<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Cant run the app]]></title><description><![CDATA[<p dir="auto">My first time trying to build a magicmirror, and i cant solve this problem. Can you guys help me? <img src="https://scontent.flis1-1.fna.fbcdn.net/v/t35.0-12/s2048x2048/27398084_1727036654014382_1034589331_o.jpg?oh=29aaa82c910600393482d305e8093444&amp;oe=5A6E7BD3" alt="alt text" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/topic/6409/cant-run-the-app</link><generator>RSS for Node</generator><lastBuildDate>Wed, 13 May 2026 10:51:19 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/6409.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 27 Jan 2018 19:11:48 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Cant run the app on Mon, 29 Jan 2018 04:45:54 GMT]]></title><description><![CDATA[<p dir="auto">i am wondering why u use MM 2.2.1. The actual release is 2.2.2 i think.<br />
Anyhow…</p>
<p dir="auto">Try starting in development mode and take a look at errors:</p>
<pre><code>npm start dev
<p dir="auto">or via ssh:</p>
<pre><code>DISPLAY=:0 npm start dev
]]></description><link>https://forum.magicmirror.builders/post/34861</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/34861</guid><dc:creator><![CDATA[cruunnerr]]></dc:creator><pubDate>Mon, 29 Jan 2018 04:45:54 GMT</pubDate></item><item><title><![CDATA[Reply to Cant run the app on Sun, 28 Jan 2018 23:07:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/saljoke" aria-label="Profile: saljoke">@<bdi>saljoke</bdi></a> i tryed, and exatly the same error</p>
]]></description><link>https://forum.magicmirror.builders/post/34849</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/34849</guid><dc:creator><![CDATA[goncalovsc]]></dc:creator><pubDate>Sun, 28 Jan 2018 23:07:35 GMT</pubDate></item><item><title><![CDATA[Reply to Cant run the app on Sun, 28 Jan 2018 16:18:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cpramhofer" aria-label="Profile: cpramhofer">@<bdi>cpramhofer</bdi></a> i installed by the commands, I followed a video</p>
]]></description><link>https://forum.magicmirror.builders/post/34808</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/34808</guid><dc:creator><![CDATA[goncalovsc]]></dc:creator><pubDate>Sun, 28 Jan 2018 16:18:01 GMT</pubDate></item><item><title><![CDATA[Reply to Cant run the app on Sun, 28 Jan 2018 16:16:55 GMT]]></title><description><![CDATA[<p dir="auto">Did you run the install directly from the command line (without the start of the graphical user interface)?</p>
<p dir="auto">You should run the setup within the GUI!</p>
]]></description><link>https://forum.magicmirror.builders/post/34807</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/34807</guid><dc:creator><![CDATA[cpramhofer]]></dc:creator><pubDate>Sun, 28 Jan 2018 16:16:55 GMT</pubDate></item><item><title><![CDATA[Reply to Cant run the app on Sun, 28 Jan 2018 13:32:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/saljoke" aria-label="Profile: saljoke">@<bdi>saljoke</bdi></a> I’ll try later at night, when I’ve done that I’ll give you an update. Thanks</p>
]]></description><link>https://forum.magicmirror.builders/post/34793</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/34793</guid><dc:creator><![CDATA[goncalovsc]]></dc:creator><pubDate>Sun, 28 Jan 2018 13:32:42 GMT</pubDate></item><item><title><![CDATA[Reply to Cant run the app on Sun, 28 Jan 2018 13:02:31 GMT]]></title><description><![CDATA[<p dir="auto">Try to rebuild electron or reinstall with last update. npm install -g electron or npm rebuild in magic Mirror directory</p>
]]></description><link>https://forum.magicmirror.builders/post/34792</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/34792</guid><dc:creator><![CDATA[saljoke]]></dc:creator><pubDate>Sun, 28 Jan 2018 13:02:31 GMT</pubDate></item><item><title><![CDATA[Reply to Cant run the app on Sun, 28 Jan 2018 12:56:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ninjabreadman" aria-label="Profile: ninjabreadman">@<bdi>ninjabreadman</bdi></a> I’ve done all that, and the error persists</p>
