<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[newsfeed gives an error]]></title><description><![CDATA[<p dir="auto">Hi all,</p>
<p dir="auto">i get an error with the newsfeed modul. I look in the logfile with ‘pm2 logs’ and i see this error:</p>
<pre><code>mm-0 Get league table for url http://api.football-data.org/v1/competitions/430/leagueTable
mm-0 Can't parse feed item:
mm-0 { text: '\n\n\n\n\n\n',
mm-0   title: '',
mm-0   link: { href: 'http://www.tagesschau.de' },
mm-0   id: 'http://www.tagesschau.de',
mm-0   updated: '',
mm-0   summary: '' }
mm-0 Title:
mm-0 Description:
mm-0 Pubdate:
mm-0 Whoops! There was an uncaught exception...
mm-0 TypeError: parser.close is not a function
mm-0     at SAXStream.openf1 (/home/pi/MagicMirror/node_modules/feedme/lib/xmlfeedparser.js:107:14)
mm-0     at emitOne (events.js:96:13)
mm-0     at SAXStream.emit (events.js:188:7)
mm-0     at Object.me._parser.(anonymous function) [as onopentag] (/home/pi/MagicMirror/node_modules/sax/lib/sax.js:258:17)
mm-0     at emit (/home/pi/MagicMirror/node_modules/sax/lib/sax.js:640:35)
mm-0     at emitNode (/home/pi/MagicMirror/node_modules/sax/lib/sax.js:645:5)
mm-0     at openTag (/home/pi/MagicMirror/node_modules/sax/lib/sax.js:841:5)
mm-0     at Object.write (/home/pi/MagicMirror/node_modules/sax/lib/sax.js:1404:13)
mm-0     at SAXStream.write (/home/pi/MagicMirror/node_modules/sax/lib/sax.js:239:18)
mm-0     at yoshi.write (/home/pi/MagicMirror/node_modules/feedme/lib/feedme.js:41:14)
mm-0 MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
mm-0 If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
<p dir="auto">A few lines is the fact that the system is deprecated.</p>
<p dir="auto">Had any one else these Errors?</p>
<p dir="auto">Best regards<br />
Daniel</p>
<hr />
<p dir="auto"><strong>Note from admin:</strong> Please use <a href="https://github.com/adam-p/markdown-here/wiki/Markdown-Cheatsheet#code" target="_blank" rel="noopener noreferrer nofollow ugc">Markdown</a> on code snippets for easier reading!</p>
]]></description><link>https://forum.magicmirror.builders/topic/655/newsfeed-gives-an-error</link><generator>RSS for Node</generator><lastBuildDate>Thu, 21 May 2026 20:51:22 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/655.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 18 Sep 2016 07:32:42 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to newsfeed gives an error on Sun, 18 Sep 2016 09:36:48 GMT]]></title><description><![CDATA[<p dir="auto">oh thanks… heise produce the error… :-(</p>
]]></description><link>https://forum.magicmirror.builders/post/4963</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/4963</guid><dc:creator><![CDATA[ostfilinchen]]></dc:creator><pubDate>Sun, 18 Sep 2016 09:36:48 GMT</pubDate></item><item><title><![CDATA[Reply to newsfeed gives an error on Tue, 27 Sep 2016 21:04:35 GMT]]></title><description><![CDATA[<p dir="auto">I don’t think the error Comes from the Soccer module. Here is the new log from pm2:</p>
<pre><code>mm-0 starting internet monitor node helper
mm-0 Create new news fetcher for url: http://www.heise.de/security/news/news-top-atom.xml - Interval: 300000
mm-0 Create new news fetcher for url: http://www.n-tv.de/rss - Interval: 300000
<hr />
]]></description><link>https://forum.magicmirror.builders/post/4960</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/4960</guid><dc:creator><![CDATA[ostfilinchen]]></dc:creator><pubDate>Tue, 27 Sep 2016 21:04:35 GMT</pubDate></item></channel></rss>
