MagicMirror² v2.7.0 is available! For more information about this release, check out this topic.
Failed to load gRPC binary module - MMM-Assistant.
  • I installed MMM-Assistant following Wiki instruction.
    My error :
    0|mm       | { Error: Failed to load gRPC binary module because it was not installed for the current system
    0|mm       | Expected directory: electron-v1.4-linux-arm-glibc
    0|mm       | Found: [electron-v1.4-linux-arm-{libc}, node-v48-linux-arm-glibc]
    0|mm       | This problem can often be fixed by running "npm rebuild" on the current system
    0|mm       | Original error: Cannot find module '/home/pi/MagicMirror/modules/MMM-Assistant/node_modules/grpc/src/node/extension_binary/electron-v1.4-linux-arm-glibc/grpc_node.node'
    0|mm       |     at Object. (/home/pi/MagicMirror/modules/MMM-Assistant/node_modules/grpc/src/grpc_extension.js:53:17)
    0|mm       |     at Module._compile (module.js:556:32)
    0|mm       |     at Object.Module._extensions..js (module.js:565:10)
    0|mm       |     at Module.load (module.js:473:32)
    0|mm       |     at tryModuleLoad (module.js:432:12)
    0|mm       |     at Function.Module._load (module.js:424:3)
    0|mm       |     at Module.require (module.js:483:17)
    0|mm       |     at require (internal/module.js:20:19)
    0|mm       |     at Object. (/home/pi/MagicMirror/modules/MMM-Assistant/node_modules/grpc/src/client.js:37:12)
    0|mm       |     at Module._compile (module.js:556:32) code: 'MODULE_NOT_FOUND' }
    Any suggestions?
    thnks
  • I too am running into this issue with my new mirror. I tried running npm rebuild with no luck. Planning on bashing my head against it until I fix it this weekend, will post back with results.
  • The module has now been fixed and is working good as of today. Please update!
