<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[What module or turorial did you use to manage getting iCloud data?]]></title><description><![CDATA[<p dir="auto">Re: <a href="/topic/2037/default-calendar-icloud-calendar-description">Default Calendar - iCloud Calendar description</a></p>
<p dir="auto">Hi am a bit curious,</p>
<p dir="auto">which moduler or tutorial did you use to manage getting iCloud calendar content?</p>
]]></description><link>https://forum.magicmirror.builders/topic/6252/what-module-or-turorial-did-you-use-to-manage-getting-icloud-data</link><generator>RSS for Node</generator><lastBuildDate>Fri, 12 Jun 2026 08:32:27 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/6252.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 16 Jan 2018 19:26:24 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to What module or turorial did you use to manage getting iCloud data? on Tue, 16 Jan 2018 21:47:24 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/user/gailby" aria-label="Profile: Gailby">@<bdi>Gailby</bdi></a> – check out <a class="plugin-mentions-user plugin-mentions-a" href="/user/beh" aria-label="Profile: Beh">@<bdi>Beh</bdi></a>’s <a href="https://forum.magicmirror.builders/topic/5327/sync-private-icloud-calendar-with-magicmirror">post</a>. It’s a very very detailed walkthrough. That method syncs/downloads your iCloud calendar locally and then displays it with the Calendar module (although you could use any module that supports iCal).</p>
]]></description><link>https://forum.magicmirror.builders/post/34095</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/34095</guid><dc:creator><![CDATA[ninjabreadman]]></dc:creator><pubDate>Tue, 16 Jan 2018 21:47:24 GMT</pubDate></item></channel></rss>
