<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-OpenhabFloorplan]]></title><description><![CDATA[<p dir="auto">A magic mirror is the ideal place for showing the state of lights, window contacts, and other labels from <a href="http://www.openhab.org/" target="_blank" rel="noopener noreferrer nofollow ugc">openhab</a> on a floorplan of your house / apartment! I already <a href="https://paphko.blogspot.de/2016/01/magic-mirror-openhab.html" target="_blank" rel="noopener noreferrer nofollow ugc">implemented this</a> inside main.js of the old version of the magic mirror, but this does not work with MM2. So I re-implemented the entire module to be properly configurable and with push events via http requests instead of polling. This way, state changes of lights / window contacts / labels are immediately updated on the magic mirror :-)</p>
<p dir="auto">To comfort configuration of the module, there is a <strong>draft mode</strong> which shows all configured items:</p>
<p dir="auto"><img src="/uploads/files/1473878318469-openhabfloorplan-draft-resized.png" alt="0_1473878320905_openhabfloorplan-draft.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">In regular mode, lights are only shown if they are switched on, window and door contacts are only shown if they are open, and labels are shown with their actual contents.</p>
<p dir="auto"><img src="/uploads/files/1473878353822-openhabfloorplan-running-resized.png" alt="0_1473878356074_openhabfloorplan-running.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Labels can actually be configured for any item, for example:</p>
<ul>
<li>Currently played title from <a href="https://github.com/openhab/openhab/wiki/Sonos-Binding" target="_blank" rel="noopener noreferrer nofollow ugc">sonos speaker</a> or another <a href="https://github.com/openhab/openhab/wiki/Frontier-Silicon-Radio-Binding" target="_blank" rel="noopener noreferrer nofollow ugc">internet radio</a></li>
<li>Current channel on your <a href="https://github.com/openhab/openhab/wiki/Lg-TV" target="_blank" rel="noopener noreferrer nofollow ugc">LG</a>, <a href="https://github.com/openhab/openhab/wiki/Samsung-TV-Binding" target="_blank" rel="noopener noreferrer nofollow ugc">Samsung</a>, or <a href="https://github.com/openhab/openhab/wiki/Panasonic-TV-Binding" target="_blank" rel="noopener noreferrer nofollow ugc">Panasonic</a> TV</li>
<li>Fan speed of your <a href="https://github.com/openhab/openhab/wiki/Swegon-Ventilation-Binding" target="_blank" rel="noopener noreferrer nofollow ugc">Swegon ventilation system</a></li>
<li>Current state of your <a href="https://github.com/openhab/openhab/wiki/URTSI-Binding" target="_blank" rel="noopener noreferrer nofollow ugc">Somfy Rollershutters</a></li>
<li>Basically each item which is fed by an openhab binding</li>
</ul>
<p dir="auto">Check out the <a href="https://github.com/paphko/mmm-openhabfloorplan" target="_blank" rel="noopener noreferrer nofollow ugc">module page</a> for instructions how to set up your individual floorplan.<br />
Please vote this topic up, if you installed and enjoy this module :-)</p>
]]></description><link>https://forum.magicmirror.builders/topic/627/mmm-openhabfloorplan</link><generator>RSS for Node</generator><lastBuildDate>Tue, 16 Jun 2026 09:48:56 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/627.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 14 Sep 2016 18:43:30 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-OpenhabFloorplan on Sat, 14 Dec 2019 09:48:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/teddy" aria-label="Profile: teddy">@<bdi>teddy</bdi></a>  Sorry for the late reply, I didn’t check the forum for quite a while. But from your post, I don’t know how to help. It’s as if you say “my car is not working, what am I doing wrong?”<br />
