<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[So ... to update MagicMirror I would ... ??]]></title><description><![CDATA[<p dir="auto">cd into the magicmirror folder and run:</p>
<p dir="auto">sudo apt-get update</p>
<p dir="auto">or</p>
<p dir="auto">sudo apt-get upgrade</p>
<p dir="auto">do I then have to run npm install???</p>
<p dir="auto">Thanks for the help</p>
<p dir="auto">chef</p>
]]></description><link>https://forum.magicmirror.builders/topic/6874/so-to-update-magicmirror-i-would</link><generator>RSS for Node</generator><lastBuildDate>Tue, 16 Jun 2026 09:50:09 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/6874.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 01 Apr 2018 13:27:15 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to So ... to update MagicMirror I would ... ?? on Mon, 25 Jan 2021 01:47:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bitfit2020" aria-label="Profile: bitfit2020">@<bdi>bitfit2020</bdi></a> i dont have a config in any of my scripts</p>
<p dir="auto">i used the sample doing install,<br />
config.js for upgrade<br />
and no confug for the screen saver and pm2 scripts at the end</p>
<p dir="auto">upgrade does what u are supposed to do manually, but breaks running systems with lots of none-base modules</p>
<p dir="auto">upgrade tries to detect and fix the breakage</p>
<p dir="auto">run 1st time it will just check if its possible upgrade would work</p>
<p dir="auto">second time with ‘apply’  parm will do the upgrade process. a log is kept of the process</p>
]]></description><link>https://forum.magicmirror.builders/post/87769</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/87769</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 25 Jan 2021 01:47:05 GMT</pubDate></item><item><title><![CDATA[Reply to So ... to update MagicMirror I would ... ?? on Sun, 24 Jan 2021 21:30:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bitfit2020" aria-label="Profile: bitfit2020">@<bdi>bitfit2020</bdi></a> it gives u that control</p>
<p dir="auto">but glad u got it working</p>
]]></description><link>https://forum.magicmirror.builders/post/87754</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/87754</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 24 Jan 2021 21:30:52 GMT</pubDate></item><item><title><![CDATA[Reply to So ... to update MagicMirror I would ... ?? on Sun, 24 Jan 2021 18:39:38 GMT]]></title><description><![CDATA[<p dir="auto">Must be some of my modules but with your default config mirror works but with my config I get a BLACK SCREEN.</p>
<p dir="auto">BTW, I did not upgrade (was a bit worried)… not sure if should do that !</p>
]]></description><link>https://forum.magicmirror.builders/post/87746</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/87746</guid><dc:creator><![CDATA[bitfit2020]]></dc:creator><pubDate>Sun, 24 Jan 2021 18:39:38 GMT</pubDate></item><item><title><![CDATA[Reply to So ... to update MagicMirror I would ... ?? on Sun, 24 Jan 2021 18:14:36 GMT]]></title><description><![CDATA[<p dir="auto">U da man!!!  I’m back on the playground :) Thanks.</p>
]]></description><link>https://forum.magicmirror.builders/post/87745</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/87745</guid><dc:creator><![CDATA[bitfit2020]]></dc:creator><pubDate>Sun, 24 Jan 2021 18:14:36 GMT</pubDate></item><item><title><![CDATA[Reply to So ... to update MagicMirror I would ... ?? on Sun, 24 Jan 2021 16:27:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/chef" aria-label="Profile: chef">@<bdi>chef</bdi></a> use my upgrade script<br />
see here</p>
<p dir="auto"><a href="https://github.com/sdetweil/MagicMirror_scripts" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/sdetweil/MagicMirror_scripts</a></p>
