<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MacMirror]]></title><description><![CDATA[<h1>MacMirror with Hello-Lucy voice enhancement</h1>
<p dir="auto">So, I’ve had this useless, 2006 MacBook laying around for some time now.<br />
What does one do with a 12 year old, nearly worthless, 32bit laptop? And I do<br />
mean nearly worthless. A quick search on eBay revealed that this MacBook can be had<br />
for about $25. The 64bit Core 2 Duo (2007) can be gotten for about $10 more. Again,<br />
I asked myself, “What do I do with it?” It only has 2GB of RAM and modern browsers won’t<br />
even run on it. There aren’t too many options where this old laptop is concerned.</p>
<p dir="auto">Off to the ubuntu website I went. Even installing ubuntu on it was a little tricky and<br />
I was limited to the 32bit version of ubuntu, as well. However, once I got ubuntu settled<br />
I installed MagicMirror. I was not disappointed. This laptop even has a mini DVI out port<br />
to drive an external monitor. I thought about disassembling it to use it for a conventional<br />
style mirror but that would mean acquiring another monitor and a larger piece of two-way<br />
mirror. I had a small piece left over from the “Vanity Mirror” I made not too long ago. So,<br />
I took the bezel off the MacBook and cut the mirror exactly the same size as the inner metal<br />
bezel that secures the display. I affixed the mirror to the inner metal bezel around the<br />
display with a drop of Gorilla Super Glue in each corner. That’s all it needed. Put the outer<br />
bezel back on. I did this by design. I could have made the mirror as large as the casing.<br />
Why didn’t I? Because I wanted the lid to open and close normally, which it does very nicely.<br />
When you open the lid you are greeted by a mirror, not a black display. Pretty damn cool!</p>
<p dir="auto">So, what do you get with your $25 MacMirror? Everything! Compare this to buying a Pi.</p>
<p dir="auto">2GHz Core Duo T2500 Intel Processor (32bit)<br />
2 GB of RAM (Maximum)<br />
250 GB Hard Drive. (Original 60 GB)<br />
Intel GMA 950 Video Card with 64MB of VRAM<br />
13.3" TFT active-matrix display with a 1280 by 800 native resolution.<br />
Mini DVI out supports 1920 by 1200 resolution on external monitors.(That’s crazy!)<br />
Slot-loading double layer DVD/CD-RW SuperDrive (Still functional)<br />
Gigabit Ethernet<br />
Wifi - AirPort Extreme (802.11a/b/g)<br />
Bluetooth 2.0+EDR standard.<br />
Two 480-Mbps USB 2.0 ports.<br />
One Firewire “400” port.<br />
iSight Camera (not working)<br />
Integrated microphone</p>
<p dir="auto">For less than the price of a Pi3, this thing performs wonderfully and outperforms the Pi3 in<br />
every category, even running a 32 bit version of ubuntu. The MM software and ubuntu run very<br />
nicely together and the Hello-Lucy voice enhancement runs beautifully, with excellent response<br />
time. :-)</p>
<p dir="auto"><img src="/assets/uploads/files/1516832488713-44.jpg" alt="3_1516832482702_44.jpg" class=" img-fluid img-markdown" /> <img src="/assets/uploads/files/1516832488460-33.jpg" alt="2_1516832482702_33.jpg" class=" img-fluid img-markdown" /> <img src="/assets/uploads/files/1516832488592-22.jpg" alt="1_1516832482701_22.jpg" class=" img-fluid img-markdown" /> <img src="/assets/uploads/files/1516832488320-11.jpg" alt="0_1516832482701_11.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto"><a href="https://youtu.be/OjHeJd2avhw" target="_blank" rel="noopener noreferrer nofollow ugc">https://youtu.be/OjHeJd2avhw</a></p>
]]></description><link>https://forum.magicmirror.builders/topic/6376/macmirror</link><generator>RSS for Node</generator><lastBuildDate>Wed, 10 Jun 2026 09:28:56 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/6376.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 24 Jan 2018 22:25:15 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MacMirror on Fri, 02 Aug 2019 00:37:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/trividar" aria-label="Profile: trividar">@<bdi>trividar</bdi></a></p>
<p dir="auto">Well, unless you’ve changed something it should work. Yes, <a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a>’s sleepwake module is excellent.</p>
<p dir="auto">Are you using this config option?<br />
