<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Changing compliments]]></title><description><![CDATA[<p dir="auto">Totally new to Linux and Magic Mirror. I tried to change a complimenT in the config.js file of the compliment module and I got the error to install a configuration file. I kept my changes in between the double quotes. Am I doing this wrong? Thanks.</p>
]]></description><link>https://forum.magicmirror.builders/topic/6427/changing-compliments</link><generator>RSS for Node</generator><lastBuildDate>Sun, 12 Apr 2026 08:41:25 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/6427.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 29 Jan 2018 17:55:37 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Changing compliments on Thu, 20 Aug 2020 02:58:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kc5ril" aria-label="Profile: KC5RIL">@<bdi>KC5RIL</bdi></a> read this</p>
<p dir="auto"><a href="https://forum.magicmirror.builders/topic/4231/how-to-add-modules-for-absolute-beginners?_=1597892229407">https://forum.magicmirror.builders/topic/4231/how-to-add-modules-for-absolute-beginners?_=1597892229407</a></p>
]]></description><link>https://forum.magicmirror.builders/post/80385</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/80385</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 20 Aug 2020 02:58:20 GMT</pubDate></item><item><title><![CDATA[Reply to Changing compliments on Thu, 20 Aug 2020 02:31:36 GMT]]></title><description><![CDATA[<p dir="auto">EUREKA!</p>
<p dir="auto">The error message at start was bothering me.  Figured it out with some playing around.  needed a ‘}’ at 195.  Problem solved.</p>
<p dir="auto">Thanks for ya’lls help.  I’ll more than likely pester you again with more issues.  Have your crayons ready!</p>
]]></description><link>https://forum.magicmirror.builders/post/80384</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/80384</guid><dc:creator><![CDATA[KC5RIL]]></dc:creator><pubDate>Thu, 20 Aug 2020 02:31:36 GMT</pubDate></item><item><title><![CDATA[Reply to Changing compliments on Thu, 20 Aug 2020 02:19:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> I’ve proofed all I can.  I don’t see anymore syntax errors.  Still won’t run properly.  Here’s the config:check ```<br />
pi@WALL-e:~/MagicMirror $ npm run config:check</p>
<p dir="auto">magicmirror@2.12.0 config:check /home/pi/MagicMirror<br />
node js/check_config.js</p>
<p dir="auto">[2020-08-19 21:11:52.797] [INFO]   Checking file…  /home/pi/MagicMirror/config/config.js<br />
[2020-08-19 21:11:52.858] [LOG]    Line 194 col 3 Parsing error: Unexpected token {<br />
/home/pi/MagicMirror/js/check_config.js:66<br />
throw new Error(“Wrong syntax in config file!”);<br />
^</p>
<p dir="auto">Error: Wrong syntax in config file!<br />
at /home/pi/MagicMirror/js/check_config.js:66:10<br />
at FSReqWrap.readFileAfterClose [as oncomplete] (internal/fs/read_file_context.js:53:3)<br />
npm ERR! code ELIFECYCLE<br />
npm ERR! errno 1<br />
npm ERR! magicmirror@2.12.0 config:check: <code>node js/check_config.js</code><br />
npm ERR! Exit status 1<br />
npm ERR!<br />
npm ERR! Failed at the magicmirror@2.12.0 config:check script.<br />
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.</p>
<p dir="auto">npm ERR! A complete log of this run can be found in:<br />
npm ERR!     /home/pi/.npm/_logs/2020-08-20T02_11_52_899Z-debug.log</p>
<pre><code></code></pre>
]]></description><link>https://forum.magicmirror.builders/post/80383</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/80383</guid><dc:creator><![CDATA[KC5RIL]]></dc:creator><pubDate>Thu, 20 Aug 2020 02:19:37 GMT</pubDate></item><item><title><![CDATA[Reply to Changing compliments on Thu, 20 Aug 2020 01:47:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kc5ril" aria-label="Profile: KC5RIL">@<bdi>KC5RIL</bdi></a> general rules for the value to the right of :</p>