]]></description><link>https://forum.magicmirror.builders/post/87729</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/87729</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 24 Jan 2021 16:27:48 GMT</pubDate></item><item><title><![CDATA[Reply to So ... to update MagicMirror I would ... ?? on Sun, 24 Jan 2021 16:21:22 GMT]]></title><description><![CDATA[<p dir="auto">Dude -</p>
<p dir="auto">My magicmirrior is DEAD !!! HELP !!! HELP !!!</p>
<p dir="auto">This is STILL an issue … had the BLACK SCREEN after the npm pull &amp;&amp; install npm</p>
<p dir="auto">Now the mirror does not even start and I get a Javascript error !!!<br />
I also got the 4 vulnerabilities (1 low, 2 high, 1 critical) after the install<br />
<img src="/assets/uploads/files/1611505275752-2021-01-24-111621_1920x1080_scrot.png" alt="2021-01-24-111621_1920x1080_scrot.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/87727</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/87727</guid><dc:creator><![CDATA[bitfit2020]]></dc:creator><pubDate>Sun, 24 Jan 2021 16:21:22 GMT</pubDate></item><item><title><![CDATA[Reply to So ... to update MagicMirror I would ... ?? on Thu, 24 May 2018 09:42:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/richard238" aria-label="Profile: richard238">@<bdi>richard238</bdi></a> said in <a href="/post/37875">So ... to update MagicMirror I would ... ??</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/michmich" aria-label="Profile: MichMich">@<bdi>MichMich</bdi></a> said in <a href="/post/37825">So ... to update MagicMirror I would ... ??</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/richard238" aria-label="Profile: Richard238">@<bdi>Richard238</bdi></a> Please share the steps you took to upgrade and the log files which shows errors.</p>
<p dir="auto">I followed the usual update routine.<br />
I don’t have any logs, as I’ve restored MM from an earlier SD card backup.</p>
<p dir="auto">MM working OK everywhere, it’s just telling me I’m 150 commits out-of-date.<br />
I’ll live with that until the electron black screen issue is resolved.</p>
<p dir="auto">Found the error logs from a backup I forgot I’d taken:</p>
<pre><code>[TAILING] Tailing last 15 lines for [mm] process (change the value with --lines option)
/home/pi/.pm2/logs/mm-error-0.log last 15 lines:
0|mm       |     at Function.Module._load (module.js:424:3)
0|mm       |     at Module.require (module.js:483:17)
0|mm       |     at require (internal/module.js:20:19)
0|mm       |     at bindings (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/bindings/bindings.js:81:44)
0|mm       | Error: Module version mismatch. Expected 50, got 57.
0|mm       |     at Error (native)
0|mm       |     at process.module.(anonymous function) [as dlopen] (ELECTRON_ASAR.js:173:20)
0|mm       |     at Object.Module._extensions..node (module.js:583:18)
0|mm       |     at Object.module.(anonymous function) [as .node] (ELECTRON_ASAR.js:173:20)
0|mm       |     at Module.load (module.js:473:32)
0|mm       |     at tryModuleLoad (module.js:432:12)
/home/pi/.pm2/logs/mm-out-0.log last 15 lines:
0|mm       | Initializing new module helper ...
0|mm       | Module helper loaded: MMM-MyTemps
0|mm       | Module helper loaded: updatenotification
0|mm       | No helper found for module: clock.
0|mm       | Module helper loaded: calendar
0|mm       | No helper found for module: compliments.
0|mm       | No helper found for module: currentweather.
0|mm       | No helper found for module: weatherforecast.
0|mm       | No helper found for module: MMM-doomsDay.
0|mm       | Whoops! There was an uncaught exception...
0|mm       | MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
0|mm       | If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
0|mm       | Launching application.