<img src="/assets/uploads/files/1564706221774-screenshot-from-2019-08-01-20-35-53.png" alt="0_1564706221426_Screenshot from 2019-08-01 20-35-53.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/59660</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/59660</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Fri, 02 Aug 2019 00:37:05 GMT</pubDate></item><item><title><![CDATA[Reply to MacMirror on Thu, 01 Aug 2019 09:11:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mykle1" aria-label="Profile: Mykle1">@<bdi>Mykle1</bdi></a> Hello, I tried to play your Youtube video, the funny thing is, every command is perfectly recognized by your voice ;o) just “go to sleep” not! But I’ve managed to realize a few times “go to sleep”, but nothing happens on my Macmirror, so I have to find out what I did wrong (or try mmm-sleepwake module with motion project and my camera)!<br />
But apart from this, your module extension is amazing! I love it! Thank you for your work!</p>
]]></description><link>https://forum.magicmirror.builders/post/59622</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/59622</guid><dc:creator><![CDATA[trividar]]></dc:creator><pubDate>Thu, 01 Aug 2019 09:11:30 GMT</pubDate></item><item><title><![CDATA[Reply to MacMirror on Thu, 01 Aug 2019 00:15:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/trividar" aria-label="Profile: trividar">@<bdi>trividar</bdi></a></p>
<p dir="auto">I don’t know if you’ve seen this video but it clearly shows the ‘GO TO SLEEP’ command working.</p>
<p dir="auto"><a href="https://www.youtube.com/watch?v=Zsm_hi7XvM4" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.youtube.com/watch?v=Zsm_hi7XvM4</a></p>
]]></description><link>https://forum.magicmirror.builders/post/59617</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/59617</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Thu, 01 Aug 2019 00:15:34 GMT</pubDate></item><item><title><![CDATA[Reply to MacMirror on Tue, 30 Jul 2019 01:02:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/trividar" aria-label="Profile: trividar">@<bdi>trividar</bdi></a></p>
<p dir="auto">Not terribly hard to change the command. Feel free to make any changes that work best for you. However, I won’t be making any changes to the repo at this time.</p>
]]></description><link>https://forum.magicmirror.builders/post/59517</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/59517</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Tue, 30 Jul 2019 01:02:47 GMT</pubDate></item><item><title><![CDATA[Reply to MacMirror on Mon, 29 Jul 2019 05:21:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mykle1" aria-label="Profile: Mykle1">@<bdi>Mykle1</bdi></a> Thanks, but unfortunately it also doesn’t work if I say it as a word ;o( It’s difficult to change this formulation? I would try what works best for me.</p>
]]></description><link>https://forum.magicmirror.builders/post/59478</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/59478</guid><dc:creator><![CDATA[trividar]]></dc:creator><pubDate>Mon, 29 Jul 2019 05:21:22 GMT</pubDate></item><item><title><![CDATA[Reply to MacMirror on Sun, 28 Jul 2019 00:10:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/trividar" aria-label="Profile: trividar">@<bdi>trividar</bdi></a></p>
<p dir="auto">The reason I made the command “GO TO SLEEP” is that I had the best results with that phrase. You can see in some of my videos that feature that command that it does work for me. Some people that with accents have had trouble with mmm-voice/Hello-Lucy due to this. A close friend of mine that lives in Norway has trouble with Lucy due to his accent.</p>
<p dir="auto">Please try this:</p>
<p dir="auto">Try saying the command as one word, GoToSleep instead of 3 separate words</p>
]]></description><link>https://forum.magicmirror.builders/post/59444</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/59444</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Sun, 28 Jul 2019 00:10:15 GMT</pubDate></item><item><title><![CDATA[Reply to MacMirror on Sat, 27 Jul 2019 22:06:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mykle1" aria-label="Profile: Mykle1">@<bdi>Mykle1</bdi></a> Hi, I got it to work on my Mac mini… wooow it’s fantastic!!! Just a question/problem, it will not recognize “go to sleep”, it will recognize “go sleep”, sleep, sleep, go… but never “go to sleep”. Is there a way to change the command “go sleep” or just “sleep”, thank you!</p>
