<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[HMDI (from Pi 3) to DVI?  Will it work?]]></title><description><![CDATA[<p dir="auto">Will the <a href="http://www.newegg.com/Product/Product.aspx?Item=N82E16824262011" target="_blank" rel="noopener noreferrer nofollow ugc">HANNspree HF225DPB </a> monitor work for the Magic Mirror application?</p>
<p dir="auto">It doesn’t have an HDMI input, but could I just use an HDMI to DVI cable to connect the Pi 3 to the monitor?</p>
<p dir="auto">Thanks!</p>
]]></description><link>https://forum.magicmirror.builders/topic/662/hmdi-from-pi-3-to-dvi-will-it-work</link><generator>RSS for Node</generator><lastBuildDate>Wed, 07 Oct 2026 19:07:54 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/662.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 19 Sep 2016 12:03:30 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to HMDI (from Pi 3) to DVI?  Will it work? on Sat, 19 Nov 2016 21:29:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bibi" aria-label="Profile: bibi">@<bdi>bibi</bdi></a> display port to hdmi works definitely. it’s both digital, so the adapter should be pretty simple and cheap (I use one for ~12€ from miniDP to HDMI on my laptop)</p>
]]></description><link>https://forum.magicmirror.builders/post/8245</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/8245</guid><dc:creator><![CDATA[dbahn25]]></dc:creator><pubDate>Sat, 19 Nov 2016 21:29:45 GMT</pubDate></item><item><title><![CDATA[Reply to HMDI (from Pi 3) to DVI?  Will it work? on Mon, 24 Oct 2016 16:40:26 GMT]]></title><description><![CDATA[<p dir="auto">in the same idea an adaptor display port &gt; hdmi would also work no? anyone has tried this ?</p>
]]></description><link>https://forum.magicmirror.builders/post/6808</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/6808</guid><dc:creator><![CDATA[bibi]]></dc:creator><pubDate>Mon, 24 Oct 2016 16:40:26 GMT</pubDate></item><item><title><![CDATA[Reply to HMDI (from Pi 3) to DVI?  Will it work? on Tue, 20 Sep 2016 11:12:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mcsorley" aria-label="Profile: McSorley">@<bdi>McSorley</bdi></a> <a class="plugin-mentions-user plugin-mentions-a" href="/user/yawns" aria-label="Profile: yawns">@<bdi>yawns</bdi></a> thank you guys! The blue one looks exactly like something I discovered in my local shop, so it’s solved, thank you!</p>
]]></description><link>https://forum.magicmirror.builders/post/5082</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/5082</guid><dc:creator><![CDATA[indigomejor]]></dc:creator><pubDate>Tue, 20 Sep 2016 11:12:02 GMT</pubDate></item><item><title><![CDATA[Reply to HMDI (from Pi 3) to DVI?  Will it work? on Tue, 20 Sep 2016 11:08:15 GMT]]></title><description><![CDATA[<p dir="auto">Right, you need an active HDMI-VGA converter.</p>
<p dir="auto">You could go for this: <a href="https://thepihut.com/products/raspberry-pi-hdmi-to-vga-convertor" target="_blank" rel="noopener noreferrer nofollow ugc">https://thepihut.com/products/raspberry-pi-hdmi-to-vga-convertor</a><br />
However the “chain” looks a bit ugly (second image) and I could imagine it is a bit unsteady.</p>
<p dir="auto">Or you go for this: <a href="https://www.pi-supply.com/product/gert-vga-666-hardware-vga-raspberry-pi/" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.pi-supply.com/product/gert-vga-666-hardware-vga-raspberry-pi/</a><br />
However this blocks almost all GPIO ports and you need to solder it on your own, as it is a kit</p>
]]></description><link>https://forum.magicmirror.builders/post/5081</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/5081</guid><dc:creator><![CDATA[yawns]]></dc:creator><pubDate>Tue, 20 Sep 2016 11:08:15 GMT</pubDate></item><item><title><![CDATA[Reply to HMDI (from Pi 3) to DVI?  Will it work? on Tue, 20 Sep 2016 10:54:12 GMT]]></title><description><![CDATA[<p dir="auto">Dont get a straight VGA to HDMI cable because it wouldnt work. You would need convertor which is a bit larger than you would expect and often need to be powered.</p>
]]></description><link>https://forum.magicmirror.builders/post/5080</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/5080</guid><dc:creator><![CDATA[McSorley]]></dc:creator><pubDate>Tue, 20 Sep 2016 10:54:12 GMT</pubDate></item><item><title><![CDATA[Reply to HMDI (from Pi 3) to DVI?  Will it work? on Tue, 20 Sep 2016 10:41:41 GMT]]></title><description><![CDATA[<p dir="auto">Hi, will work VGA cable with HDMI adapter? Thank you very much!</p>
]]></description><link>https://forum.magicmirror.builders/post/5079</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/5079</guid><dc:creator><![CDATA[indigomejor]]></dc:creator><pubDate>Tue, 20 Sep 2016 10:41:41 GMT</pubDate></item><item><title><![CDATA[Reply to HMDI (from Pi 3) to DVI?  Will it work? on Mon, 19 Sep 2016 23:03:03 GMT]]></title><description><![CDATA[<p dir="auto">I have a DVI right angle adapter with a DVI to HDMI Cable.</p>
]]></description><link>https://forum.magicmirror.builders/post/5052</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/5052</guid><dc:creator><![CDATA[McSorley]]></dc:creator><pubDate>Mon, 19 Sep 2016 23:03:03 GMT</pubDate></item><item><title><![CDATA[Reply to HMDI (from Pi 3) to DVI?  Will it work? on Mon, 19 Sep 2016 20:54:50 GMT]]></title><description><![CDATA[<p dir="auto">that’s what I am doing. I was using an adapter for initial testing, then I bought a HDMI to DVD cable from amazon for the final build. Works just fine</p>
]]></description><link>https://forum.magicmirror.builders/post/5049</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/5049</guid><dc:creator><![CDATA[loribeeinca]]></dc:creator><pubDate>Mon, 19 Sep 2016 20:54:50 GMT</pubDate></item><item><title><![CDATA[Reply to HMDI (from Pi 3) to DVI?  Will it work? on Mon, 19 Sep 2016 13:41:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nbrenn" aria-label="Profile: nbrenn">@<bdi>nbrenn</bdi></a>  it’s working for me … i used a monitor which don’t have HDMI port so i connected with a HDMI to DVI <a href="https://www.amazon.com/Importer520-Plated-Female-DVI-D-Adapter/dp/B0035B4LJM/ref=pd_sim_23_1?ie=UTF8&amp;psc=1&amp;refRID=WRCHGK88JX3HP5G3J04V" target="_blank" rel="noopener noreferrer nofollow ugc">converter</a>  only issue is the sound wont output trough HDMI you need to use something else :) Good Luck</p>
]]></description><link>https://forum.magicmirror.builders/post/5027</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/5027</guid><dc:creator><![CDATA[zam]]></dc:creator><pubDate>Mon, 19 Sep 2016 13:41:54 GMT</pubDate></item><item><title><![CDATA[Reply to HMDI (from Pi 3) to DVI?  Will it work? on Mon, 19 Sep 2016 13:31:08 GMT]]></title><description><![CDATA[<p dir="auto">Yes, I do the same on my development monitor.</p>
]]></description><link>https://forum.magicmirror.builders/post/5026</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/5026</guid><dc:creator><![CDATA[MichMich]]></dc:creator><pubDate>Mon, 19 Sep 2016 13:31:08 GMT</pubDate></item></channel></rss>
