<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[TypeError: Cannot read property 'hash' of null]]></title><description><![CDATA[<p dir="auto">Hey Guys. Whats the Problem?</p>
<p dir="auto">TypeError: Cannot read property ‘hash’ of null<br />
at /home/pi/MagicMirror/modules/default/updatenotification/node_helper.js:68:31<br />
at Git. (/home/pi/MagicMirror/node_modules/simple-git/src/git.js:1482:10)<br />
at done (/home/pi/MagicMirror/node_modules/simple-git/src/git.js:1354:21)<br />
at ChildProcess. (/home/pi/MagicMirror/node_modules/simple-git/src/git.js:1379:16)<br />
at emitTwo (events.js:106:13)<br />
at ChildProcess.emit (events.js:191:7)<br />
at Process.ChildProcess._handle.onexit (internal/child_process.js:219:12)<br />
MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?<br />
If you think this really is an issue, please open an issue on GitHub: <a href="https://github.com/MichMich/MagicMirror/issues" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/MichMich/MagicMirror/issues</a></p>
]]></description><link>https://forum.magicmirror.builders/topic/6574/typeerror-cannot-read-property-hash-of-null</link><generator>RSS for Node</generator><lastBuildDate>Sat, 15 Aug 2026 06:24:06 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/6574.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 13 Feb 2018 15:52:41 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to TypeError: Cannot read property 'hash' of null on Tue, 13 Feb 2018 17:12:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/robodoc" aria-label="Profile: RoboDoc">@<bdi>RoboDoc</bdi></a> said in <a href="/post/35649">TypeError: Cannot read property ‘hash’ of null</a>:</p>
<p dir="auto">at /home/pi/MagicMirror/modules/default/updatenotification/node_helper.js:68:31</p>
<p dir="auto">line 68 in the node_helper of the update notification seems to check all modules on GitHub for updates, if i understand that correctly…</p>
<p dir="auto">So there are two options:</p>
<ol>
<li>
<p dir="auto">Your mirror lost it’s wifi/internet connection. Maybe u could check on your router if the device had logged off from the wifi.<br />
Or check the strength of the connection. Maybe take a look at the wifi_rebooter, as the wifi on the RPi 3 is not the best. So i installed an automatically wifi_rebooter here. U could try that as well: <a href="http://alexba.in/blog/2015/01/14/automatically-reconnecting-wifi-on-a-raspberrypi/" target="_blank" rel="noopener noreferrer nofollow ugc">http://alexba.in/blog/2015/01/14/automatically-reconnecting-wifi-on-a-raspberrypi/</a><br />
in my case my Pi pings my router address every 3 minutes and when it cannot reach it, it reboots it’s wifi itself.</p>
</li>
<li>
<p dir="auto">Some of the 3rd party modules has errors. But i don’t think so. To check it u could just run the default modules for a while</p>
</li>
</ol>
]]></description><link>https://forum.magicmirror.builders/post/35655</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/35655</guid><dc:creator><![CDATA[cruunnerr]]></dc:creator><pubDate>Tue, 13 Feb 2018 17:12:40 GMT</pubDate></item><item><title><![CDATA[Reply to TypeError: Cannot read property 'hash' of null on Tue, 13 Feb 2018 16:51:32 GMT]]></title><description><![CDATA[<p dir="auto">Whoops! There was an uncaught exception…<br />
at Process.ChildProcess._handle.onexit (internal/child_process.js:215:12)<br />
<p dir="auto">–</p>
<p dir="auto">I get the same error message. I tried adjusting the reloadInterval-values, but it didn’t help much. Everything seems to work okay for a while, then after 8-10 error messages (appx 1-2 hrs), like the one above, MM suddenly shuts down. Haven’t started MM in debug mode, yet.</p>
<p dir="auto">I run a newly installed system, with fresh &amp; updated Raspian (4.9.59-v7), MM, and a couple of modules - none of which throws any errors on startup. (Modules: alert, calendar, clock, currentweather, newsfeed, weatherforecast, updatenotification, MMM-GoogleMapsTraffic, MMM-Nest and calendar_monthly).</p>
]]></description><link>https://forum.magicmirror.builders/post/35649</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/35649</guid><dc:creator><![CDATA[RoboDoc]]></dc:creator><pubDate>Tue, 13 Feb 2018 16:51:32 GMT</pubDate></item></channel></rss>