]]></description><link>https://forum.magicmirror.builders/post/59441</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/59441</guid><dc:creator><![CDATA[trividar]]></dc:creator><pubDate>Sat, 27 Jul 2019 22:06:50 GMT</pubDate></item><item><title><![CDATA[Reply to MacMirror on Thu, 25 Jul 2019 05:04:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> woow amazing! Thank you very much for this info! I will try to build my MM V2 with Mac mini, mmm-voice/hello Lucy &amp; MMM-SleepWake and my standard modules, which I already have with my first Raspi build! Maybe I will write a step-by-step guide if I succeed.</p>
]]></description><link>https://forum.magicmirror.builders/post/59368</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/59368</guid><dc:creator><![CDATA[trividar]]></dc:creator><pubDate>Thu, 25 Jul 2019 05:04:55 GMT</pubDate></item><item><title><![CDATA[Reply to MacMirror on Thu, 25 Jul 2019 01:17:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/trividar" aria-label="Profile: trividar">@<bdi>trividar</bdi></a> mmm-voice/hello Lucy use pocketsphinx for voice reco. It is supported on osx and Ubuntu.</p>
<p dir="auto">And those modules support ‘go to sleep’.  Which can launch a command to turn off hdmi, or whatever.</p>
<p dir="auto">My MMM-SleepWake does motion detection via camera  and can do the wakeup when they do sleep</p>
]]></description><link>https://forum.magicmirror.builders/post/59363</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/59363</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 25 Jul 2019 01:17:28 GMT</pubDate></item><item><title><![CDATA[Reply to MacMirror on Wed, 24 Jul 2019 23:58:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/trividar" aria-label="Profile: trividar">@<bdi>trividar</bdi></a></p>
<p dir="auto">I don’t really know as the MacMirror is the only Mac I’ve dealt with. There are Mac users here. Perhaps they will chime in and provide you with an answer.</p>
]]></description><link>https://forum.magicmirror.builders/post/59360</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/59360</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Wed, 24 Jul 2019 23:58:52 GMT</pubDate></item><item><title><![CDATA[Reply to MacMirror on Wed, 24 Jul 2019 06:15:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mykle1" aria-label="Profile: Mykle1">@<bdi>Mykle1</bdi></a> What do you think, would it also work on Mac OS x or do I have to install ubuntu on the Mac mini? THX !!</p>
]]></description><link>https://forum.magicmirror.builders/post/59336</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/59336</guid><dc:creator><![CDATA[trividar]]></dc:creator><pubDate>Wed, 24 Jul 2019 06:15:48 GMT</pubDate></item><item><title><![CDATA[Reply to MacMirror on Tue, 23 Jul 2019 23:54:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/trividar" aria-label="Profile: trividar">@<bdi>trividar</bdi></a> said in <a href="/post/59275">MacMirror</a>:</p>
<p dir="auto">is there a way to disable te Monitor/HDMI output/SleepMode with voice on Mac with ubuntu?</p>
<p dir="auto">I think mmm-voice has that ability by default. However,  using mmm-voice with the Hello Lucy enhancement you can simply issue the voice commands “Go To Sleep” to put your monitor in standby/sleep and “Please Wake Up” to turn it back on.</p>
<p dir="auto">There are other voice modules that may do the same thing.</p>
]]></description><link>https://forum.magicmirror.builders/post/59332</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/59332</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Tue, 23 Jul 2019 23:54:30 GMT</pubDate></item><item><title><![CDATA[Reply to MacMirror on Tue, 23 Jul 2019 06:41:39 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/user/mykle1" aria-label="Profile: Mykle1">@<bdi>Mykle1</bdi></a>, what an amazing and fantastic work! I’ll try to rebuild it on my Mac Mini.<br />
One question I have already now, is there a way to disable te Monitor/HDMI output/SleepMode with voice on Mac with ubuntu?</p>
]]></description><link>https://forum.magicmirror.builders/post/59275</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/59275</guid><dc:creator><![CDATA[trividar]]></dc:creator><pubDate>Tue, 23 Jul 2019 06:41:39 GMT</pubDate></item><item><title><![CDATA[Reply to MacMirror on Thu, 25 Jan 2018 20:17:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mykle1" aria-label="Profile: Mykle1">@<bdi>Mykle1</bdi></a> - fantastic job man!!!<br />
I like it</p>
]]></description><link>https://forum.magicmirror.builders/post/34657</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/34657</guid><dc:creator><![CDATA[Johans]]></dc:creator><pubDate>Thu, 25 Jan 2018 20:17:10 GMT</pubDate></item></channel></rss>
