<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Maximum File Size of ics FIle?]]></title><description><![CDATA[<p dir="auto">Hey everyone,</p>
<p dir="auto">i stumbled over the MagicMirror Project almost a year ago and was already then hooked!<br />
I am now currently building my own, but i got a problem with the Calender plugin.</p>
<p dir="auto">My main Google Calender won’t load. All i get is “Loading…”<br />
I tried to open the FIle via Chrome and it imediatly downloaded it (<a href="https://calendar.google.com/calendar/ical/myname%40gmail.com/private-key/basic.ics" target="_blank" rel="noopener noreferrer nofollow ugc">https://calendar.google.com/calendar/ical/myname%40gmail.com/private-key/basic.ics</a>).</p>
<p dir="auto">The file size is 1,35MB - is this a problem for the mirror? Because any other File (like a Holiday ics from the web with 27KB or even my quick created test gmail account with only one appointment) will load and display the events on the mirror…</p>
<p dir="auto">Is there any way to fix this?</p>
<p dir="auto">I’m running the newest version of the MagicMirror on a Raspi 3<br />
PRETTY_NAME=“Raspbian GNU/Linux 9 (stretch)”<br />
NAME=“Raspbian GNU/Linux”<br />
VERSION_ID=“9”<br />
VERSION=“9 (stretch)”</p>
<p dir="auto">Any help is apreciated - even if it is a workaround…<br />
Thanks!</p>
]]></description><link>https://forum.magicmirror.builders/topic/6480/maximum-file-size-of-ics-file</link><generator>RSS for Node</generator><lastBuildDate>Tue, 09 Jun 2026 05:55:51 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/6480.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 31 Jan 2018 19:02:54 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Maximum File Size of ics FIle? on Tue, 06 Feb 2018 01:23:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/stef" aria-label="Profile: Stef">@<bdi>Stef</bdi></a> That’s awesome, congrats. Thanks for letting us know!</p>
<p dir="auto">If anything, comment on <a class="plugin-mentions-user plugin-mentions-a" href="/user/beh" aria-label="Profile: Beh">@<bdi>Beh</bdi></a>’s post with any edits or additions you suggest to help others.</p>
<p dir="auto">Cheers!</p>
]]></description><link>https://forum.magicmirror.builders/post/35303</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/35303</guid><dc:creator><![CDATA[ninjabreadman]]></dc:creator><pubDate>Tue, 06 Feb 2018 01:23:57 GMT</pubDate></item><item><title><![CDATA[Reply to Maximum File Size of ics FIle? on Mon, 05 Feb 2018 21:23:32 GMT]]></title><description><![CDATA[<p dir="auto">Uhoh… i almost forgot:<br />
It all works like a charme now!</p>
<p dir="auto">Thank you <a class="plugin-mentions-user plugin-mentions-a" href="/user/ninjabreadman" aria-label="Profile: ninjabreadman">@<bdi>ninjabreadman</bdi></a>!</p>
<p dir="auto">…Maybe i will write a litlle howto… but after all it was pretty straight forward.</p>
<p dir="auto">This Thread can be closed now.</p>
]]></description><link>https://forum.magicmirror.builders/post/35287</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/35287</guid><dc:creator><![CDATA[Stef]]></dc:creator><pubDate>Mon, 05 Feb 2018 21:23:32 GMT</pubDate></item><item><title><![CDATA[Reply to Maximum File Size of ics FIle? on Sat, 03 Feb 2018 21:53:19 GMT]]></title><description><![CDATA[<p dir="auto">YES! Thanks!<br />
I didn’t realised that…</p>
]]></description><link>https://forum.magicmirror.builders/post/35194</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/35194</guid><dc:creator><![CDATA[Stef]]></dc:creator><pubDate>Sat, 03 Feb 2018 21:53:19 GMT</pubDate></item><item><title><![CDATA[Reply to Maximum File Size of ics FIle? on Sat, 03 Feb 2018 21:25:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/stef" aria-label="Profile: Stef">@<bdi>Stef</bdi></a> Ah, i think you have the symlink to <code>vdirsyncer</code> but not the hidden folder, <code>.vdirsyncer</code> (in your home folder) for config options.</p>
<p dir="auto">Type <code>mkdir ~/.vdirsyncer</code> then try again to create the config file.</p>
]]></description><link>https://forum.magicmirror.builders/post/35193</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/35193</guid><dc:creator><![CDATA[ninjabreadman]]></dc:creator><pubDate>Sat, 03 Feb 2018 21:25:31 GMT</pubDate></item><item><title><![CDATA[Reply to Maximum File Size of ics FIle? on Sat, 03 Feb 2018 21:18:53 GMT]]></title><description><![CDATA[<p dir="auto">Yes i know :(<br />
But everytime i enter</p>
<p dir="auto">touch ~/.vdirsyncer/config</p>
<p dir="auto">i get, that it can’t find the directory…<br />
(" touch: ‘/home/pi/.vdirsyncer/config’ kann nicht ber▒hrt werden: Datei oder Verzeichnis nicht gefunden")</p>
