<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Permission Denied - Config File]]></title><description><![CDATA[<p dir="auto">I just installed MM on my Pi 3.  I am attempting to update the config/config.js thru terminal but keep getting a “Permission Denied” message. Please help<br />
<img src="/assets/uploads/files/1523581988686-capture.png" alt="0_1523581988348_Capture.PNG" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/topic/6971/permission-denied-config-file</link><generator>RSS for Node</generator><lastBuildDate>Tue, 12 May 2026 13:17:45 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/6971.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 13 Apr 2018 01:14:10 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Permission Denied - Config File on Fri, 13 Apr 2018 01:21:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ninjabreadman" aria-label="Profile: ninjabreadman">@<bdi>ninjabreadman</bdi></a>  you my good man are a life saver thank you so much it worked.</p>
]]></description><link>https://forum.magicmirror.builders/post/38333</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/38333</guid><dc:creator><![CDATA[KumarTRD]]></dc:creator><pubDate>Fri, 13 Apr 2018 01:21:47 GMT</pubDate></item><item><title><![CDATA[Reply to Permission Denied - Config File on Fri, 13 Apr 2018 01:20:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kumartrd" aria-label="Profile: KumarTRD">@<bdi>KumarTRD</bdi></a> It’s not executable. You need to use an editor to open it, like <code>nano</code>:</p>
<p dir="auto"><code>nano ~/MagicMirror/config/config.js</code></p>
]]></description><link>https://forum.magicmirror.builders/post/38332</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/38332</guid><dc:creator><![CDATA[ninjabreadman]]></dc:creator><pubDate>Fri, 13 Apr 2018 01:20:12 GMT</pubDate></item></channel></rss>
