<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Change module position]]></title><description><![CDATA[<p dir="auto">Hello,<br />
I know that  can change the position from the modul of the right to the left ,bottem.<br />
I can change them exactly px ? even if the module has no style.css.<br />
because I want to have on the left side more modules</p>
<p dir="auto">sorry for my bad English</p>
]]></description><link>https://forum.magicmirror.builders/topic/624/change-module-position</link><generator>RSS for Node</generator><lastBuildDate>Fri, 15 May 2026 07:57:18 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/624.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 14 Sep 2016 10:28:18 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Change module position on Mon, 08 Jul 2019 07:34:04 GMT]]></title><description><![CDATA[<p dir="auto">@strawberry-3-141 I tried putting this into cutstom.css and changing the left and right px . But nothing happened . I want to shift my clock to the right a little for alignment . Is there anything I’m doing wrong ? Thank you .</p>
]]></description><link>https://forum.magicmirror.builders/post/58688</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/58688</guid><dc:creator><![CDATA[Legendary_Wiz]]></dc:creator><pubDate>Mon, 08 Jul 2019 07:34:04 GMT</pubDate></item><item><title><![CDATA[Reply to Change module position on Fri, 16 Sep 2016 13:45:21 GMT]]></title><description><![CDATA[<p dir="auto">sorry I couldn’t get your question</p>
]]></description><link>https://forum.magicmirror.builders/post/4889</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/4889</guid><dc:creator><![CDATA[strawberry 3.141]]></dc:creator><pubDate>Fri, 16 Sep 2016 13:45:21 GMT</pubDate></item><item><title><![CDATA[Reply to Change module position on Thu, 15 Sep 2016 09:07:49 GMT]]></title><description><![CDATA[<p dir="auto">Thank you for your help!! language I could change only in what config I make the position of the modules</p>
]]></description><link>https://forum.magicmirror.builders/post/4832</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/4832</guid><dc:creator><![CDATA[samydp]]></dc:creator><pubDate>Thu, 15 Sep 2016 09:07:49 GMT</pubDate></item><item><title><![CDATA[Reply to Change module position on Wed, 14 Sep 2016 14:54:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/samydp" aria-label="Profile: samydp">@<bdi>samydp</bdi></a> the module name is case sensitive so you have to write it like in the config file e.g. in your case it would be <code>.clock</code></p>
<pre><code>.clock{
  left : 100 px,
  top:50 px
<p dir="auto">also think about using <code>position</code> with the values <code>fixed, absolute or relative</code></p>
]]></description><link>https://forum.magicmirror.builders/post/4784</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/4784</guid><dc:creator><![CDATA[strawberry 3.141]]></dc:creator><pubDate>Wed, 14 Sep 2016 14:54:01 GMT</pubDate></item><item><title><![CDATA[Reply to Change module position on Wed, 14 Sep 2016 14:46:08 GMT]]></title><description><![CDATA[<p dir="auto">Perfekt:)<br />
can i with the help of .modulname in the Main chance the position of the individual modules?<br />
For example:</p>
<p dir="auto">.Clock (Modul Name)<br />
Left : 100 px,<br />
Top:50 px</p>
]]></description><link>https://forum.magicmirror.builders/post/4783</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/4783</guid><dc:creator><![CDATA[samydp]]></dc:creator><pubDate>Wed, 14 Sep 2016 14:46:08 GMT</pubDate></item><item><title><![CDATA[Reply to Change module position on Wed, 14 Sep 2016 13:22:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/samydp" aria-label="Profile: samydp">@<bdi>samydp</bdi></a> you don’t need to link the custom.css file it’s already working with the content in this file</p>
<p dir="auto">of course you can change the font as well</p>
]]></description><link>https://forum.magicmirror.builders/post/4781</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/4781</guid><dc:creator><![CDATA[strawberry 3.141]]></dc:creator><pubDate>Wed, 14 Sep 2016 13:22:08 GMT</pubDate></item><item><title><![CDATA[Reply to Change module position on Wed, 14 Sep 2016 13:13:31 GMT]]></title><description><![CDATA[<p dir="auto">perfect! how do I link the file created in the config? I can also change the font?</p>
]]></description><link>https://forum.magicmirror.builders/post/4780</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/4780</guid><dc:creator><![CDATA[samydp]]></dc:creator><pubDate>Wed, 14 Sep 2016 13:13:31 GMT</pubDate></item><item><title><![CDATA[Reply to Change module position on Wed, 14 Sep 2016 10:54:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/samydp" aria-label="Profile: samydp">@<bdi>samydp</bdi></a> those are all valid positions you can enter in the config.js <a href="https://forum.magicmirror.builders/topic/286/regions">https://forum.magicmirror.builders/topic/286/regions</a></p>
<p dir="auto">however you can make your custom layout in <code>~/MagicMirror/css/custom.css</code></p>
]]></description><link>https://forum.magicmirror.builders/post/4776</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/4776</guid><dc:creator><![CDATA[strawberry 3.141]]></dc:creator><pubDate>Wed, 14 Sep 2016 10:54:37 GMT</pubDate></item></channel></rss>
