<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Rpi3 freezes after a few houres]]></title><description><![CDATA[<p dir="auto">Hi there,</p>
<p dir="auto">I have a strange problem with my MM. After a few hours the MM is complete frozen. No ssh, no ftp and a frozen screen as well.</p>
<p dir="auto">I’ve updated to MM 2.2.2 with a fresh install on the same Rasbian as MM 2.2.1 was running. After installing I was coping over from the old MM directory those modules I wanted keep in my new MM - without npm install them. Its running well. I  used my old config.js too.</p>
<p dir="auto">A fresh rebooted system is running down from  37% free memory to 0% and freezes.<br />
I have seen, that there are 4 tasks of electron are running which are taking all the memory.</p>
<p dir="auto">I have no errors in the logs!</p>
<p dir="auto">Any idea what to do?</p>
<p dir="auto">My config.js:</p>
 * MIT Licensed.
var config = {
	port: 8080,
	address: "0.0.0.0",
	language: 'de',
	timeFormat: 24,
	units: 'metric',
			module: 'alert',
			module: 'clock',
			position: 'top_left'
			module: 'calendar',
			header: 'Mein Kalender',
			position: 'top_left',
						symbol: 'calendar-check-o ',
						url: 'webcal://www.ifeiertage.de/ni-.ics'
						symbol: 'calendar-o',
						url: 'https://calendar.google.com/calendar/ical/private-basic.ics'
			module: 'currentweather',
			position: 'top_right',
				locationID: '2881062',  //ID from http://www.openweathermap.org
				appid: '
			module: 'weatherforecast',
			header: 'Wettervorschau',
	            appid: '
			module: 'MMM-Remote-Control',
			// uncomment the following line to show the URL of the remote control on the mirror
			//position: 'bottom_left'
			// you can hide this module afterwards from the remote control itself
			module: 'MMM-PNews',
			position: 'bottom_bar',
				key: "",
				maxWidth: "100%",
				newsSource: "der-tagesspiegel", // "der-tagesspiegel", "die-zeit", "gruenderszene", "spiegel-online", "t3n", "wired-de",
			module: 'newsfeed',
				feeds: [
						title: "HAZ Schlagzeilen",
						url: "http://www.haz.de/rss/feed/haz_schlagzeilen",
						title: "SPIEGEL Schlagzeilen",
						url: "http://www.spiegel.de/schlagzeilen/index.rss",
				showSourceTitle: true,
				showPublishDate: true,
				showDescription: true,
				updateInterval: 20 * 1000,
				animationSpeed: 3.5 * 1000
			module: 'internet-monitor',
			position: 'top_center',
			header: '',
			config:{
				type: 'minimal',
				maxTime: 1,
				updateInterval: 9000000,
				verbose: false,
				displayStrength: true,
				displaySpeed: true,
                strengthIconSize: 80,
                maxGaugeScale: 1,
		wifiSymbol:{
                    fullColor: '#3afc25',
                    almostColor: '#ffff0c',
                    halfColor: '#ff8c00',
					noneColor: '#ff1111'
			module: 'MMM-MovieListings',
			position: 'bottom_right',
			header: '',
				includeMoviePlot: true,
				apiKey : "",
				interface: 'poster', //'list', 'poster', 'detailed'
				//moviesPerPage : 5,
				pageChangeInterval : 20 * 1000, // = 30 seconds
				refreshInterval : 1000 * 60 * 60 * 24, // = Once a day
			module:	'MMM-Fuel',
				api_key: "",
				lat: 52.429327,
				lng: 9.726591,
				sortBy: "e5",
				types: ["e5", "diesel"],
				rotate: false,
				open: true
			module: 'MMM-nasaastropic',
					updateInterval: 6*60*60*1000,
					animationSpeed: 0,
					header: 'NASA - Bild des Tages',
					maxlongedge: 1300
			module: 'MMM-SystemStats',
			position: 'top_left', // This can be any of the regions.
			classes: 'small dimmed', // Add your own styling. Optional.
