<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Get weather at a calendar event location]]></title><description><![CDATA[<p dir="auto">Hey guys,<br />
just finished setting up my pi3 and am installing modules as we speak, but one I couldn’t find and thought might be a useful addition would be a module that can get a location from a calendar event, plug it into open weather, and retrieve anything important about the weather (eg if an umbrella is needed, or if there is high temperatures expected)</p>
]]></description><link>https://forum.magicmirror.builders/topic/6715/get-weather-at-a-calendar-event-location</link><generator>RSS for Node</generator><lastBuildDate>Wed, 09 Sep 2026 01:25:01 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/6715.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 05 Mar 2018 00:33:09 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Get weather at a calendar event location on Mon, 05 Mar 2018 22:44:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ninjabreadman" aria-label="Profile: ninjabreadman">@<bdi>ninjabreadman</bdi></a> Does the weather module support dynamic locations? how would I get the weather location id for open weather. also, I was planning on using it not so much as determining the whole day weather, but warning the user about rain in the area or heat. Considering where I live it can vary a lot between the suburbs and the CBD.</p>
]]></description><link>https://forum.magicmirror.builders/post/36619</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/36619</guid><dc:creator><![CDATA[Albinolan]]></dc:creator><pubDate>Mon, 05 Mar 2018 22:44:39 GMT</pubDate></item><item><title><![CDATA[Reply to Get weather at a calendar event location on Mon, 05 Mar 2018 19:56:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/albinolan" aria-label="Profile: Albinolan">@<bdi>Albinolan</bdi></a> I haven’t seen it done, but someone asked how to show driving directions to  calendar event locations, and <a href="https://forum.magicmirror.builders/topic/812/2-1-0-calendar-will-broadcast-events/6">I described the basic process here.</a> This is basically the same, but with weather.</p>
<p dir="auto">The default <code>calendar</code> module broadcasts events via the <a href="https://github.com/MichMich/MagicMirror/blob/master/modules/README.md" target="_blank" rel="noopener noreferrer nofollow ugc">MM notification framework</a>. You just need to modify a module to receive and interpret the notification/events.</p>
<p dir="auto">I question the overall utility, though. How often is the weather different from your house (or mirror) to the destination? I can see the utility if you travel a lot, or often visit neighboring towns, but imagine for most people seeing the weather forecast <em>for their city</em> should suffice.</p>
]]></description><link>https://forum.magicmirror.builders/post/36609</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/36609</guid><dc:creator><![CDATA[ninjabreadman]]></dc:creator><pubDate>Mon, 05 Mar 2018 19:56:30 GMT</pubDate></item></channel></rss>
