<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[RPi Zero Troubleshooting]]></title><description><![CDATA[<p dir="auto">I’ve followed the guide at <a href="https://forum.magicmirror.builders/topic/1183/how-i-got-my-magic-mirror-working-on-a-raspberry-pi-0-zero">https://forum.magicmirror.builders/topic/1183/how-i-got-my-magic-mirror-working-on-a-raspberry-pi-0-zero</a> to get MM installed on my RPi Zero W using Jessie Lite, but I’m having some issues now that the install is complete.</p>
<p dir="auto">Once Midori opens up (or if I connect to it using a browser on my PC), the screen is just black, and on the Pi I get the messages when the server starts:</p>
<p dir="auto">:::</p>
<p dir="auto">Starting MagicMirror: v2.2.2<br />
Loading Config …<br />
Loading module helpers …<br />
No helper found for module: alert.<br />
Initializing new module helper …<br />
Module helper loaded: updatenotification<br />
No helper found for module: clock.<br />
Module helper loaded: calendar<br />
No helper found for module: compliments.<br />
No helper found for module: currentweather.<br />
No helper found for module: weatherforecast.<br />
Module helper loaded: newsfeed.<br />
All module helpers loaded.<br />
Starting server on port 8080 …<br />
You’re using a full whitelist configuration to allow for all IPs<br />
Server started …<br />
Connecting socket for: update<br />
Connecting socket for: calendar<br />
Starting node helper for: calendar<br />
Connecting socket for: newsfeed<br />
Starting module: newsfeed<br />
Sockets connected &amp; modules started …</p>
<p dir="auto">I’m not really sure where to go from here but any help would be appreciated.</p>
]]></description><link>https://forum.magicmirror.builders/topic/6836/rpi-zero-troubleshooting</link><generator>RSS for Node</generator><lastBuildDate>Thu, 18 Jun 2026 02:26:21 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/6836.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 26 Mar 2018 11:55:58 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to RPi Zero Troubleshooting on Mon, 26 Mar 2018 22:02:20 GMT]]></title><description><![CDATA[<p dir="auto">Did some digging in the forums and found that</p>
<p dir="auto">npm install --unsafe-perm</p>
<p dir="auto">Looks to have fixed my issue!</p>
]]></description><link>https://forum.magicmirror.builders/post/37461</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/37461</guid><dc:creator><![CDATA[MattSharp]]></dc:creator><pubDate>Mon, 26 Mar 2018 22:02:20 GMT</pubDate></item></channel></rss>
