<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Energy saving]]></title><description><![CDATA[<p dir="auto">Hi. I would like that the monitor turns of at 21:00 and turns on again at 08:00.<br />
But i have no idea how to do this im a noob so maybe someone could help me with this.</p>
<p dir="auto">Also i tried to put google assistant to the mirror but i couldnt make it i think thats a bit to hard for me n my knowledge :/</p>
]]></description><link>https://forum.magicmirror.builders/topic/6643/energy-saving</link><generator>RSS for Node</generator><lastBuildDate>Sun, 14 Jun 2026 06:36:49 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/6643.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 23 Feb 2018 16:45:21 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Energy saving on Fri, 23 Feb 2018 19:45:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/peter" aria-label="Profile: Peter">@<bdi>Peter</bdi></a> thank you for help :-) good to know</p>
]]></description><link>https://forum.magicmirror.builders/post/36182</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/36182</guid><dc:creator><![CDATA[svenr]]></dc:creator><pubDate>Fri, 23 Feb 2018 19:45:44 GMT</pubDate></item><item><title><![CDATA[Reply to Energy saving on Fri, 23 Feb 2018 19:44:14 GMT]]></title><description><![CDATA[<p dir="auto">Not if you use a time based method.<br />
I think I will use the pir only in the future: any movement will turn on the screen for several minutes.<br />
Even in the middle of the night …<br />
Peter</p>
]]></description><link>https://forum.magicmirror.builders/post/36181</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/36181</guid><dc:creator><![CDATA[Peter]]></dc:creator><pubDate>Fri, 23 Feb 2018 19:44:14 GMT</pubDate></item><item><title><![CDATA[Reply to Energy saving on Fri, 23 Feb 2018 19:41:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/peter" aria-label="Profile: Peter">@<bdi>Peter</bdi></a> so it means at 01:00 at night you have no chance to turn on the screen right?</p>
]]></description><link>https://forum.magicmirror.builders/post/36180</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/36180</guid><dc:creator><![CDATA[svenr]]></dc:creator><pubDate>Fri, 23 Feb 2018 19:41:54 GMT</pubDate></item><item><title><![CDATA[Reply to Energy saving on Fri, 23 Feb 2018 19:34:39 GMT]]></title><description><![CDATA[<p dir="auto">My monitor turns off at 23.30 and on at 7.00.<br />
So at night I cannot turn it on.<br />
During the day the monitor is turned off and on with a pir.<br />
Clear?<br />
Peter</p>
]]></description><link>https://forum.magicmirror.builders/post/36179</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/36179</guid><dc:creator><![CDATA[Peter]]></dc:creator><pubDate>Fri, 23 Feb 2018 19:34:39 GMT</pubDate></item><item><title><![CDATA[Reply to Energy saving on Fri, 23 Feb 2018 19:22:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/peter" aria-label="Profile: Peter">@<bdi>Peter</bdi></a> thank you i guess that helps me just one question: if i type that the monitor should turn off (just a example) from 09:00 till 12:00 and after that works how im able to turn on the monitor in case i changed opinion and at 10:00 i want to turn on the monitor. The monitor is off at 10:00 so how to change it</p>
]]></description><link>https://forum.magicmirror.builders/post/36178</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/36178</guid><dc:creator><![CDATA[svenr]]></dc:creator><pubDate>Fri, 23 Feb 2018 19:22:56 GMT</pubDate></item><item><title><![CDATA[Reply to Energy saving on Fri, 23 Feb 2018 19:08:16 GMT]]></title><description><![CDATA[<p dir="auto">For turning on the mirror (or the screen) and wakening it up, maybe this will help you:<br />
<a href="https://forum.magicmirror.builders/topic/6291/howto-turn-on-off-your-monitor-time-based-pir-button-app">https://forum.magicmirror.builders/topic/6291/howto-turn-on-off-your-monitor-time-based-pir-button-app</a><br />
I use this too and I am happy with it.<br />
Later I added a pir.<br />
Succes!<br />
Peter</p>
]]></description><link>https://forum.magicmirror.builders/post/36177</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/36177</guid><dc:creator><![CDATA[Peter]]></dc:creator><pubDate>Fri, 23 Feb 2018 19:08:16 GMT</pubDate></item></channel></rss>
