<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Magic Mirror 2 on Raspberry Pi 3 - Wifi shutting down!]]></title><description><![CDATA[<p dir="auto">Hi guys,</p>
<p dir="auto">I installed magi mirror on my rpi3 (jessie) and every thig works well until the wifi randomly goes down.</p>
<p dir="auto"><img src="/assets/uploads/files/1519112970320-63b4d313-13c9-42d1-ab1e-2d35c8fcf22c-grafik.png" alt="0_1519112969586_63b4d313-13c9-42d1-ab1e-2d35c8fcf22c-grafik.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">The rpi3 is still alive but I cannot reach it over SSH.</p>
<p dir="auto">I set the wifi power management to off and I followed all indication/tutorials. But I cannot solve this problem.</p>
<p dir="auto">Can you help me some expert with a workaround or a tip?</p>
<p dir="auto">Thank you very much.</p>
<p dir="auto">Best regards,<br />
Noro</p>
]]></description><link>https://forum.magicmirror.builders/topic/6616/magic-mirror-2-on-raspberry-pi-3-wifi-shutting-down</link><generator>RSS for Node</generator><lastBuildDate>Fri, 05 Jun 2026 23:01:08 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/6616.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 20 Feb 2018 07:50:30 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Magic Mirror 2 on Raspberry Pi 3 - Wifi shutting down! on Tue, 20 Feb 2018 09:19:14 GMT]]></title><description><![CDATA[<p dir="auto">I disabled the wifi power saving. I will setup the script in crontab to check the connection as you suggested. Thank you.</p>
Noro</p>
]]></description><link>https://forum.magicmirror.builders/post/35970</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/35970</guid><dc:creator><![CDATA[noro]]></dc:creator><pubDate>Tue, 20 Feb 2018 09:19:14 GMT</pubDate></item><item><title><![CDATA[Reply to Magic Mirror 2 on Raspberry Pi 3 - Wifi shutting down! on Tue, 20 Feb 2018 09:10:39 GMT]]></title><description><![CDATA[<p dir="auto">Did you follow the guidelines for disabling wifi power saving mode?<br />
If it still fails, you could follow this approach: <a href="http://alexba.in/blog/2015/01/14/automatically-reconnecting-wifi-on-a-raspberrypi/" target="_blank" rel="noopener noreferrer nofollow ugc">http://alexba.in/blog/2015/01/14/automatically-reconnecting-wifi-on-a-raspberrypi/</a><br />
Maybe replace the ip with the ip of your router to ping a local device in case internet connection dropped at that point.</p>
]]></description><link>https://forum.magicmirror.builders/post/35969</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/35969</guid><dc:creator><![CDATA[yawns]]></dc:creator><pubDate>Tue, 20 Feb 2018 09:10:39 GMT</pubDate></item></channel></rss>