<p dir="auto">numbers and true/false, no quotes,<br />
otherwise needs quotes, doesn’t matter which as long as they are matched.</p>
<p dir="auto">be careful on quotes, these curly ones " ’<br />
are no good, but these text mode are<br />
ok</p>
<pre><code>"'
<p dir="auto">also if the next line starts with a word, then this line needs a trailing comma</p>
]]></description><link>https://forum.magicmirror.builders/post/80382</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/80382</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 20 Aug 2020 01:47:29 GMT</pubDate></item><item><title><![CDATA[Reply to Changing compliments on Thu, 20 Aug 2020 01:38:27 GMT]]></title><description><![CDATA[<p dir="auto">Okay!  It’s coming together for me.  I’m catching a couple more syntax errors.  I’ll keep proofing to see if I catch more.</p>
]]></description><link>https://forum.magicmirror.builders/post/80381</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/80381</guid><dc:creator><![CDATA[KC5RIL]]></dc:creator><pubDate>Thu, 20 Aug 2020 01:38:27 GMT</pubDate></item><item><title><![CDATA[Reply to Changing compliments on Thu, 20 Aug 2020 01:34:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kc5ril" aria-label="Profile: KC5RIL">@<bdi>KC5RIL</bdi></a></p>
<pre><code>position: "lower_third"
<p dir="auto">why did I say?<br />
comma missing on the line before the error</p>
<pre><code>position: "lower_third", // &lt; -----
]]></description><link>https://forum.magicmirror.builders/post/80380</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/80380</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 20 Aug 2020 01:34:00 GMT</pubDate></item><item><title><![CDATA[Reply to Changing compliments on Thu, 20 Aug 2020 01:31:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mykle1" aria-label="Profile: Mykle1">@<bdi>Mykle1</bdi></a> Here’s the code.  Figured this seemed like a popular spot to wet my feet.  If I could get through this, I could set the rest up.</p>
<pre><code>{
			module: "compliments",
			 	   compliments: {
			 	   "....-01-01": [
			 	   "Happy New Year!"
			    	   "....-01-07": [
				   "Happy Birthday, Matt!"
				   "....-01-08": [
				   "Hail to the King, Baby!",
				   "I'm all shook up!",
				   "You ain't nuthin' but a hound dog!"
				   "....-01-25": [
				   "yaD etisoppO yppaH"
				   "2021-02-02": [
				   "It's Groundhog Day \nAgain!"
				   "....-02-14": [
				   "Happy Valentine's Day!"
				   "2021-02-16": [
				   "Laissez les bon temps rouler!"
				   "....-03-14": [
				   "Time for Pi!"
				   "2021-03-17": [
				   "Erin Go Bragh!",
				   "Kiss Me! \nI'm Irish"
				   "....-04-01": [
				   "Your shoes are untied.",
				   "Made you look.",
				   "April Fools!"
				   "2021-04-04": [
				   "Happy Easter!",
				   "Rejoice!",
				   "He is Risen!"
				   "....-05-04": [
				   "May the Fourth be with you!"
				   "....-05-06": [
				   "Revenge of the Sixth!"
				   "....-05-09": [
				   "Happy Mother's Day!"
				   "....-05-25": [
				   "Don't forget your towel.",
				   "42!"
				   "2021-05-31": [
				   "Happy Memorial Day!"
				   "2021-06-20": [
				   "Happy Father's Day!"
				   "....-07-04": [
				   "Celebrate your Independence!",
				   "Freedom!",
				   "Happy Fourth of July!"
				   "....-07-09": [
				   "Happy Birthday, Noodle!"
				   "....-08-14": [
				   "Happy Anniversary!"
				   "2021-09-06": [
				   "Happy Labor Day!"
				   "....-09-11": [
				   "Never Forget.",
				   "Some gave all",
				   "343/61",
				   "Let's Roll!"
				   "...-10-..": [
				   "Boo!"
				   "....-11-16": [
				   "Happy Birthday, Susanne!"
				   "2021-11-25": [
				   "Gobble! Gobble!",
				   "Happy Thanksgiving!"
				   "....-12-07": [
				   "A day that will live in infamy!"
				   "....-12-23": [
				   "Time to air our grievances!",
				   "Festivus for the rest of us!"
