<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Calendar and Newsfeed stop Updating after 1-2 hours]]></title><description><![CDATA[<p dir="auto">My Magic Mirror works and runs the default calendar, weather, and newsfeed modules as well as MMM-Cryptocurrency. I did the config check and it came back with proper syntax. Overall, everything works well, but I’ve noticed that my claendar stops updating after 1-2 hours and that my newsfeed also stops updating. I linked to an iCal URL. If I make a change to the calendar using another device, the changes will update on the Magic Mirror, but after MagicMirror has run for an hour or so it stops reflecting the changes. I left my MagicMirror running for a week and events that were 5-6 days ago were listed as occurring tomorrow.</p>
<p dir="auto">It also was running the previous weeks’ headlines. I’m not sure if they’re doing the same thing as the calendar and updating for 1-2 hours, then stopping, or if they just do an initial load and never update.</p>
<p dir="auto">The MMM-Cryptocurrency and weather modules do update appropriately. If I close and restart MagicMirror everything starts off up to date and then after an hour or two it appears the calendar and newsfeed stop updating.</p>
<p dir="auto">I’m sure there’s a smart way to look in a logfile and see what’s going on, but I didn’t see anything obvious. I checked the messages when I quit the Magic Mirror application, and I also browsed through the logfiles under ~/Pi/.rpi/logs/. Nothing jumped out at me, but I’m more or less self taught on Linux and have no real idea what I’m doing. Any help is appreciated.</p>
]]></description><link>https://forum.magicmirror.builders/topic/6292/calendar-and-newsfeed-stop-updating-after-1-2-hours</link><generator>RSS for Node</generator><lastBuildDate>Mon, 13 Apr 2026 11:41:49 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/6292.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 21 Jan 2018 14:07:10 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Calendar and Newsfeed stop Updating after 1-2 hours on Sun, 21 Jan 2018 21:34:01 GMT]]></title><description><![CDATA[<p dir="auto">Not sure if this applies to you, but I had problems with updating the calendar. Turns out I had to change the wifi channel -&gt; <a href="https://forum.magicmirror.builders/topic/4193/calendar-not-updating-after-changing-to-wifi-ssid/3">https://forum.magicmirror.builders/topic/4193/calendar-not-updating-after-changing-to-wifi-ssid/3</a></p>
]]></description><link>https://forum.magicmirror.builders/post/34380</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/34380</guid><dc:creator><![CDATA[kwyjibo089]]></dc:creator><pubDate>Sun, 21 Jan 2018 21:34:01 GMT</pubDate></item><item><title><![CDATA[Reply to Calendar and Newsfeed stop Updating after 1-2 hours on Sun, 21 Jan 2018 17:49:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/osowp95" aria-label="Profile: osoWP95">@<bdi>osoWP95</bdi></a></p>
<p dir="auto">If you’re using <code>pm2</code>, you can use <code>pm2 logs</code> to view the server logs (or view them directly in <code>~/.pm2/logs</code>).</p>
<p dir="auto">You can also use <code>npm start dev</code> to start in dev mode and see the browser (client) console (be sure to stop the PM2 process first, e.g. <code>pm2 stop mm</code>).</p>
]]></description><link>https://forum.magicmirror.builders/post/34375</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/34375</guid><dc:creator><![CDATA[ninjabreadman]]></dc:creator><pubDate>Sun, 21 Jan 2018 17:49:10 GMT</pubDate></item></channel></rss>