If you want some help, please check logs for errors and post them here.</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/zdenek" aria-label="Profile: zdenek">@<bdi>zdenek</bdi></a>  It should be possible to run openhab on the same RPi. I didn’t try it but I don’t see any reason why it should not work. You only have to change the port of one of them because both use 8080 by default.</p>
]]></description><link>https://forum.magicmirror.builders/post/66006</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/66006</guid><dc:creator><![CDATA[paphko]]></dc:creator><pubDate>Sat, 14 Dec 2019 09:48:56 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-OpenhabFloorplan on Mon, 18 Nov 2019 06:03:02 GMT]]></title><description><![CDATA[<p dir="auto">Hi all<br />
sorry for stupid question - do I need to have another RPi to run OpenHAB, or it can by on the same?</p>
<p dir="auto">thanks Zdeněk</p>
]]></description><link>https://forum.magicmirror.builders/post/64638</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/64638</guid><dc:creator><![CDATA[zdenek]]></dc:creator><pubDate>Mon, 18 Nov 2019 06:03:02 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-OpenhabFloorplan on Sat, 18 Aug 2018 11:30:53 GMT]]></title><description><![CDATA[<p dir="auto">Hi, I have problems and need help. What am I doing wrong?</p>
<p dir="auto"><img src="https://image.ibb.co/jWYFTK/1.png" alt="alt text" class=" img-fluid img-markdown" /><br />
<img src="https://image.ibb.co/hg2naz/2.png" alt="alt text" class=" img-fluid img-markdown" /><br />
<img src="https://image.ibb.co/dOjdhe/3.png" alt="alt text" class=" img-fluid img-markdown" /><br />
<img src="https://image.ibb.co/hOhnaz/4.png" alt="alt text" class=" img-fluid img-markdown" /><br />
<img src="https://image.ibb.co/dekjNe/5.png" alt="alt text" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/43547</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/43547</guid><dc:creator><![CDATA[teddy]]></dc:creator><pubDate>Sat, 18 Aug 2018 11:30:53 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-OpenhabFloorplan on Thu, 16 Mar 2017 20:46:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/paphko" aria-label="Profile: paphko">@<bdi>paphko</bdi></a> With you Update everything works as expected!!!</p>
<p dir="auto"><img src="/assets/uploads/files/1489697108303-upload-3fa13796-8258-4888-8ea9-97ce6d72d95f.png" alt="0_1489697104040_upload-3fa13796-8258-4888-8ea9-97ce6d72d95f" class=" img-fluid img-markdown" /></p>
<p dir="auto">Again, thank you very much for your help and the effort you put in your module!<br />
:grinning:<br />
Best regards<br />
Schummi</p>
]]></description><link>https://forum.magicmirror.builders/post/17636</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/17636</guid><dc:creator><![CDATA[schummi84]]></dc:creator><pubDate>Thu, 16 Mar 2017 20:46:46 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-OpenhabFloorplan on Thu, 16 Mar 2017 19:57:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/paphko" aria-label="Profile: paphko">@<bdi>paphko</bdi></a> Thank you very much for your effort. I’ll give it a try and report on the outcome!</p>
]]></description><link>https://forum.magicmirror.builders/post/17634</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/17634</guid><dc:creator><![CDATA[schummi84]]></dc:creator><pubDate>Thu, 16 Mar 2017 19:57:20 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-OpenhabFloorplan on Thu, 16 Mar 2017 13:13:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/schummi84" aria-label="Profile: schummi84">@<bdi>schummi84</bdi></a> <a class="plugin-mentions-user plugin-mentions-a" href="/user/yourhighnessleender" aria-label="Profile: YourhighnessLeender">@<bdi>YourhighnessLeender</bdi></a> : OH2 has a slightly different JSON format in items response which I had to deal with. Please pull latest changes, set new ‘version’ option is your config, and try again.</p>
