<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Black Screen issue using Autoinstaller]]></title><description><![CDATA[<p dir="auto">Hi Guys,</p>
<p dir="auto">I used MM for about a year and it stopped working so I decided to update the OS to the Stream version and reinstall MM from scratch I used the Autoinstaller and everything seemed to install properly.</p>
<p dir="auto">For the life of me I can’t get past the Black Screen issue. This is what the terminal window shows…</p>
<p dir="auto">pi@raspberrypi:~/MagicMirror $ npm start dev</p>
<p dir="auto">magicmirror@2.3.1 start /home/pi/MagicMirror<br />
sh <a href="http://run-start.sh" target="_blank" rel="noopener noreferrer nofollow ugc">run-start.sh</a> “dev”</p>
<p dir="auto">Starting MagicMirror: v2.3.1<br />
Loading config …<br />
Loading module helpers …<br />
No helper found for module: alert.<br />
Initializing new module helper …<br />
Module helper loaded: updatenotification<br />
No helper found for module: clock.<br />
Module helper loaded: calendar<br />
No helper found for module: compliments.<br />
No helper found for module: currentweather.<br />
No helper found for module: weatherforecast.<br />
Module helper loaded: newsfeed<br />
All module helpers loaded.<br />
Starting server on port 8080 …<br />
Server started …<br />
Connecting socket for: updatenotification<br />
Connecting socket for: calendar<br />
Starting node helper for: calendar<br />
Connecting socket for: newsfeed<br />
Starting module: newsfeed<br />
Sockets connected &amp; modules started …<br />
Launching application.</p>
]]></description><link>https://forum.magicmirror.builders/topic/6933/black-screen-issue-using-autoinstaller</link><generator>RSS for Node</generator><lastBuildDate>Wed, 12 Aug 2026 17:03:50 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/6933.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 06 Apr 2018 17:07:36 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Black Screen issue using Autoinstaller on Fri, 06 Apr 2018 17:16:56 GMT]]></title><description><![CDATA[<p dir="auto">I followed the update procedure for 2.3.1 including elctron beta and it’s now working with the default modules!</p>
]]></description><link>https://forum.magicmirror.builders/post/38043</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/38043</guid><dc:creator><![CDATA[Sachin]]></dc:creator><pubDate>Fri, 06 Apr 2018 17:16:56 GMT</pubDate></item></channel></rss>