<p dir="auto">I hope that helps find what’s wrong, and how to fix it.</p>
<p dir="auto">Thanks!</p>
]]></description><link>https://forum.magicmirror.builders/post/39783</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/39783</guid><dc:creator><![CDATA[Richard238]]></dc:creator><pubDate>Thu, 24 May 2018 09:42:40 GMT</pubDate></item><item><title><![CDATA[Reply to So ... to update MagicMirror I would ... ?? on Tue, 10 Apr 2018 06:36:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/e3v3a" aria-label="Profile: E3V3A">@<bdi>E3V3A</bdi></a><br />
I thought I tried both. But it doesn’t matter now, I’ve redone everything. It’s back on now. Thanks for your help.</p>
]]></description><link>https://forum.magicmirror.builders/post/38221</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/38221</guid><dc:creator><![CDATA[surger13]]></dc:creator><pubDate>Tue, 10 Apr 2018 06:36:55 GMT</pubDate></item><item><title><![CDATA[Reply to So ... to update MagicMirror I would ... ?? on Sun, 08 Apr 2018 22:33:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/surger13" aria-label="Profile: surger13">@<bdi>surger13</bdi></a> Did <strong>you</strong> read the text?<br />
<code>Make sure you have the latest version of node.js and npm installed.</code><br />
– That’s exactly what it means.</p>
]]></description><link>https://forum.magicmirror.builders/post/38167</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/38167</guid><dc:creator><![CDATA[E3V3A]]></dc:creator><pubDate>Sun, 08 Apr 2018 22:33:06 GMT</pubDate></item><item><title><![CDATA[Reply to So ... to update MagicMirror I would ... ?? on Thu, 05 Apr 2018 12:53:04 GMT]]></title><description><![CDATA[<p dir="auto">Hello,<br />
I can’t get it to work anymore. :-(<br />
have meanwhile updated the Raspi including firmware. MagicMirror directory renamed and reinstalled.<br />
After booting only a black screen.</p>
<p dir="auto">Does that mean anything to anyone?</p>
<pre><code>pi@ftpi:~/MagicMirror $ npm start
&gt; magicmirror@2.3.1 start /home/pi/MagicMirror
&gt; sh run-start.sh
npm ERR! Linux 4.14.32-v7+
npm ERR! argv "/usr/bin/node" "/usr/bin/npm" "start"
npm ERR! node v6.14.1
npm ERR! npm  v3.10.10
npm ERR! code ELIFECYCLE
npm ERR! magicmirror@2.3.1 start: `sh run-start.sh`
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the magicmirror@2.3.1 start script 'sh run-start.sh'.
npm ERR! If you do, this is most likely a problem with the magicmirror package,
npm ERR! not with npm itself.
npm ERR!     sh run-start.sh
npm ERR!     npm bugs magicmirror
npm ERR! Or if that isn't available, you can get their info via:
npm ERR!     npm owner ls magicmirror
]]></description><link>https://forum.magicmirror.builders/post/37984</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/37984</guid><dc:creator><![CDATA[surger13]]></dc:creator><pubDate>Thu, 05 Apr 2018 12:53:04 GMT</pubDate></item><item><title><![CDATA[Reply to So ... to update MagicMirror I would ... ?? on Tue, 03 Apr 2018 09:44:41 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">I’ll live with that until the electron black screen issue is resolved.</p>
<p dir="auto">It is resolved in V2.3.1</p>
]]></description><link>https://forum.magicmirror.builders/post/37877</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/37877</guid><dc:creator><![CDATA[MichMich]]></dc:creator><pubDate>Tue, 03 Apr 2018 09:44:41 GMT</pubDate></item><item><title><![CDATA[Reply to So ... to update MagicMirror I would ... ?? on Tue, 03 Apr 2018 08:25:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/michmich" aria-label="Profile: MichMich">@<bdi>MichMich</bdi></a> said in <a href="/post/37825">So ... to update MagicMirror I would ... ??</a>:</p>
]]></description><link>https://forum.magicmirror.builders/post/37875</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/37875</guid><dc:creator><![CDATA[Richard238]]></dc:creator><pubDate>Tue, 03 Apr 2018 08:25:03 GMT</pubDate></item><item><title><![CDATA[Reply to So ... to update MagicMirror I would ... ?? on Tue, 03 Apr 2018 06:19:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/richard238" aria-label="Profile: Richard238">@<bdi>Richard238</bdi></a> said in <a href="/post/37823">So ... to update MagicMirror I would ... ??</a>:</p>