]]></description><link>https://forum.magicmirror.builders/post/17587</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/17587</guid><dc:creator><![CDATA[paphko]]></dc:creator><pubDate>Thu, 16 Mar 2017 13:13:21 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-OpenhabFloorplan on Thu, 09 Mar 2017 11:26:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/schummi84" aria-label="Profile: schummi84">@<bdi>schummi84</bdi></a> I’ll test that as soon as I find some time - maybe tomorrow, maybe next week.</p>
]]></description><link>https://forum.magicmirror.builders/post/16910</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/16910</guid><dc:creator><![CDATA[paphko]]></dc:creator><pubDate>Thu, 09 Mar 2017 11:26:31 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-OpenhabFloorplan on Wed, 08 Mar 2017 19:14:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/paphko" aria-label="Profile: paphko">@<bdi>paphko</bdi></a> I tried you hint with the following result:</p>
<pre><code>[{"link":"http://192.168.2.122:8080/rest/items/ExtendedColorLight_Color","state":"ON","type":"Switch","name":"ExtendedColorLight_Color","label":"Color","category":"ColorLight","tags":[],"groupNames":[]},{"link":"http://192.168.2.122:8080/rest/items/SOFA_Switch","state":"ON","type":"Switch","name":"SOFA_Switch","label":"Color","category":"ColorLight","tags":[],"groupNames":[]},{"link":"http://192.168.2.122:8080/rest/items/SOFA_Color","state":"274,87,24","type":"Color","name":"SOFA_Color","label":"Color","category":"ColorLight","tags":[],"groupNames":[]},{"link":"http://192.168.2.122:8080/rest/items/SOFA_ColorTemperature","state":"0","type":"Dimmer","name":"SOFA_ColorTemperature","label":"Color Temperature","category":"ColorLight","tags":[],"groupNames":[]}]
<p dir="auto">Basically it shows two items at the moment, both created with PaperUI. I still don’t undertsand why the file based setup/configuration is not working. I wouldn’t mind if th efloorplan integration would work but still doesn’t. I added the two items to the config.js but without success. I checked the pm2 logs to see the follwoing error:</p>
<pre><code>0|mm       | TypeError: Cannot read property 'statusCode' of undefined
0|mm       |     at Request._callback (/home/pi/MagicMirror/modules/mmm-openhabfloorplan/node_helper.js:38:65)
0|mm       |     at self.callback (/home/pi/MagicMirror/node_modules/request/request.js:186:22)
0|mm       |     at emitOne (events.js:96:13)
0|mm       |     at Request.emit (events.js:188:7)
0|mm       |     at Request.onRequestError (/home/pi/MagicMirror/node_modules/request/request.js:845:8)
0|mm       |     at ClientRequest.emit (events.js:188:7)
0|mm       |     at Socket.socketErrorListener (_http_client.js:308:9)
0|mm       |     at Socket.emit (events.js:188:7)
<p dir="auto">Note: I already modified the mmm-openhabfloorplan.js according to your other thread. Unfortunatelly I cannot attach the files here - If required I can post the sourcecode.</p>
<p dir="auto">Any idea ?</p>
<p dir="auto">Cheers<br />
Schummi</p>
]]></description><link>https://forum.magicmirror.builders/post/16849</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/16849</guid><dc:creator><![CDATA[schummi84]]></dc:creator><pubDate>Wed, 08 Mar 2017 19:14:29 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-OpenhabFloorplan on Wed, 08 Mar 2017 09:57:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/paphko" aria-label="Profile: paphko">@<bdi>paphko</bdi></a> thanks for the hint. I will try it this afternoon and come back with the result.</p>
