<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Whitescreen after Reboot]]></title><description><![CDATA[<p dir="auto">After rebooting my R PI 3 i got a whitescreen and a problem with electron:</p>
<p dir="auto">Error log:</p>
<pre><code>pi@raspberrypi:~/MagicMirror $ tail -f  /home/pi/.pm2/logs/mm-error-0.log
npm verb cli [ '/usr/local/bin/node', '/usr/local/bin/npm', 'start' ]
npm info using npm@3.8.3
npm info using node@v5.10.1
npm verb run-script [ 'prestart', 'start', 'poststart' ]
npm info lifecycle magicmirror@2.0.0~prestart: magicmirror@2.0.0
npm sill lifecycle magicmirror@2.0.0~prestart: no script for prestart, continuing
npm info lifecycle magicmirror@2.0.0~start: magicmirror@2.0.0
WARNING! Could not find config. Please create one.
App threw an error when running [ReferenceError: Log is not defined]
<hr />
<p dir="auto"><strong>Note from admin:</strong> Please use Markdown for your code/shell snippets so it is easier to read!</p>
]]></description><link>https://forum.magicmirror.builders/topic/66/whitescreen-after-reboot</link><generator>RSS for Node</generator><lastBuildDate>Wed, 15 Apr 2026 22:58:06 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/66.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 10 May 2016 15:51:29 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Whitescreen after Reboot on Tue, 10 May 2016 17:50:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/michmich" aria-label="Profile: MichMich">@<bdi>MichMich</bdi></a>, oooooh. I was about to start a new topic and demand access to those <code>'frowned'</code> modules! :)</p>
]]></description><link>https://forum.magicmirror.builders/post/411</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/411</guid><dc:creator><![CDATA[KirAsh4]]></dc:creator><pubDate>Tue, 10 May 2016 17:50:59 GMT</pubDate></item><item><title><![CDATA[Reply to Whitescreen after Reboot on Tue, 10 May 2016 17:47:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kirash4" aria-label="Profile: KirAsh4">@<bdi>KirAsh4</bdi></a> Lol … those are modules that are modified by my auto correct… ;)</p>
]]></description><link>https://forum.magicmirror.builders/post/410</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/410</guid><dc:creator><![CDATA[MichMich]]></dc:creator><pubDate>Tue, 10 May 2016 17:47:21 GMT</pubDate></item><item><title><![CDATA[Reply to Whitescreen after Reboot on Tue, 10 May 2016 17:42:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/michmich" aria-label="Profile: MichMich">@<bdi>MichMich</bdi></a>, uh, een momentje, but what are <code>'frowned modules'</code> ? </p>
]]></description><link>https://forum.magicmirror.builders/post/409</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/409</guid><dc:creator><![CDATA[KirAsh4]]></dc:creator><pubDate>Tue, 10 May 2016 17:42:58 GMT</pubDate></item><item><title><![CDATA[Reply to Whitescreen after Reboot on Tue, 10 May 2016 17:35:14 GMT]]></title><description><![CDATA[<p dir="auto">Thx, i got it.</p>
<p dir="auto">This module was using the log.log function</p>
<p dir="auto"><a href="https://github.com/SamLewis0602/MMM-Traffic?files=1" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/SamLewis0602/MMM-Traffic?files=1</a></p>
]]></description><link>https://forum.magicmirror.builders/post/407</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/407</guid><dc:creator><![CDATA[Bangee]]></dc:creator><pubDate>Tue, 10 May 2016 17:35:14 GMT</pubDate></item><item><title><![CDATA[Reply to Whitescreen after Reboot on Tue, 10 May 2016 17:24:01 GMT]]></title><description><![CDATA[<p dir="auto">Btw, thats weird. Since it has no config. it should only load the hello world module. Which doesn’t use Log. :-/</p>
]]></description><link>https://forum.magicmirror.builders/post/406</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/406</guid><dc:creator><![CDATA[MichMich]]></dc:creator><pubDate>Tue, 10 May 2016 17:24:01 GMT</pubDate></item><item><title><![CDATA[Reply to Whitescreen after Reboot on Tue, 10 May 2016 17:46:57 GMT]]></title><description><![CDATA[<p dir="auto">There is something wrong with your installation. Since it can’t find your config file.</p>
<p dir="auto">And, somehow you’re using a module that uses the Log.log function in a node_helper. Log.log is only available in the <s>frowned</s> default modules.</p>
]]></description><link>https://forum.magicmirror.builders/post/405</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/405</guid><dc:creator><![CDATA[MichMich]]></dc:creator><pubDate>Tue, 10 May 2016 17:46:57 GMT</pubDate></item></channel></rss>
