<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[New to MM]]></title><description><![CDATA[<p dir="auto">Having this error, cant see were is the problem. some can help?<br />
And how can i set the default calendar to mexico holidays?</p>
<p dir="auto"><code>webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics</code></p>
<p dir="auto">Thanks all</p>
<pre><code>0 info it worked if it ends with ok
1 verbose cli [ '/usr/bin/node', '/usr/bin/npm', 'run', 'config:check' ]
2 info using npm@3.10.10
3 info using node@v6.13.0
4 verbose config Skipping project config: /home/pi/.npmrc. (matches userconfig)
5 verbose stack Error: ENOENT: no such file or directory, open '/home/pi/package.json'
5 verbose stack     at Error (native)
6 verbose cwd /home/pi
7 error Linux 4.9.59-v7+
8 error argv "/usr/bin/node" "/usr/bin/npm" "run" "config:check"
9 error node v6.13.0
10 error npm  v3.10.10
11 error path /home/pi/package.json
12 error code ENOENT
13 error errno -2
14 error syscall open
15 error enoent ENOENT: no such file or directory, open '/home/pi/package.json'
16 error enoent ENOENT: no such file or directory, open '/home/pi/package.json'
16 error enoent This is most likely not a problem with npm itself
16 error enoent and is related to npm not being able to find a file.
17 verbose exit [ -2, true ]
]]></description><link>https://forum.magicmirror.builders/topic/6625/new-to-mm</link><generator>RSS for Node</generator><lastBuildDate>Sat, 09 May 2026 23:42:02 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/6625.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 21 Feb 2018 05:59:08 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to New to MM on Wed, 21 Feb 2018 14:34:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/pinsdorf" aria-label="Profile: pinsdorf">@<bdi>pinsdorf</bdi></a> its on /home/pi/MagicMirror, I will reinstall , and after that i will report back and see if the problem comes back, thank you for the calendar too</p>
]]></description><link>https://forum.magicmirror.builders/post/36068</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/36068</guid><dc:creator><![CDATA[jorgeg73]]></dc:creator><pubDate>Wed, 21 Feb 2018 14:34:28 GMT</pubDate></item><item><title><![CDATA[Reply to New to MM on Wed, 21 Feb 2018 14:28:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lavolp3" aria-label="Profile: lavolp3">@<bdi>lavolp3</bdi></a> yes on this one i will reinstall to jessie, the error didnt appear after several days. thanks</p>
]]></description><link>https://forum.magicmirror.builders/post/36066</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/36066</guid><dc:creator><![CDATA[jorgeg73]]></dc:creator><pubDate>Wed, 21 Feb 2018 14:28:17 GMT</pubDate></item><item><title><![CDATA[Reply to New to MM on Wed, 21 Feb 2018 10:34:08 GMT]]></title><description><![CDATA[<p dir="auto">Regarding Mexican holidays: there are free calendars available, e.g. here <a href="https://www.calendarlabs.com/ical-calendar/holidays/mexico-holidays-60/" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.calendarlabs.com/ical-calendar/holidays/mexico-holidays-60/</a>. I don’t know the exact URL to configure MM’s calendar module, but I’d start with the download link’s URL on this page.</p>
]]></description><link>https://forum.magicmirror.builders/post/36052</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/36052</guid><dc:creator><![CDATA[pinsdorf]]></dc:creator><pubDate>Wed, 21 Feb 2018 10:34:08 GMT</pubDate></item><item><title><![CDATA[Reply to New to MM on Wed, 21 Feb 2018 10:28:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jorgeg73" aria-label="Profile: jorgeg73">@<bdi>jorgeg73</bdi></a> said in <a href="/post/36041">New to MM</a>:</p>
<p dir="auto">5 verbose stack Error: ENOENT: no such file or directory, open '/home/pi/package.json’</p>
<p dir="auto">I’m wondering, why node is expecting the file package.json in the home directory <code>/home/pi</code>and not in <code>/home/pi/MagicMirror</code>?!</p>
<p dir="auto">Are you running <code>npm start</code> from within the MagicMirror directory, i.e. did you do <code>cd ~/MagicMirror</code> first?</p>
]]></description><link>https://forum.magicmirror.builders/post/36051</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/36051</guid><dc:creator><![CDATA[pinsdorf]]></dc:creator><pubDate>Wed, 21 Feb 2018 10:28:05 GMT</pubDate></item><item><title><![CDATA[Reply to New to MM on Wed, 21 Feb 2018 09:29:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jorgeg73" aria-label="Profile: jorgeg73">@<bdi>jorgeg73</bdi></a> said in <a href="/post/36041">New to MM</a>:</p>
<blockquote></blockquote>
<p dir="auto">You’re using  Raspbian Stretch!?<br />
A lot of people here have had problems with stretch, though I don’t know if they are the same<br />
It’s still advisable to use Raspbian Jessie instead of the newer Raspbian Stretch</p>
]]></description><link>https://forum.magicmirror.builders/post/36049</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/36049</guid><dc:creator><![CDATA[lavolp3]]></dc:creator><pubDate>Wed, 21 Feb 2018 09:29:57 GMT</pubDate></item></channel></rss>