]]></description><link>https://forum.magicmirror.builders/post/34791</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/34791</guid><dc:creator><![CDATA[goncalovsc]]></dc:creator><pubDate>Sun, 28 Jan 2018 12:56:55 GMT</pubDate></item><item><title><![CDATA[Reply to Cant run the app on Sun, 28 Jan 2018 12:44:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/goncalovsc" aria-label="Profile: goncalovsc">@<bdi>goncalovsc</bdi></a> Is this after having run the auto install script or manually installing? Did you run <code>npm install</code> in the <code>~/MagicMirror</code> folder? Have you tried running <code>npm start</code> in the same directory?</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cruunnerr" aria-label="Profile: cruunnerr">@<bdi>cruunnerr</bdi></a> What are the permissions of your <a href="http://run-start.sh" target="_blank" rel="noopener noreferrer nofollow ugc">run-start.sh</a>? It doesn’t make sense to me that mine is <code>rw-r—r—</code> but works fine. I would expect it needs <code>x</code> permissions.</p>
]]></description><link>https://forum.magicmirror.builders/post/34790</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/34790</guid><dc:creator><![CDATA[ninjabreadman]]></dc:creator><pubDate>Sun, 28 Jan 2018 12:44:39 GMT</pubDate></item><item><title><![CDATA[Reply to Cant run the app on Sun, 28 Jan 2018 11:44:15 GMT]]></title><description><![CDATA[<pre><code>0 info it worked if it ends with ok
1 verbose cli [ '/usr/bin/node', '/usr/bin/npm', 'start' ]
2 info using npm@3.10.10
3 info using node@v6.12.2
5 info lifecycle magicmirror@2.2.1~prestart: magicmirror@2.2.1
6 silly lifecycle magicmirror@2.2.1~prestart: no script for prestart, continuing
7 info lifecycle magicmirror@2.2.1~start: magicmirror@2.2.1
8 verbose lifecycle magicmirror@2.2.1~start: unsafe-perm in lifecycle true
9 verbose lifecycle magicmirror@2.2.1~start: PATH: /usr/lib/node_modules/npm/bin/node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
10 verbose lifecycle magicmirror@2.2.1~start: CWD: /home/pi/MagicMirror
11 silly lifecycle magicmirror@2.2.1~start: Args: [ '-c', 'sh run-start.sh' ]
12 silly lifecycle magicmirror@2.2.1~start: Returned: code: 1  signal: null
13 info lifecycle magicmirror@2.2.1~start: Failed to exec start script
14 verbose stack Error: magicmirror@2.2.1 start: `sh run-start.sh`
14 verbose stack Exit status 1
14 verbose stack     at EventEmitter. (/usr/lib/node_modules/npm/lib/utils/lifecycle.js:255:16)
14 verbose stack     at emitTwo (events.js:106:13)
14 verbose stack     at EventEmitter.emit (events.js:191:7)
14 verbose stack     at ChildProcess. (/usr/lib/node_modules/npm/lib/utils/spawn.js:40:14)
14 verbose stack     at ChildProcess.emit (events.js:191:7)
14 verbose stack     at maybeClose (internal/child_process.js:920:16)
14 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:230:5)
15 verbose pkgid magicmirror@2.2.1
16 verbose cwd /home/pi/MagicMirror
17 error Linux 4.9.59-v7+
18 error argv "/usr/bin/node" "/usr/bin/npm" "start"
19 error node v6.12.2
20 error npm  v3.10.10
21 error code ELIFECYCLE
22 error magicmirror@2.2.1 start: `sh run-start.sh`
22 error Exit status 1
23 error Failed at the magicmirror@2.2.1 start script 'sh run-start.sh'.
23 error Make sure you have the latest version of node.js and npm installed.
23 error If you do, this is most likely a problem with the magicmirror package,
23 error not with npm itself.
23 error Tell the author that this fails on your system:
23 error     sh run-start.sh
23 error You can get information on how to open an issue for this project with:
23 error     npm bugs magicmirror
23 error Or if that isn't available, you can get their info via:
23 error     npm owner ls magicmirror
23 error There is likely additional logging output above.
24 verbose exit [ 1, true ]
]]></description><link>https://forum.magicmirror.builders/post/34787</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/34787</guid><dc:creator><![CDATA[goncalovsc]]></dc:creator><pubDate>Sun, 28 Jan 2018 11:44:15 GMT</pubDate></item><item><title><![CDATA[Reply to Cant run the app on Sun, 28 Jan 2018 09:41:35 GMT]]></title><description><![CDATA[<p dir="auto">Could u send the full log file in a code box here?</p>
<pre><code>cat /home/pi/.npm/_logs/2018-01-02T17_31_20_367Z-debug.log
]]></description><link>https://forum.magicmirror.builders/post/34781</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/34781</guid><dc:creator><![CDATA[cruunnerr]]></dc:creator><pubDate>Sun, 28 Jan 2018 09:41:35 GMT</pubDate></item></channel></rss>