]]></description><link>https://forum.magicmirror.builders/post/16802</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/16802</guid><dc:creator><![CDATA[schummi84]]></dc:creator><pubDate>Wed, 08 Mar 2017 09:57:14 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-OpenhabFloorplan on Wed, 08 Mar 2017 09:50:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/schummi84" aria-label="Profile: schummi84">@<bdi>schummi84</bdi></a> Please open <a href="http://192.168.2.122:8080/rest/items" target="_blank" rel="noopener noreferrer nofollow ugc">http://192.168.2.122:8080/rest/items</a> to get a (huge) list of all items that are available via the REST API. I realized that items that are automatically created via the Paper UI get an auto-generated name. However, you should be able to find them in the huge list of all items by searching the item labels.</p>
<p dir="auto">For example, the Paper UI created yahoo weather item ‘Luftfeuchtigkeit’ has item name ‘yahooweather_weather_berlin_humidity’ on my setup. Then the item URL for such an item would be: <a href="http://192.168.2.122:8080/rest/items/yahooweather_weather_berlin_humidity" target="_blank" rel="noopener noreferrer nofollow ugc">http://192.168.2.122:8080/rest/items/yahooweather_weather_berlin_humidity</a></p>
]]></description><link>https://forum.magicmirror.builders/post/16801</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/16801</guid><dc:creator><![CDATA[paphko]]></dc:creator><pubDate>Wed, 08 Mar 2017 09:50:25 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-OpenhabFloorplan on Wed, 08 Mar 2017 05:21:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/schummi84" aria-label="Profile: schummi84">@<bdi>schummi84</bdi></a> that sounds strange, it seems as if the rest api does not cover all items. I’ll try to check that as soon as I find some time.</p>
]]></description><link>https://forum.magicmirror.builders/post/16788</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/16788</guid><dc:creator><![CDATA[paphko]]></dc:creator><pubDate>Wed, 08 Mar 2017 05:21:56 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-OpenhabFloorplan on Tue, 07 Mar 2017 22:45:47 GMT]]></title><description><![CDATA[<p dir="auto">Update:<br />
I reinstalled a clean Jessie on the Raspi and installed Openhab according to the guide on the <a href="http://openhab.org" target="_blank" rel="noopener noreferrer nofollow ugc">openhab.org</a> homepage.</p>
<p dir="auto">This time I did not install anything via PAPERUI besides the HUE Binding. I copied my item/things/sitemap files as described above to the openhab2 folder.</p>
<p dir="auto">Checking  the PAPERUI on localhost:8080 shows that the the bridge and lights get listet under the THINGS menue but no items appear.</p>
<p dir="auto"><img src="/assets/uploads/files/1488926336776-upload-bc388935-db4b-4b31-901d-393cb3c8b713.png" alt="0_1488926336055_upload-bc388935-db4b-4b31-901d-393cb3c8b713" class=" img-fluid img-markdown" /></p>
<p dir="auto">When I link one of the lights with a “new item” I can see the item  but with a confusing name. I can control it with openhab though.</p>
<p dir="auto"><img src="/assets/uploads/files/1488926550497-upload-a216e794-f0f5-41b8-94ab-0feab73b19f4.png" alt="0_1488926552608_upload-a216e794-f0f5-41b8-94ab-0feab73b19f4" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="/assets/uploads/files/1488926413700-upload-c030bbb8-5768-4e81-a523-4f5d29102265.png" alt="0_1488926411068_upload-c030bbb8-5768-4e81-a523-4f5d29102265" class=" img-fluid img-markdown" /></p>
<p dir="auto">Your hint with checking the status in the browser just gives me this:</p>
<pre><code>{
http://192.168.2.122:8080/rest/items/L_HUE_STRIP_Toggle
 "error": {
    "message": "Item L_HUE_STRIP_Toggle does not exist!",
    "http-code": 404
<p dir="auto">Accordingly in the Magicmirror no connection is made.</p>
<p dir="auto">Is this a basic OpenHab setup or configuration error?</p>
<p dir="auto">Note: trying to change the name of the item manually resutls in a “conflict error”</p>
<p dir="auto">Sorry for the long post. Any help is appreciated!</p>
Schummi</p>
