<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[New Raspbian Updates -- OK]]></title><description><![CDATA[<p dir="auto">I just got pushed the latest Raspian <strong>Stretch</strong> upgrade to:</p>
<pre><code class="language-bash"># uname -a
Linux mmm 4.9.80-v7+ #1098 SMP Fri Mar 9 19:11:42 GMT 2018 armv7l GNU/Linux
# sudo lsb_release -a
No LSB modules are available.
Distributor ID: Raspbian
Description:    Raspbian GNU/Linux 9.3 (stretch)
Release:        9.3
Codename:       stretch
<p dir="auto">After doing <code>sudo apt upgrade</code> (116 MB) it broke my splash screen and reset all other <code>/boot/cmdline.txt</code> settings to original:</p>
<pre><code class="language-bash">dwc_otg.lpm_enable=0 console=serial0,115200 console=tty1 root=PARTUUID=xxxxxxxx-yy rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait splash plymouth.ignore-serial-consoles quiet
<p dir="auto">Make sure you make a backup of this file, and the MM splash image.<br />
I’m still investigating what else has changed…</p>
<p dir="auto">EDIT:</p>
<p dir="auto">Ok, it seem fairly safe, unless you have made other OS changes.</p>
]]></description><link>https://forum.magicmirror.builders/topic/6776/new-raspbian-updates-ok</link><generator>RSS for Node</generator><lastBuildDate>Sat, 11 Jul 2026 04:50:07 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/6776.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 14 Mar 2018 08:59:34 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to New Raspbian Updates -- OK on Wed, 14 Mar 2018 11:03:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/e3v3a" aria-label="Profile: E3V3A">@<bdi>E3V3A</bdi></a> great thanks, can’t wait to get up and running!!  Thank you!</p>
]]></description><link>https://forum.magicmirror.builders/post/37000</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/37000</guid><dc:creator><![CDATA[webweaves]]></dc:creator><pubDate>Wed, 14 Mar 2018 11:03:39 GMT</pubDate></item><item><title><![CDATA[Reply to New Raspbian Updates -- OK on Wed, 14 Mar 2018 11:01:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/webweaves" aria-label="Profile: webweaves">@<bdi>webweaves</bdi></a> The full one!</p>
]]></description><link>https://forum.magicmirror.builders/post/36999</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/36999</guid><dc:creator><![CDATA[E3V3A]]></dc:creator><pubDate>Wed, 14 Mar 2018 11:01:33 GMT</pubDate></item><item><title><![CDATA[Reply to New Raspbian Updates -- OK on Wed, 14 Mar 2018 10:37:00 GMT]]></title><description><![CDATA[<p dir="auto">Hi, to get up and running with the standard install of MM should I use<br />
Raspbian Stretch with desktop or Raspbian Stretch Lite?</p>
<p dir="auto">Thank you!</p>
]]></description><link>https://forum.magicmirror.builders/post/36997</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/36997</guid><dc:creator><![CDATA[webweaves]]></dc:creator><pubDate>Wed, 14 Mar 2018 10:37:00 GMT</pubDate></item></channel></rss>