]]></description><link>https://forum.magicmirror.builders/post/35192</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/35192</guid><dc:creator><![CDATA[Stef]]></dc:creator><pubDate>Sat, 03 Feb 2018 21:18:53 GMT</pubDate></item><item><title><![CDATA[Reply to Maximum File Size of ics FIle? on Sat, 03 Feb 2018 21:17:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/stef" aria-label="Profile: Stef">@<bdi>Stef</bdi></a> You first need to create the config file (i.e. via <code>touch</code>):</p>
<pre><code>touch ~/.vdirsyncer/config
nano ~/.vdirsyncer/config
<p dir="auto">Yes, <code>.vdirsyncer</code> exists, but <code>config</code> doesn’t (yet).</p>
]]></description><link>https://forum.magicmirror.builders/post/35191</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/35191</guid><dc:creator><![CDATA[ninjabreadman]]></dc:creator><pubDate>Sat, 03 Feb 2018 21:17:26 GMT</pubDate></item><item><title><![CDATA[Reply to Maximum File Size of ics FIle? on Sat, 03 Feb 2018 21:09:24 GMT]]></title><description><![CDATA[<p dir="auto">Ok… I am stuck…</p>
<p dir="auto">The Google API creation wasn’t a problem, and installing the vdirsyncer worked well also.</p>
<p dir="auto">But now i am supposed to create a conifg file in ~/.vdirsyncer/config - but i get an error everytime, that this File or Folder can’t be found…</p>
<p dir="auto">If i run ls -l in usr/bin, i get the following output:<br />
lrwxrwxrwx 1 root root          30 Feb  3 21:32 vdirsyncer -&gt; /home/pi/.local/bin/vdirsyncer</p>
<p dir="auto">So… it is an folder… but why can’t i access it??<br />
Am i missing something?</p>
<p dir="auto">thanks!</p>
]]></description><link>https://forum.magicmirror.builders/post/35190</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/35190</guid><dc:creator><![CDATA[Stef]]></dc:creator><pubDate>Sat, 03 Feb 2018 21:09:24 GMT</pubDate></item><item><title><![CDATA[Reply to Maximum File Size of ics FIle? on Fri, 02 Feb 2018 20:33:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ninjabreadman" aria-label="Profile: ninjabreadman">@<bdi>ninjabreadman</bdi></a> (nice name btw)<br />
Thanks for your headsup.<br />
Yes this is directly from Google.<br />
Unfortuantley, adding the start/end dates won’t work. It seems to me, that i have to make my calendar public, in order to use this… and i do not want this.</p>
<p dir="auto">I’ll try to find the time to check out your other Hint with vdirsyncer. Looks easy enough.</p>
<p dir="auto">I’ll keep you posted!</p>
<p dir="auto">Thanks and a nice weekend</p>
]]></description><link>https://forum.magicmirror.builders/post/35133</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/35133</guid><dc:creator><![CDATA[Stef]]></dc:creator><pubDate>Fri, 02 Feb 2018 20:33:25 GMT</pubDate></item><item><title><![CDATA[Reply to Maximum File Size of ics FIle? on Thu, 01 Feb 2018 13:05:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/stef" aria-label="Profile: Stef">@<bdi>Stef</bdi></a> Just checked, and my largest calendar is 425Kb, so I can’t say what is “too big”.</p>
<p dir="auto">Is this from an online service like Google or Outlook? You may be able to use query parameters to <a href="https://wiki.mq.edu.au/display/wiki/How+to+set+the+date+range+in+a+Google+calendar" target="_blank" rel="noopener noreferrer nofollow ugc">specify start/end dates</a> (edit: <a href="https://stackoverflow.com/questions/21322221/google-calendar-feed-timemin-timemax-not-working" target="_blank" rel="noopener noreferrer nofollow ugc">more detailed description and API links here</a>) for your query to return fewer results. If not,  apparently some CalDAV servers (like DAVDroid) also allow you to pass parameters for start/end dates for the calendar. You can then create a query to (e.g.) only return events for this month and next.</p>
<p dir="auto">Alternatively, you might instead look at <a href="https://forum.magicmirror.builders/topic/5327/sync-private-icloud-calendar-with-magicmirror">this post</a>. You may have to change the config for whatever service you’re using, but in <code>vdirsyncer</code> you can set <code>start_date</code> and <code>end_date</code> options which should slice your calendar into something reasonable that you can then serve locally from your Pi. It’s not as simple as pointing a module at a URL, but once set up with a <code>cron</code> job should be pretty reliable.</p>
]]></description><link>https://forum.magicmirror.builders/post/35053</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/35053</guid><dc:creator><![CDATA[ninjabreadman]]></dc:creator><pubDate>Thu, 01 Feb 2018 13:05:28 GMT</pubDate></item></channel></rss>