				updateInterval: 10000,
				animationSpeed: 0,
				align: 'left', // align labels
				//header: 'System Stats', // This is optionaL
			module: 'MMM-Carousel',
				transitionInterval: 20000,
				ignoreModules: ['clock', 'alert', 'internet-monitor', 'currentweather', 'MMM-Remote-Control',],
				mode: 'slides',
				slides: [
				['calendar', 'MMM-PNews', 'MMM-MovieListings', 'MMM-Sonos',],
				['MMM-nasaastropic', 'weatherforecast',],
				['MMM-Fuel', 'newsfeed', 'MMM-MovieListings', 'MMM-Sonos',],
				['MMM-Events','MMM-SystemStats', 'MMM-MovieListings', 'MMM-PNews', 'MMM-Sonos',],
				['MMM-xiaomi', 'MMM-SystemStats', 'weatherforecast', 'MMM-Sonos',],
				['MMM-iHaveBeenThere']
			module: 'MMM-Events',
				city: "Hannover",	           // Your City
				eventType: "performing_arts",		   // Choose from Events List below
				when: "Next week",                 // "All", "Future", "Past", "Today", "Last Week", "This Week", "Next week", and months by name, e.g. "October"
				mode: "noFrame",                   // "Frame" or "noFrame" (around picture)
				apikey: "",
				rotateInterval: 1 * 60 * 1000,     // New Event Appears every 3 minutes
				useHeader: false,	           // Set to true if you want a header
				header: "",
				animationSpeed: 3000,              // Event fades in and out
				picture: true,                     // true, false = no image
		module: 'MMM-xiaomi',
		position: 'bottom_left',
		header: 'Temperatur / Feuchtigkeit',  // This is optional
			gatewayIP: '192.168.2.160',
			gatewayToken: '6ebf9b84e5c615c09268166a99b95f0a',
			showWindow: true,
			showVentilation: false,
			minTemperature: false,
			maxHumidity: false,
			showTrend: true,
			showNotifications: false,
			outsideSensorId: '158d0001b920bd',
			rooms: [
			{ name: 'Wohnzimmer', sortOrder: 30, devices : ['158d00015736a8', '158d000119fcb2'] },
			{ name: 'Bad', sortOrder: 30, devices : ['158d0001b911b9'] },
			{ name: 'Schlafzimmer', sortOrder: 30, devices : ['158d0001b91177', '158d00011919a3', '56234267'] },
			{ name: 'Arbeitszimmer', sortOrder: 30, devices : ['158d0001b9035b'] },
			{ name: 'Draußen', sortOrder: 30, devices : ['158d0001b920bd'] },
		module: 'MMM-iHaveBeenThere',
		position: 'middle_center',	// bigger place is recommended.
			zoomLevel: 1.0,
			home_desc: "Langenhagen",
			home_lat: 52.436972,
			home_lon: 9.714468,
			away_lat: [8.077707, -4.251792, 43.653226, 13.062883, 35.902819, 23.089880, 7.934206, 11.199286, 20.629559,  45.440847, 36.543312, 56.949649, 47.497912,  41.385064, 40.416775, 30.388870,  6.451360, 47.582370, 46.776085, 3.157764, 45.438845, 50.075538, 36.405267, 38.966901, ],
			away_lon: [77.531977, 39.598932, -79.383184, -59.542683, 14.487007, -82.361938, 98.371216, -60.789940, -87.073885, 12.315515, 32.008322, 24.105186, 19.040235, 2.173403, -3.703790, -9.600254, 79.978741, 12.162750, 9.676668, 101.711860, 17.191742, 14.437800, 10.622360, 1.551727, ],
			away_desc: ["Indien", "Kenja", "Kanada", "Barbados", "Malta", "Cuba", "Thailand", "Trinidad &amp; Tobago", "Mexico", "Venedig", "Türkei", "Letland", "Budapest", "Barcelona", "Madrid", "Marokko", "Sri Lanka", "Österreich", "Schweiz", "Malaysia", "Kroatien", "Prag", "Tunesien", "Ibiza"],
			trip: [false, false, false, false, false, false, false, false, false, false, false, false, false, false, false, false, false, false]
	module: 'MMM-Sonos',
	position: 'middle_center', // you may choose any location
	config: {}
]]></description><link>https://forum.magicmirror.builders/topic/6287/rpi3-freezes-after-a-few-houres</link><generator>RSS for Node</generator><lastBuildDate>Sat, 09 May 2026 18:05:06 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/6287.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 19 Jan 2018 14:42:18 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Rpi3 freezes after a few houres on Sun, 18 Mar 2018 19:52:00 GMT]]></title><description><![CDATA[<p dir="auto">Just to let you know: In my case it was the <em>MMM-iHaveBeenThere</em> module which caused the trouble.</p>
]]></description><link>https://forum.magicmirror.builders/post/37178</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/37178</guid><dc:creator><![CDATA[Albert2002]]></dc:creator><pubDate>Sun, 18 Mar 2018 19:52:00 GMT</pubDate></item><item><title><![CDATA[Reply to Rpi3 freezes after a few houres on Sat, 20 Jan 2018 08:56:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mykle1" aria-label="Profile: Mykle1">@<bdi>Mykle1</bdi></a> said in <a href="/post/34284">Rpi3 freezes after a few houres</a>:</p>