]]></description><link>https://forum.magicmirror.builders/post/16766</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/16766</guid><dc:creator><![CDATA[schummi84]]></dc:creator><pubDate>Tue, 07 Mar 2017 22:45:47 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-OpenhabFloorplan on Mon, 06 Mar 2017 21:13:43 GMT]]></title><description><![CDATA[<p dir="auto">As additional Information here my OpenHab configuration:</p>
<pre><code>lights.things
Bridge hue:bridge:1 [ ipAddress="192.168.2.100" ]
	0100	L_HUE_BEDROOM_WHITE_Toggle 	[ lightId="1" ]
	0210	L_HUE_BEDROOM_COLOR_Toggle 	[ lightId="2" ]
	0210	L_HUE_STRIP_Toggle 		[ lightId="3" ]
	0210	L_HUE_WZ-MITTE_Toggle 		[ lightId="4" ]
	0210	L_HUE_ZELT_Toggle 		[ lightId="5" ]
	0200	L_HUE_IRIS_Toggle		[ lightId="6" ]
	0210	L_HUE_SOFA_Toggle 		[ lightId="7" ]
	0210	L_HUE_ESSECKE_Toggle 		[ lightId="8" ]
	0100	L_HUE_ESSTISCH_Toggle 		[ lightId="9" ]
	0100	L_HUE_KUECHE_Toggle		[ lightId="10" ]
lights.sitemap
sitemap lights label="Main Menu"
	Frame {
		Switch item=	L_HUE_SOFA_Toggle
		Switch item=	L_HUE_STRIP_Toggle
		Switch item=	L_HUE_ZELT_Toggle
		Switch item=	L_HUE_IRIS_Toggle
		Switch item= 	L_HUE_ESSECKE_Toggle
		Switch item=	L_HUE_ESSTISCH_Toggle
		Switch item= 	L_HUE_WZ-MITTE_Toggle
		Switch item=	L_HUE_KUECHE_Toggle
		Switch item= 	L_HUE_BEDROOM_COLOR_Toggle
		Switch item= 	L_HUE_BEDROOM_WHITE_Toggle
Lights.item
//=====SWITCHES======================================
Switch 		L_HUE_BEDROOM_WHITE_Toggle 	{ channel="hue:0100:0017881c28a8:1:brightness" }
Switch 		L_HUE_BEDROOM_COLOR_Toggle 	{ channel="hue:0210:0017881c28a8:2:color" }
Switch 		L_HUE_STRIP_Toggle 		{ channel="hue:0210:0017881c28a8:3:color" }
Switch 		L_HUE_WZ-MITTE_Toggle 		{ channel="hue:0210:0017881c28a8:4:color" }
Switch 		L_HUE_ZELT_Toggle 		{ channel="hue:0210:0017881c28a8:5:color" }
Switch 		L_HUE_IRIS_Toggle 		{ channel="hue:0200:0017881c28a8:6:color" }
Switch 		L_HUE_SOFA_Toggle 		{ channel="hue:0210:0017881c28a8:7:color" }
Switch 		L_HUE_ESSECKE_Toggle 		{ channel="hue:0210:0017881c28a8:8:color" }
Switch 		L_HUE_ESSTISCH_Toggle 		{ channel="hue:0100:0017881c28a8:9:brightness" }
Switch 		L_HUE_KUECHE_Toggle 		{ channel="hue:0100:0017881c28a8:10:brightness" }
<p dir="auto">Strangly the Config via files seems not to work as the “L_ZELT” item was configured via the PAPERUI and the files are obviously ignored:</p>
<pre><code>http://192.168.2.122:8080/rest/items/L_HUE_ZELT_Toggle
<pre><code>{
  "error": {
    "message": "Item L_HUE_ZELT_Toggle does not exist!",
    "http-code": 404
<p dir="auto">I found the Openhab on the raspberry in:</p>
<pre><code>/etc/openhab2
<p dir="auto">Is this the correct location?</p>
<p dir="auto">Thanks for any help!</p>
]]></description><link>https://forum.magicmirror.builders/post/16654</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/16654</guid><dc:creator><![CDATA[schummi84]]></dc:creator><pubDate>Mon, 06 Mar 2017 21:13:43 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-OpenhabFloorplan on Mon, 06 Mar 2017 21:01:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/paphko" aria-label="Profile: paphko">@<bdi>paphko</bdi></a> When I adjust your link with one of my items I get the following result:</p>
<pre><code>{
  "link": "http://192.168.2.122:8080/rest/items/L_ZELT",
  "state": "ON",
  "type": "Switch",
  "name": "L_ZELT",
  "label": "Switch_Zelt",
  "category": "Light",
  "tags": [],
  "groupNames": []
<p dir="auto">Adding the Light in the config.js is still not working.</p>
<p dir="auto">Here the config code:</p>
<pre><code>	//------------- OPENHAB FLOORPLAN ----------------------------------------------------------
        module: 'mmm-openhabfloorplan',
        position: 'bottom_center', // this can be any of the regions
            updateInterval: 60 * 60 * 1000, // refreshing all windows / lights / labels once per hour; 0 to disable periodic update
            draft: false, // if true, all lights, windows, and label names are shown; if false, get states from openhab
            openhab: {
                url: "http://localhost:8080", // must not have a trailing slash!