<p dir="auto">Installed MM2.3.1, still got black screen<br />
Installed earlier version electron, still got black screen.</p>
<p dir="auto">Shutdown and restarted.</p>
<p dir="auto">Now nothing on :8080 either :(</p>
<p dir="auto">Same with me. I was not at home over Easter, had switched off the raspberry 3 days. Launched yesterday and just a black screen. :(<br />
After that I read this with the new update and executed it, unfortunately without any changes. The downgrade of electron described above also brought no change. Still a black screen and no display via ip:8080.</p>
]]></description><link>https://forum.magicmirror.builders/post/37872</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/37872</guid><dc:creator><![CDATA[surger13]]></dc:creator><pubDate>Tue, 03 Apr 2018 06:19:40 GMT</pubDate></item><item><title><![CDATA[Reply to So ... to update MagicMirror I would ... ?? on Mon, 02 Apr 2018 12:05:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/richard238" aria-label="Profile: Richard238">@<bdi>Richard238</bdi></a> Please share the steps you took to upgrade and the log files which shows errors.</p>
]]></description><link>https://forum.magicmirror.builders/post/37825</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/37825</guid><dc:creator><![CDATA[MichMich]]></dc:creator><pubDate>Mon, 02 Apr 2018 12:05:58 GMT</pubDate></item><item><title><![CDATA[Reply to So ... to update MagicMirror I would ... ?? on Mon, 02 Apr 2018 11:33:20 GMT]]></title><description><![CDATA[<p dir="auto">Installed MM2.3.1, still got black screen<br />
]]></description><link>https://forum.magicmirror.builders/post/37823</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/37823</guid><dc:creator><![CDATA[Richard238]]></dc:creator><pubDate>Mon, 02 Apr 2018 11:33:20 GMT</pubDate></item><item><title><![CDATA[Reply to So ... to update MagicMirror I would ... ?? on Sun, 01 Apr 2018 17:50:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/michmich" aria-label="Profile: MichMich">@<bdi>MichMich</bdi></a> Thanks very much for the easter gift!</p>
]]></description><link>https://forum.magicmirror.builders/post/37790</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/37790</guid><dc:creator><![CDATA[chef]]></dc:creator><pubDate>Sun, 01 Apr 2018 17:50:27 GMT</pubDate></item><item><title><![CDATA[Reply to So ... to update MagicMirror I would ... ?? on Sun, 01 Apr 2018 17:30:58 GMT]]></title><description><![CDATA[<p dir="auto">Just updated the new repo.</p>
<p dir="auto"><strong>It’s alive again.</strong></p>
<p dir="auto">Thanks great job</p>
]]></description><link>https://forum.magicmirror.builders/post/37789</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/37789</guid><dc:creator><![CDATA[Charley]]></dc:creator><pubDate>Sun, 01 Apr 2018 17:30:58 GMT</pubDate></item><item><title><![CDATA[Reply to So ... to update MagicMirror I would ... ?? on Sun, 01 Apr 2018 17:19:14 GMT]]></title><description><![CDATA[<p dir="auto">Just to say it…<br />
It seem that many people having problems, are running something out dated.<br />
Either: <em>nodejs, npm,</em> or <em>pm2</em>.</p>
<p dir="auto">Because of the incredible dependency chain involved for node packages, I can only assume that using a newer versions of one package, will also require a newer version of the package depending on it, and possibly vice versa. Of course when things are working, it all beautiful, but it seem very easy that it doesn’t.</p>