<p dir="auto">Have you tried running only the default modules to see if the problem still occurs? If it does not, add them one by one, or in pairs, until you experience a problem so you can isolate the issue.</p>
<p dir="auto">Ok, this is what I try now. Thank you for your help!</p>
]]></description><link>https://forum.magicmirror.builders/post/34310</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/34310</guid><dc:creator><![CDATA[Albert2002]]></dc:creator><pubDate>Sat, 20 Jan 2018 08:56:41 GMT</pubDate></item><item><title><![CDATA[Reply to Rpi3 freezes after a few houres on Sat, 20 Jan 2018 03:00:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/barrysmallgoods" aria-label="Profile: barrysmallgoods">@<bdi>barrysmallgoods</bdi></a> said in <a href="/post/34299">Rpi3 freezes after a few houres</a>:</p>
<p dir="auto">It turned out to be a pi-hole module for me.</p>
<p dir="auto">Well done, mate! :-)</p>
]]></description><link>https://forum.magicmirror.builders/post/34300</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/34300</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Sat, 20 Jan 2018 03:00:00 GMT</pubDate></item><item><title><![CDATA[Reply to Rpi3 freezes after a few houres on Sat, 20 Jan 2018 02:55:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mykle1" aria-label="Profile: Mykle1">@<bdi>Mykle1</bdi></a> said in <a href="/post/34284">Rpi3 freezes after a few houres</a>:</p>
<p dir="auto">This is what I did recently. It wasn’t the pi freezing but the browser on the pi, I am running the mirror on a server. It turned out to be a pi-hole module for me.</p>
]]></description><link>https://forum.magicmirror.builders/post/34299</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/34299</guid><dc:creator><![CDATA[barrysmallgoods]]></dc:creator><pubDate>Sat, 20 Jan 2018 02:55:16 GMT</pubDate></item><item><title><![CDATA[Reply to Rpi3 freezes after a few houres on Fri, 19 Jan 2018 22:31:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/albert2002" aria-label="Profile: Albert2002">@<bdi>Albert2002</bdi></a></p>
<p dir="auto">Indeed, but not all users have the same troubles, and not for the same reasons. Anyway . . .</p>
<p dir="auto">If you are unfortunate and the problem arises before the addition of 3rd party modules then that is another matter altogether.</p>
]]></description><link>https://forum.magicmirror.builders/post/34284</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/34284</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Fri, 19 Jan 2018 22:31:44 GMT</pubDate></item><item><title><![CDATA[Reply to Rpi3 freezes after a few houres on Fri, 19 Jan 2018 19:14:24 GMT]]></title><description><![CDATA[<p dir="auto">I checked this, unfortunately I’m not running two instances.  The second one is a service needed by the Sonos Module.<br />
It seams to me that there a few people which having problems since 2.2.2?</p>
<pre><code>pi@MagicMirror:~ $ pm2 status
? Name  ? mode ? status ? ? ? cpu ? memory   ?
? mm    ? fork ? online ? 0 ? 0%  ? 1.3 MB   ?
? sonos ? fork ? online ? 0 ? 0%  ? 1.3 MB   ?
 Use `pm2 show ` to get more details about an app
pi@MagicMirror:~ $
]]></description><link>https://forum.magicmirror.builders/post/34280</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/34280</guid><dc:creator><![CDATA[Albert2002]]></dc:creator><pubDate>Fri, 19 Jan 2018 19:14:24 GMT</pubDate></item><item><title><![CDATA[Reply to Rpi3 freezes after a few houres on Fri, 19 Jan 2018 17:30:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/albert2002" aria-label="Profile: Albert2002">@<bdi>Albert2002</bdi></a></p>
<p dir="auto">You may have more than one instance of MM running. That seems to be common recently. Please see the instructions here to check and correct. 7th, 8th and 9th post</p>
<p dir="auto"><a href="https://forum.magicmirror.builders/topic/6249/something-is-wrong/7">https://forum.magicmirror.builders/topic/6249/something-is-wrong/7</a></p>
]]></description><link>https://forum.magicmirror.builders/post/34276</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/34276</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Fri, 19 Jan 2018 17:30:16 GMT</pubDate></item></channel></rss>
