<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[How to autorestart MM once a day]]></title><description><![CDATA[<p dir="auto">Hi, I was trying to autorestart the mirror once a day. The problem is my twitter feed that stacks every 1-2 days. I was not able to fix it, only restart helps. I’ve added the cronjob (?) line, however, it doesn’t work for me.<br />
Can some one point me in to the right direction, how to do the auto restart with other options? PM2 or other?<br />
I need step by step, please.</p>
]]></description><link>https://forum.magicmirror.builders/topic/6826/how-to-autorestart-mm-once-a-day</link><generator>RSS for Node</generator><lastBuildDate>Sat, 11 Apr 2026 11:04:17 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/6826.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 23 Mar 2018 10:11:31 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to How to autorestart MM once a day on Tue, 20 Dec 2022 13:30:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/davechild" aria-label="Profile: DaveChild">@<bdi>DaveChild</bdi></a> also need to run the cron task under the user id that created the pm2 task…  usually pi</p>
<p dir="auto">running under root (default) will fail</p>
]]></description><link>https://forum.magicmirror.builders/post/106668</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/106668</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 20 Dec 2022 13:30:38 GMT</pubDate></item><item><title><![CDATA[Reply to How to autorestart MM once a day on Mon, 19 Dec 2022 20:13:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/maxpower" aria-label="Profile: MaxPower">@<bdi>MaxPower</bdi></a> said in <a href="/post/37392">How to autorestart MM once a day</a>:</p>
<p dir="auto">I recommend you then add the following crontab task:</p>
<pre><code>* 4 * * * pm2 restart mm
<p dir="auto">Sorry to bump this old topic, but I found this searching for how to restart MM automatically and the crontab line given isn’t quite correct. That line will restart MM every minute from 4am to 5am. The line to get it to run just once is something like:</p>
<pre><code>17 4 * * * pm2 restart mm
<p dir="auto">That’ll run at 4:17 am only.</p>
]]></description><link>https://forum.magicmirror.builders/post/106665</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/106665</guid><dc:creator><![CDATA[DaveChild]]></dc:creator><pubDate>Mon, 19 Dec 2022 20:13:10 GMT</pubDate></item><item><title><![CDATA[Reply to How to autorestart MM once a day on Sun, 25 Mar 2018 20:52:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/maxpower" aria-label="Profile: MaxPower">@<bdi>MaxPower</bdi></a> Sound like it would be better to file an issue with the module developer github, to fix the problem, rather than have to restart you pi.</p>
]]></description><link>https://forum.magicmirror.builders/post/37428</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/37428</guid><dc:creator><![CDATA[E3V3A]]></dc:creator><pubDate>Sun, 25 Mar 2018 20:52:06 GMT</pubDate></item><item><title><![CDATA[Reply to How to autorestart MM once a day on Sat, 24 Mar 2018 20:18:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ninjabreadman" aria-label="Profile: ninjabreadman">@<bdi>ninjabreadman</bdi></a> thank you for the help!</p>
<p dir="auto">Sorry, I meant that my twitter modul stucks every day or so. I’m not sure why, but every other say one twit stuck and stays there forever until I restart MM. Sometimes it can be after 2-3 days sometimes several hours. So the esiest way I found is to restart the mirror every day.<br />
Thanks for the script, I added it to the cron, I hope it will work.</p>
]]></description><link>https://forum.magicmirror.builders/post/37392</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/37392</guid><dc:creator><![CDATA[MaxPower]]></dc:creator><pubDate>Sat, 24 Mar 2018 20:18:45 GMT</pubDate></item><item><title><![CDATA[Reply to How to autorestart MM once a day on Fri, 23 Mar 2018 13:14:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/maxpower" aria-label="Profile: MaxPower">@<bdi>MaxPower</bdi></a> It <em>stacks</em> every 1-2 days? I don’t quite understand what that means.</p>
<p dir="auto">In any case, what command are you using to restart? Are you trying to restart MM (recommended) or the RPi? If you have <code>pm2</code> installed and managing your MM process, I suggest using <code>pm2 restart mm</code>. Whatever commend you choose, run it in Terminal first to ensure it will do what you intend.</p>
<p dir="auto">There are lots of <a href="https://www.youtube.com/watch?v=rErAOjACT6w" target="_blank" rel="noopener noreferrer nofollow ugc">videos</a> and <a href="https://www.makeuseof.com/tag/linux-task-scheduling-crontab-explained/" target="_blank" rel="noopener noreferrer nofollow ugc">walkthroughs</a> available online on how to use <code>crontab</code>.</p>
<p dir="auto">I recommend you then add the following <code>crontab</code> task:</p>
<p dir="auto">This will restart MM every day at 4am (when I assume you’re not using it) so that it’s ready in the morning.</p>
]]></description><link>https://forum.magicmirror.builders/post/37344</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/37344</guid><dc:creator><![CDATA[ninjabreadman]]></dc:creator><pubDate>Fri, 23 Mar 2018 13:14:19 GMT</pubDate></item></channel></rss>
