<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[I messed up]]></title><description><![CDATA[<p dir="auto">reloaded sd card, loaded MM, and clicked to use auto start during set up, now I cant get to pi gui to make any changes, it just starts mm full screen. How do I change it so I start it if i cant get behind it? only vnc is set on.</p>
]]></description><link>https://forum.magicmirror.builders/topic/6242/i-messed-up</link><generator>RSS for Node</generator><lastBuildDate>Thu, 08 Oct 2026 07:59:12 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/6242.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 16 Jan 2018 00:25:09 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to I messed up on Tue, 16 Jan 2018 12:22:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cruunnerr" aria-label="Profile: cruunnerr">@<bdi>cruunnerr</bdi></a> said in <a href="/post/34052">I messed up</a>:</p>
<p dir="auto">i think the process of pm2 is called MagicMirror</p>
<p dir="auto">Ahhh, thanks for putting me straight. I don’t do automatic installations anymore. I’ve only installed PM2 manually and use the commands that I stated.  Good catch <a class="plugin-mentions-user plugin-mentions-a" href="/user/cruunnerr" aria-label="Profile: cruunnerr">@<bdi>cruunnerr</bdi></a>! :-)</p>
]]></description><link>https://forum.magicmirror.builders/post/34062</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/34062</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Tue, 16 Jan 2018 12:22:14 GMT</pubDate></item><item><title><![CDATA[Reply to I messed up on Tue, 16 Jan 2018 05:36:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cruunnerr" aria-label="Profile: cruunnerr">@<bdi>cruunnerr</bdi></a> thanks that did what I wanted</p>
]]></description><link>https://forum.magicmirror.builders/post/34053</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/34053</guid><dc:creator><![CDATA[navyvette87]]></dc:creator><pubDate>Tue, 16 Jan 2018 05:36:58 GMT</pubDate></item><item><title><![CDATA[Reply to I messed up on Tue, 16 Jan 2018 04:28:39 GMT]]></title><description><![CDATA[<p dir="auto">Please correct me if i am wrong.</p>
<p dir="auto">What Mykle1 said is right. Have u used the automatic installer and said “YES” when it asked u too start automatically i think the process of pm2 is called MagicMirror. So the commands should be:</p>
<p dir="auto"><code>pm2 stop MagicMirror</code><br />
<code>pm2 start MagicMirror</code><br />
<code>pm2 save MagicMirror</code> (to save the current status (on or off))</p>
]]></description><link>https://forum.magicmirror.builders/post/34052</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/34052</guid><dc:creator><![CDATA[cruunnerr]]></dc:creator><pubDate>Tue, 16 Jan 2018 04:28:39 GMT</pubDate></item><item><title><![CDATA[Reply to I messed up on Tue, 16 Jan 2018 01:24:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/navyvette87" aria-label="Profile: navyvette87">@<bdi>navyvette87</bdi></a></p>
<p dir="auto">Press your <code>Alt</code> key. This will drop a menu bar at the top. Minimize MM there and type <code>pm2 stop mm</code> in your terminal to stop the mirror. <code>pm2 start mm</code> will start your mirror when you are ready</p>
]]></description><link>https://forum.magicmirror.builders/post/34046</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/34046</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Tue, 16 Jan 2018 01:24:43 GMT</pubDate></item></channel></rss>