            floorplan: {
                image: "egog2.png", // image in subfolder 'images'; change to floorplan.png to avoid git repository changes
                width: 800, // this must be the width of the image above
                height: 333, // this must be the height of the image above
             light: { // this part shows default settings for lights; may optionally be overwritten
              image: "light.png", // located in subfolder 'images'
              width: 19, // image width
              height: 19, // image height
   		lights: { // list all light items to be shown (must be of openhab type Switch or Dimmer)
		//=== ERDGESCHOSS ================
		L_ZELT: {left:200, top:05},
//ALTERNATIVEITEM CODE
L_ZELT_Toggle: {left:200, top:05},
            windows: { // list all window / door contacts to be shown (must be of openhab type Switch or Contact)
                // openhab item: left, top, radius (draws quadrant), midPoint, and optionally counterwindow and color
                // Reed_Sleeping_right: { left: 12,  top: 231, radius: 30, midPoint: "top-left" },
                // openhab item: left, top, width, height (draws rectangle), and optionally color
                // Reed_Sleeping_left:  { left: 90,  top: 301, width: 37, height: 20 },
            labels: { // list all strings to be shown (may probably be any openhab type, resonable for String and Number)
                // openhab item: left, top, and optionally color, font size, prefix, postfix, and number of decimals for floating numbers
                //Temperature_Entry:          { left: 162, top: 280 },
                //Temperature_Bath:           { left: 277, top: 280, postfix: "°C", decimals: 1 },
<p dir="auto">Configuring the module as draft shows all configured lights correctly.</p>
<p dir="auto">Is there anything I am missing?</p>
]]></description><link>https://forum.magicmirror.builders/post/16652</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/16652</guid><dc:creator><![CDATA[schummi84]]></dc:creator><pubDate>Mon, 06 Mar 2017 21:01:37 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-OpenhabFloorplan on Thu, 02 Mar 2017 12:49:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/schummi84" aria-label="Profile: schummi84">@<bdi>schummi84</bdi></a> Please make sure your openhab installation has the <a href="http://docs.openhab.org/configuration/restdocs.html" target="_blank" rel="noopener noreferrer nofollow ugc">REST API</a> installed/enabled. You can check that in a browser, e.g.: <a href="http://localhost:8080/rest/items/Light_Garden_Garage" target="_blank" rel="noopener noreferrer nofollow ugc">http://localhost:8080/rest/items/Light_Garden_Garage</a><br />
The result should be similar to this:</p>
<pre><code>{
  "link": "http://localhost:8080/rest/items/Light_Garden_Garage",
  "state": "OFF",
  "type": "Switch",
  "name": "Light_Garden_Garage",
  "label": "Garage",
  "tags": [
    "Lighting"
  "groupNames": [
    "Garden",
    "Lights"
<p dir="auto">Does that work for you? If so, please write the URL of one of your items.</p>
]]></description><link>https://forum.magicmirror.builders/post/16282</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/16282</guid><dc:creator><![CDATA[paphko]]></dc:creator><pubDate>Thu, 02 Mar 2017 12:49:16 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-OpenhabFloorplan on Wed, 01 Mar 2017 05:31:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/schummi84" aria-label="Profile: schummi84">@<bdi>schummi84</bdi></a> did you try the adjustments explained in this issue? <a href="https://github.com/paphko/mmm-openhabfloorplan/issues/1" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/paphko/mmm-openhabfloorplan/issues/1</a></p>
]]></description><link>https://forum.magicmirror.builders/post/16179</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/16179</guid><dc:creator><![CDATA[paphko]]></dc:creator><pubDate>Wed, 01 Mar 2017 05:31:55 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-OpenhabFloorplan on Tue, 28 Feb 2017 22:05:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/yourhighnessleender" aria-label="Profile: YourhighnessLeender">@<bdi>YourhighnessLeender</bdi></a><br />
