<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-Facial Recognition Module classes]]></title><description><![CDATA[<p dir="auto">When I try to add classes to the config files i get this error:</p>
<p dir="auto">“Could not validate config file”.</p>
<p dir="auto">I tried adding a class to just one module:</p>
<pre><code>module: 'MMM-YrThen'
position: 'top_right'
classes: 'default everyone'
<p dir="auto">When I remove classes, the problem goes away, but then the mirror is just blank.</p>
]]></description><link>https://forum.magicmirror.builders/topic/6629/mmm-facial-recognition-module-classes</link><generator>RSS for Node</generator><lastBuildDate>Sun, 10 May 2026 04:49:32 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/6629.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 21 Feb 2018 18:32:05 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-Facial Recognition Module classes on Wed, 21 Feb 2018 20:12:02 GMT]]></title><description><![CDATA[<p dir="auto">Thank you! That fixed it :)</p>
]]></description><link>https://forum.magicmirror.builders/post/36084</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/36084</guid><dc:creator><![CDATA[vintage89]]></dc:creator><pubDate>Wed, 21 Feb 2018 20:12:02 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Facial Recognition Module classes on Wed, 21 Feb 2018 20:09:04 GMT]]></title><description><![CDATA[<p dir="auto">In your first snippet, there is a comma missing after position line.<br />
In your second snippet the comma is missing after the } which closes the config section.</p>
]]></description><link>https://forum.magicmirror.builders/post/36082</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/36082</guid><dc:creator><![CDATA[yawns]]></dc:creator><pubDate>Wed, 21 Feb 2018 20:09:04 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Facial Recognition Module classes on Wed, 21 Feb 2018 19:27:16 GMT]]></title><description><![CDATA[<p dir="auto">This is the module I’m trying to add classes to</p>
<pre><code>
	module: 'MMM-YrThen',
	position: 'top_right',
	classes: 'default everyone',
]]></description><link>https://forum.magicmirror.builders/post/36080</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/36080</guid><dc:creator><![CDATA[vintage89]]></dc:creator><pubDate>Wed, 21 Feb 2018 19:27:16 GMT</pubDate></item></channel></rss>
