<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Make a mirror a touch mirror]]></title><description><![CDATA[<p dir="auto">Hi</p>
<p dir="auto">I have seen a lot of posts around making a mirror touch.</p>
<p dir="auto">1: over the mirror</p>
<p dir="auto">Infrared touch it frame: it implies to add over the mirror 4 infrared parts around the mirror. It can be multitouch and easy to put in place. The mirror glass will replace the glass provided with</p>
<p dir="auto">2: Between the mirror and the screen</p>
<p dir="auto">Reactive touch panel: the reactive touch panel will need to be over the monitor and I will need to add a two way mirror film. It s easy to put in place but I could not use a real two way mirror and it could not be multitouch. In the end the touch experience will be less smooth than a capacitive touch panel. So I will<br />
Need mirror two way film, réactive touch panel and the monitor…</p>
<p dir="auto">Capacitive touch: it is not working with a real twi way mirror because of the metal. Then I will need to use in the order a two way mirror film + a glass and the monitor. Maybe some two way mirrors are existing without metal… finally the capacitive touch is much more reactive and smooth and can be multitouch.</p>
<p dir="auto">Did I miss some points or is that correct?</p>
<p dir="auto">Are there other solutions?</p>
<p dir="auto">Thanks</p>
]]></description><link>https://forum.magicmirror.builders/topic/6539/make-a-mirror-a-touch-mirror</link><generator>RSS for Node</generator><lastBuildDate>Mon, 08 Jun 2026 04:39:35 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/6539.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 10 Feb 2018 09:29:15 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Make a mirror a touch mirror on Sat, 10 Feb 2018 12:37:37 GMT]]></title><description><![CDATA[<p dir="auto">hi<br />
there seems to be a company that produces two way mirrors that work with multi touch touch overlays<br />
<a href="https://www.twowaymirrors.com/smart-mirror/" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.twowaymirrors.com/smart-mirror/</a><br />
although I have not tested them</p>
<p dir="auto">But I guess IR Touch frames are the cheapest option</p>
<p dir="auto">Max</p>
]]></description><link>https://forum.magicmirror.builders/post/35450</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/35450</guid><dc:creator><![CDATA[maxbachmann]]></dc:creator><pubDate>Sat, 10 Feb 2018 12:37:37 GMT</pubDate></item></channel></rss>