Having the same issue here with OpenHab2 running on a seperate Pi. I am using Philipps Hue and can control the lights via OpenHab but I cannot get the states with the Magic Mirror.</p>
<p dir="auto">Anyone have any suggestions?</p>
]]></description><link>https://forum.magicmirror.builders/post/16138</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/16138</guid><dc:creator><![CDATA[schummi84]]></dc:creator><pubDate>Tue, 28 Feb 2017 22:05:51 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-OpenhabFloorplan on Tue, 24 Jan 2017 14:49:00 GMT]]></title><description><![CDATA[<p dir="auto">Hola! Anyone got the floor plan working with openHab2? I’m so close, but can’t seem to get any statuses from openHab (I think). I’m sort of a noob so I might be doing something wrong.</p>
]]></description><link>https://forum.magicmirror.builders/post/12319</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/12319</guid><dc:creator><![CDATA[YourhighnessLeender]]></dc:creator><pubDate>Tue, 24 Jan 2017 14:49:00 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-OpenhabFloorplan on Tue, 20 Sep 2016 10:10:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/shashank" aria-label="Profile: shashank">@<bdi>shashank</bdi></a> If you get the light states in openhab, then yes. But I don’t have any experience with Zwave devices on openhab, I would suggest to research in the openhab community and ask there how to set it up: <a href="https://community.openhab.org" target="_blank" rel="noopener noreferrer nofollow ugc">https://community.openhab.org</a></p>
]]></description><link>https://forum.magicmirror.builders/post/5077</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/5077</guid><dc:creator><![CDATA[paphko]]></dc:creator><pubDate>Tue, 20 Sep 2016 10:10:04 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-OpenhabFloorplan on Tue, 20 Sep 2016 03:28:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/paphko" aria-label="Profile: paphko">@<bdi>paphko</bdi></a> I have Vera Edge Zwave home automation installed in my house, any possibility to get the information of the lights Status on the Mirror.</p>
]]></description><link>https://forum.magicmirror.builders/post/5068</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/5068</guid><dc:creator><![CDATA[shashank]]></dc:creator><pubDate>Tue, 20 Sep 2016 03:28:37 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-OpenhabFloorplan on Thu, 15 Sep 2016 08:23:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mitchfarino" aria-label="Profile: Mitchfarino">@<bdi>Mitchfarino</bdi></a> said in <a href="/post/4829">MMM-OpenhabFloorplan</a>:</p>
<p dir="auto">I’ve not really looked at openhab - what do you have in your current set up?</p>
<p dir="auto">I use <a href="https://github.com/openhab/openhab/wiki/Anel-Binding" target="_blank" rel="noopener noreferrer nofollow ugc">Anel</a> and <a href="https://github.com/openhab/openhab/wiki/Milight-Binding" target="_blank" rel="noopener noreferrer nofollow ugc">MiLight</a> for the lights, <a href="https://github.com/openhab/openhab/wiki/One-Wire-Binding" target="_blank" rel="noopener noreferrer nofollow ugc">OneWire</a> for temperatures, and a shell script for setting reed contacts via <a href="https://github.com/openhab/openhab/wiki/REST-API" target="_blank" rel="noopener noreferrer nofollow ugc">REST API</a>.</p>
]]></description><link>https://forum.magicmirror.builders/post/4830</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/4830</guid><dc:creator><![CDATA[paphko]]></dc:creator><pubDate>Thu, 15 Sep 2016 08:23:34 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-OpenhabFloorplan on Thu, 15 Sep 2016 07:57:48 GMT]]></title><description><![CDATA[<p dir="auto">This is incredible!</p>
<p dir="auto">I really like this module though</p>
]]></description><link>https://forum.magicmirror.builders/post/4829</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/4829</guid><dc:creator><![CDATA[Mitchfarino]]></dc:creator><pubDate>Thu, 15 Sep 2016 07:57:48 GMT</pubDate></item></channel></rss>