				   "....-12-25": [
				   "Merry Christmas, Charlie Brown!",
				   "Rejoice!",
				   "Christ the Savior is born!"
				   anytime: {
				   "Hey!",
				   "Hello.",
				   "Whaddup Dog?",
				   "Dude!",
				   "Hej!",
				   "You stay classy!"
				   morning: [
				   "Good Morning!",
				   "Smile \nIt's a beautiful day!",
				   "Rise and Shine!",
				   "Wakey Wakey! \nEggs &amp; Baky!",
				   "Coffee is ready!"
				   afternoon: [
				   "Is it beer-thirty, yet?",
				   "What a wonderful day!"
				   evening: [
				   "Good Evening."
<p dir="auto">While ya’ll are looking at that, I’ll check the troubleshooting section.  Thanks</p>
]]></description><link>https://forum.magicmirror.builders/post/80379</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/80379</guid><dc:creator><![CDATA[KC5RIL]]></dc:creator><pubDate>Thu, 20 Aug 2020 01:31:52 GMT</pubDate></item><item><title><![CDATA[Reply to Changing compliments on Thu, 20 Aug 2020 01:29:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kc5ril" aria-label="Profile: KC5RIL">@<bdi>KC5RIL</bdi></a> npm config:check can show these errors.</p>
<p dir="auto">has a bug in 2.12, temp fix posted to the top of the troubleshooting section</p>
]]></description><link>https://forum.magicmirror.builders/post/80378</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/80378</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 20 Aug 2020 01:29:06 GMT</pubDate></item><item><title><![CDATA[Reply to Changing compliments on Thu, 20 Aug 2020 01:27:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Stand by, ya’ll.  I’m proofing now.  Just caught a misplaced comma.</p>
]]></description><link>https://forum.magicmirror.builders/post/80377</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/80377</guid><dc:creator><![CDATA[KC5RIL]]></dc:creator><pubDate>Thu, 20 Aug 2020 01:27:32 GMT</pubDate></item><item><title><![CDATA[Reply to Changing compliments on Thu, 20 Aug 2020 01:26:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kc5ril" aria-label="Profile: KC5RIL">@<bdi>KC5RIL</bdi></a> &gt; Unexpected identifier</p>
<p dir="auto">90% of the time this means a comma missing on the line above</p>
]]></description><link>https://forum.magicmirror.builders/post/80376</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/80376</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 20 Aug 2020 01:26:06 GMT</pubDate></item><item><title><![CDATA[Reply to Changing compliments on Thu, 20 Aug 2020 01:24:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kc5ril" aria-label="Profile: KC5RIL">@<bdi>KC5RIL</bdi></a></p>
<p dir="auto">Post your config entry for compliments in a code block</p>
]]></description><link>https://forum.magicmirror.builders/post/80375</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/80375</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Thu, 20 Aug 2020 01:24:15 GMT</pubDate></item><item><title><![CDATA[Reply to Changing compliments on Thu, 20 Aug 2020 01:22:22 GMT]]></title><description><![CDATA[<p dir="auto">Oh, great!  Another noob needs help configuring the Compliments module.  I’ve sussed through this for two days trying to get this up and running to earn ‘cool dad points.’  I’ve followed along and made changes to the config.js file as described.  When I run ‘npm start’ I get the following: ```<br />
code_text</p>
<pre><code class="language-pi@WALL-e:~/MagicMirror">
&gt; magicmirror@2.12.0 start /home/pi/MagicMirror
&gt; DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
[2020-08-19 20:06:47.257] [LOG]    Starting MagicMirror: v2.12.0
[2020-08-19 20:06:47.264] [LOG]    Loading config ...
[2020-08-19 20:06:47.268] [ERROR]  WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: /home/pi/MagicMirror/config/config.js:68
SyntaxError: Unexpected identifier
    at Module._compile (internal/modules/cjs/loader.js:722:23)
    at Object.Module._extensions..js (internal/modules/cjs/loader.js:798:10)
    at Module.load (internal/modules/cjs/loader.js:645:32)
    at Function.Module._load (internal/modules/cjs/loader.js:560:12)
    at Module.require (internal/modules/cjs/loader.js:685:19)
    at require (internal/modules/cjs/helpers.js:16:16)
    at loadConfig (/home/pi/MagicMirror/js/app.js:67:12)
    at App.start (/home/pi/MagicMirror/js/app.js:202:3)
    at Object.&lt;anonymous&gt; (/home/pi/MagicMirror/js/electron.js:126:7)
    at Module._compile (internal/modules/cjs/loader.js:786:30)
[2020-08-19 20:06:47.269] [LOG]    Loading module helpers ...