]]></description><link>https://forum.magicmirror.builders/post/37787</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/37787</guid><dc:creator><![CDATA[E3V3A]]></dc:creator><pubDate>Sun, 01 Apr 2018 17:19:14 GMT</pubDate></item><item><title><![CDATA[Reply to So ... to update MagicMirror I would ... ?? on Sun, 01 Apr 2018 17:14:10 GMT]]></title><description><![CDATA[<p dir="auto">I’ve released an update: <a href="https://github.com/MichMich/MagicMirror/releases/tag/v2.3.1" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/MichMich/MagicMirror/releases/tag/v2.3.1</a></p>
]]></description><link>https://forum.magicmirror.builders/post/37785</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/37785</guid><dc:creator><![CDATA[MichMich]]></dc:creator><pubDate>Sun, 01 Apr 2018 17:14:10 GMT</pubDate></item><item><title><![CDATA[Reply to So ... to update MagicMirror I would ... ?? on Sun, 01 Apr 2018 17:09:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/e3v3a" aria-label="Profile: E3V3A">@<bdi>E3V3A</bdi></a> The Config &amp; Modules folder are not part of the Git repro. All other changes are overwritten.</p>
]]></description><link>https://forum.magicmirror.builders/post/37784</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/37784</guid><dc:creator><![CDATA[MichMich]]></dc:creator><pubDate>Sun, 01 Apr 2018 17:09:46 GMT</pubDate></item><item><title><![CDATA[Reply to So ... to update MagicMirror I would ... ?? on Sun, 01 Apr 2018 17:06:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nonamero" aria-label="Profile: NoNameRo">@<bdi>NoNameRo</bdi></a></p>
<p dir="auto">You guys should probaly do <code>pm2 stop mm; pm2 kill</code> to make sure it’s not running in the background.</p>
<p dir="auto">Also, AFAIK, I think if you do <code>git reset --hard</code> you’d loose all your old config settings and other changes you’ve made?</p>
]]></description><link>https://forum.magicmirror.builders/post/37783</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/37783</guid><dc:creator><![CDATA[E3V3A]]></dc:creator><pubDate>Sun, 01 Apr 2018 17:06:16 GMT</pubDate></item><item><title><![CDATA[Reply to So ... to update MagicMirror I would ... ?? on Sun, 01 Apr 2018 17:02:42 GMT]]></title><description><![CDATA[<p dir="auto">Solution in this thread <a href="https://github.com/MichMich/MagicMirror/issues/1243" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/MichMich/MagicMirror/issues/1243</a></p>
<p dir="auto">in MagicMirror Folder</p>
<pre><code>npm install electron@1.4.15
]]></description><link>https://forum.magicmirror.builders/post/37782</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/37782</guid><dc:creator><![CDATA[Montanaro]]></dc:creator><pubDate>Sun, 01 Apr 2018 17:02:42 GMT</pubDate></item><item><title><![CDATA[Reply to So ... to update MagicMirror I would ... ?? on Sun, 01 Apr 2018 17:02:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/michmich" aria-label="Profile: MichMich">@<bdi>MichMich</bdi></a> well-done.</p>
]]></description><link>https://forum.magicmirror.builders/post/37781</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/37781</guid><dc:creator><![CDATA[chef]]></dc:creator><pubDate>Sun, 01 Apr 2018 17:02:05 GMT</pubDate></item><item><title><![CDATA[Reply to So ... to update MagicMirror I would ... ?? on Sun, 01 Apr 2018 17:00:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/michmich" aria-label="Profile: MichMich">@<bdi>MichMich</bdi></a> said in <a href="/post/37779">So ... to update MagicMirror I would ... ??</a>:</p>
<p dir="auto">It seems to fix the issue for others. Not sure why you are unable to downgrade electron.<br />
<p dir="auto">Could you reboot and try again <a class="plugin-mentions-user plugin-mentions-a" href="/user/harry" aria-label="Profile: harry">@<bdi>harry</bdi></a>?</p>
<p dir="auto">Yep. Reboot helped.<br />
Rebooted, stopped MagicMirror and then the downgrade worked.<br />
MagicMirror is up and running again!</p>
<p dir="auto">Thanks a lot!</p>
]]></description><link>https://forum.magicmirror.builders/post/37780</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/37780</guid><dc:creator><![CDATA[Harry]]></dc:creator><pubDate>Sun, 01 Apr 2018 17:00:59 GMT</pubDate></item></channel></rss>
