>
<pre><code># uncomment if you get no picture on HDMI for a default "safe" mode
#hdmi_safe=1
# uncomment this if your display has a black border of unused pixels visible
# and your display can output without overscan
disable_overscan=1
# uncomment the following to adjust overscan. Use positive numbers if console
# goes off screen, and negative if there is too much border
#overscan_left=10
#overscan_right=-1000
#overscan_top=-512
#overscan_bottom=-256
# uncomment to force a console size. By default it will be display's size minus
# overscan.
#framebuffer_width=1280
#framebuffer_height=720
# uncomment if hdmi display is not detected and composite is being output
#hdmi_force_hotplug=1
# uncomment to force a specific HDMI mode (this will force VGA)
hdmi_group=1
hdmi_mode=83
# uncomment to force a HDMI mode rather than DVI. This can make audio work in
# DMT (computer monitor) modes
#hdmi_drive=1
# uncomment to increase signal to HDMI, if you have interference, blanking, or
# no display
config_hdmi_boost=11
# uncomment for composite PAL
#sdtv_mode=2
#uncomment to overclock the arm. 700 MHz is the default.
#arm_freq=800
# Uncomment some or all of these to enable the optional hardware interfaces
#dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
# Uncomment this to enable the lirc-rpi module
#dtoverlay=lirc-rpi
# Additional overlays and parameters are documented /boot/overlays/README
# Enable audio (loads snd_bcm2835)
dtparam=audio=on
display_rotate=1
avoid_warnings=1
Any thoughts on what could be missing?
]]></description><link>https://forum.magicmirror.builders/post/34013</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/34013</guid><dc:creator><![CDATA[petrpls]]></dc:creator><pubDate>Mon, 15 Jan 2018 16:38:09 GMT</pubDate></item><item><title><![CDATA[Reply to Getting the MagicMirror full-screen resolution on Mon, 15 Jan 2018 16:13:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/petrpls" aria-label="Profile: petrpls">@<bdi>petrpls</bdi></a> said in <a href="/post/34008">Getting the MagicMirror full-screen resolution</a>:</p>
<p dir="auto">You need to edit your config file ( /boot/config.txt) see this thread for <a href="https://www.raspberrypi.org/forums/viewtopic.php?t=47152" target="_blank" rel="noopener noreferrer nofollow ugc">details</a>.</p>
]]></description><link>https://forum.magicmirror.builders/post/34012</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/34012</guid><dc:creator><![CDATA[pjkoeleman]]></dc:creator><pubDate>Mon, 15 Jan 2018 16:13:02 GMT</pubDate></item></channel></rss>