[2020-08-19 20:06:47.317] [LOG]    Initializing new module helper ...
[2020-08-19 20:06:47.318] [LOG]    Module helper loaded: updatenotification
[2020-08-19 20:06:47.321] [LOG]    No helper found for module: helloworld.
[2020-08-19 20:06:47.322] [LOG]    All module helpers loaded.
[2020-08-19 20:06:47.445] [LOG]    Starting server on port 8080 ...
[2020-08-19 20:06:47.458] [LOG]    Server started ...
[2020-08-19 20:06:47.459] [LOG]    Connecting socket for: updatenotification
[2020-08-19 20:06:47.460] [LOG]    Sockets connected &amp; modules started ...
[2020-08-19 20:06:47.556] [LOG]    Launching application.
<p dir="auto">What am I looking at?  And how can I correct?  Bear with a middle aged noob.  You might have to explain this in crayon.  Thanks for the help.</p>
]]></description><link>https://forum.magicmirror.builders/post/80374</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/80374</guid><dc:creator><![CDATA[KC5RIL]]></dc:creator><pubDate>Thu, 20 Aug 2020 01:22:22 GMT</pubDate></item><item><title><![CDATA[Reply to Changing compliments on Sat, 17 Feb 2018 04:02:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/doublet" aria-label="Profile: doubleT">@<bdi>doubleT</bdi></a>  That worked perfect. Thanks again!</p>
]]></description><link>https://forum.magicmirror.builders/post/35799</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/35799</guid><dc:creator><![CDATA[AliAS]]></dc:creator><pubDate>Sat, 17 Feb 2018 04:02:58 GMT</pubDate></item><item><title><![CDATA[Reply to Changing compliments on Sat, 17 Feb 2018 03:53:44 GMT]]></title><description><![CDATA[<p dir="auto">I see. I’ll give it a try. Thank you very much.</p>
]]></description><link>https://forum.magicmirror.builders/post/35798</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/35798</guid><dc:creator><![CDATA[AliAS]]></dc:creator><pubDate>Sat, 17 Feb 2018 03:53:44 GMT</pubDate></item><item><title><![CDATA[Reply to Changing compliments on Sat, 17 Feb 2018 01:01:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/alias" aria-label="Profile: AliAS">@<bdi>AliAS</bdi></a><br />
Compliments are included via <code>document.createTextNode(complimentText);</code> which doesn’t allow HTML inside.</p>
<p dir="auto">But you can change the line within <code>getDom: function() {}</code> that includes the compliment from<br />
<code>wrapper.appendChild(compliment);</code><br />
to<br />
<code>wrapper.innerHTML = complimentText;</code></p>
<p dir="auto">and then just add a <code>&lt;br /&gt;</code> to the compliment.</p>
]]></description><link>https://forum.magicmirror.builders/post/35793</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/35793</guid><dc:creator><![CDATA[doubleT]]></dc:creator><pubDate>Sat, 17 Feb 2018 01:01:23 GMT</pubDate></item><item><title><![CDATA[Reply to Changing compliments on Fri, 16 Feb 2018 07:53:16 GMT]]></title><description><![CDATA[<p dir="auto">Does anybody know how to use a line break within a compliment? I’ve tried about a dozen different ways to no avail.</p>
]]></description><link>https://forum.magicmirror.builders/post/35763</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/35763</guid><dc:creator><![CDATA[AliAS]]></dc:creator><pubDate>Fri, 16 Feb 2018 07:53:16 GMT</pubDate></item><item><title><![CDATA[Reply to Changing compliments on Fri, 16 Feb 2018 07:51:53 GMT]]></title><description><![CDATA[<p dir="auto">External join file? Lol, thats way outta my league.</p>
]]></description><link>https://forum.magicmirror.builders/post/35762</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/35762</guid><dc:creator><![CDATA[AliAS]]></dc:creator><pubDate>Fri, 16 Feb 2018 07:51:53 GMT</pubDate></item><item><title><![CDATA[Reply to Changing compliments on Sat, 03 Feb 2018 12:45:56 GMT]]></title><description><![CDATA[<p dir="auto">Well done! :-)</p>
]]></description><link>https://forum.magicmirror.builders/post/35163</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/35163</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Sat, 03 Feb 2018 12:45:56 GMT</pubDate></item><item><title><![CDATA[Reply to Changing compliments on Fri, 02 Feb 2018 17:15:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mykle1" aria-label="Profile: Mykle1">@<bdi>Mykle1</bdi></a> Okay. We finally figured it out. We made an external join file for new compliments and that worked. Thank you all SOuch for your help.</p>
