<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[New Raspberry Pi 3+]]></title><description><![CDATA[<p dir="auto">Today they released a new Raspberry Pi</p>
<pre><code>Broadcom BCM2837B0, Cortex-A53 (ARMv8) 64-bit SoC @ 1.4GHz
1GB LPDDR2 SDRAM
2.4GHz and 5GHz IEEE 802.11.b/g/n/ac wireless LAN, Bluetooth 4.2, BLE
Gigabit Ethernet over USB 2.0 (maximum throughput 300 Mbps)
Extended 40-pin GPIO header
Full-size HDMI
4 USB 2.0 ports
CSI camera port for connecting a Raspberry Pi camera
DSI display port for connecting a Raspberry Pi touchscreen display
4-pole stereo output and composite video port
Micro SD port for loading your operating system and storing data
5V/2.5A DC power input
Power-over-Ethernet (PoE) support (requires separate PoE HAT)
<p dir="auto"><a href="https://www.raspberrypi.org/products/raspberry-pi-3-model-b-plus/" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.raspberrypi.org/products/raspberry-pi-3-model-b-plus/</a></p>
]]></description><link>https://forum.magicmirror.builders/topic/6779/new-raspberry-pi-3</link><generator>RSS for Node</generator><lastBuildDate>Thu, 18 Jun 2026 11:55:44 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/6779.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 14 Mar 2018 21:02:08 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to New Raspberry Pi 3+ on Tue, 20 Mar 2018 14:23:15 GMT]]></title><description><![CDATA[<p dir="auto">Yeah, although I love the RPi support community, for example the <code>ASUS Tinker Board S</code> look very similar in both formfactor, price and spec’s but cheaper.</p>
<p dir="auto">The Asus TB S has:</p>
<ul>
<li>2 GB RAM</li>
<li>16 GB on-board SD</li>
<li>GB Ethernet</li>
<li>1.8 GHz CPU</li>
<li>4K HD (AFAICR)</li>
</ul>
]]></description><link>https://forum.magicmirror.builders/post/37236</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/37236</guid><dc:creator><![CDATA[E3V3A]]></dc:creator><pubDate>Tue, 20 Mar 2018 14:23:15 GMT</pubDate></item><item><title><![CDATA[Reply to New Raspberry Pi 3+ on Fri, 16 Mar 2018 05:21:26 GMT]]></title><description><![CDATA[<p dir="auto">It’s only a minor upgrade to the 3, stuff like this I would expect for a major upgrade in a pi 4</p>
]]></description><link>https://forum.magicmirror.builders/post/37063</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/37063</guid><dc:creator><![CDATA[strawberry 3.141]]></dc:creator><pubDate>Fri, 16 Mar 2018 05:21:26 GMT</pubDate></item><item><title><![CDATA[Reply to New Raspberry Pi 3+ on Thu, 15 Mar 2018 22:44:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/e3v3a" aria-label="Profile: E3V3A">@<bdi>E3V3A</bdi></a> No 4K output either…</p>
]]></description><link>https://forum.magicmirror.builders/post/37049</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/37049</guid><dc:creator><![CDATA[j.e.f.f]]></dc:creator><pubDate>Thu, 15 Mar 2018 22:44:11 GMT</pubDate></item><item><title><![CDATA[Reply to New Raspberry Pi 3+ on Wed, 14 Mar 2018 21:07:53 GMT]]></title><description><![CDATA[<p dir="auto">Oh, pleeeease. Still no MIC input and still no more RAM. :)</p>
]]></description><link>https://forum.magicmirror.builders/post/37022</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/37022</guid><dc:creator><![CDATA[E3V3A]]></dc:creator><pubDate>Wed, 14 Mar 2018 21:07:53 GMT</pubDate></item></channel></rss>
