<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Volume issue on MMM-GoogleAssistant module]]></title><description><![CDATA[<p dir="auto">Hi folks,<br />
I don’t know why, but my MMM-GoogleAssistant’s volume does not correspond to the system volume. The GoogleAssistant (gauravsacc/MMM-GoogleAssistant) answers me very quietly.  How to increase the volume of the module?<br />
Thank you in advance!<br />
Best,<br />
Aro28</p>
]]></description><link>https://forum.magicmirror.builders/topic/6611/volume-issue-on-mmm-googleassistant-module</link><generator>RSS for Node</generator><lastBuildDate>Thu, 08 Oct 2026 04:18:05 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/6611.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 19 Feb 2018 20:00:49 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Volume issue on MMM-GoogleAssistant module on Wed, 21 Feb 2018 12:28:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/aro28" aria-label="Profile: aro28">@<bdi>aro28</bdi></a> That didn’t work on mine. I suspect you would need to go into alsamixer, locate your playback device’s configuration and adjust the default volume there.</p>
]]></description><link>https://forum.magicmirror.builders/post/36055</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/36055</guid><dc:creator><![CDATA[Cyberwrights]]></dc:creator><pubDate>Wed, 21 Feb 2018 12:28:21 GMT</pubDate></item><item><title><![CDATA[Reply to Volume issue on MMM-GoogleAssistant module on Wed, 21 Feb 2018 05:08:17 GMT]]></title><description><![CDATA[<p dir="auto">Yes. It works.<br />
Thanks!</p>
]]></description><link>https://forum.magicmirror.builders/post/36040</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/36040</guid><dc:creator><![CDATA[aro28]]></dc:creator><pubDate>Wed, 21 Feb 2018 05:08:17 GMT</pubDate></item><item><title><![CDATA[Reply to Volume issue on MMM-GoogleAssistant module on Tue, 20 Feb 2018 07:52:55 GMT]]></title><description><![CDATA[<p dir="auto">Thanks! <a class="plugin-mentions-user plugin-mentions-a" href="/user/d3r" aria-label="Profile: d3r">@<bdi>d3r</bdi></a><br />
Will try to do that once back to home.<br />
Best,</p>
]]></description><link>https://forum.magicmirror.builders/post/35965</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/35965</guid><dc:creator><![CDATA[aro28]]></dc:creator><pubDate>Tue, 20 Feb 2018 07:52:55 GMT</pubDate></item><item><title><![CDATA[Reply to Volume issue on MMM-GoogleAssistant module on Tue, 20 Feb 2018 04:03:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/aro28" aria-label="Profile: aro28">@<bdi>aro28</bdi></a> “Ok google, set volume to max” should do it</p>
]]></description><link>https://forum.magicmirror.builders/post/35957</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/35957</guid><dc:creator><![CDATA[d3r]]></dc:creator><pubDate>Tue, 20 Feb 2018 04:03:06 GMT</pubDate></item></channel></rss>