]]></description><link>https://forum.magicmirror.builders/post/35123</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/35123</guid><dc:creator><![CDATA[Stacy]]></dc:creator><pubDate>Fri, 02 Feb 2018 17:15:56 GMT</pubDate></item><item><title><![CDATA[Reply to Changing compliments on Fri, 02 Feb 2018 00:59:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/alias" aria-label="Profile: AliAS">@<bdi>AliAS</bdi></a> said in <a href="/post/35081">Changing compliments</a>:</p>
<p dir="auto">Does that sound right?</p>
<p dir="auto">Sure, but another idea would be to rename the non-functioning config (so you don’t lose what’s in it) and THEN make a new copy of the config.js.sample and rename it to config.js. :-)</p>
]]></description><link>https://forum.magicmirror.builders/post/35086</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/35086</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Fri, 02 Feb 2018 00:59:46 GMT</pubDate></item><item><title><![CDATA[Reply to Changing compliments on Thu, 01 Feb 2018 22:05:51 GMT]]></title><description><![CDATA[<p dir="auto">Another suggestion, and someone please correct me if I am wrong, you could delete the config.js file and save as or copy the config-sample.js as a new config.js file. That way you have a functioning config.js. But doing so, you would have to reconfigure all your modules. Does that sound right?</p>
]]></description><link>https://forum.magicmirror.builders/post/35081</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/35081</guid><dc:creator><![CDATA[AliAS]]></dc:creator><pubDate>Thu, 01 Feb 2018 22:05:51 GMT</pubDate></item><item><title><![CDATA[Reply to Changing compliments on Thu, 01 Feb 2018 21:58:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/alias" aria-label="Profile: AliAS">@<bdi>AliAS</bdi></a> remember after locating and fixing the error to hit ctrl + o to save and ctrl + x to exit nano.</p>
]]></description><link>https://forum.magicmirror.builders/post/35080</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/35080</guid><dc:creator><![CDATA[AliAS]]></dc:creator><pubDate>Thu, 01 Feb 2018 21:58:33 GMT</pubDate></item><item><title><![CDATA[Reply to Changing compliments on Thu, 01 Feb 2018 21:56:32 GMT]]></title><description><![CDATA[<p dir="auto">I had a similar problem. It showed an error for my entire addition to the config.js. Run check:config again and pay close attention to the beginning of the output. The first error should say something about expecting a bracket of one kind and it was returned a bracket of a different kind. It will also tell you the line of the error. Now nano back into config scroll down to your addition and press ctrl + c. The bottom of your screen should give you your current line number. Find the error. Mine was a missing bracket. Fixing this error fixed the entire script. All other errors were the result of the first. Sorry if I wasn’t clear or missed something, im still a new to this too. Hope it helps.</p>
]]></description><link>https://forum.magicmirror.builders/post/35079</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/35079</guid><dc:creator><![CDATA[AliAS]]></dc:creator><pubDate>Thu, 01 Feb 2018 21:56:32 GMT</pubDate></item><item><title><![CDATA[Reply to Changing compliments on Thu, 01 Feb 2018 18:22:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/doublet" aria-label="Profile: doubleT">@<bdi>doubleT</bdi></a> I save from the terminal with ctrl o. Have also tried ctrl x, y.</p>
<p dir="auto">When I get to the folders through the GUI, I can change the file and save it. I have uncomment ed the calendar, and moved things around, but when I add the configure script for new compliments I get the error message need a config file. I checked it using a terminal command someone gave me here and every line that I added it did not like, even though my code was exactly like the example.</p>
<p dir="auto">Weird. However, I am learning a lot troubleshooting this issue and I appreciate all the help.</p>
]]></description><link>https://forum.magicmirror.builders/post/35066</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/35066</guid><dc:creator><![CDATA[Stacy]]></dc:creator><pubDate>Thu, 01 Feb 2018 18:22:49 GMT</pubDate></item></channel></rss>
