<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Create another PM2 Script?]]></title><description><![CDATA[<p dir="auto">Hello, can someone please help me figuire out where to place a PM2 Script please?</p>
<p dir="auto">I am following the guide to put on MMM-Sonos, and cannot fathom out the directions to create another PM2 Script, can someone tell me what the instructions mean? Is this a command line? as I cannot find a directory named <a href="http://sonos.sh" target="_blank" rel="noopener noreferrer nofollow ugc">sonos.sh</a> file contents</p>
<pre><code>create another pm2 script named sonos.sh in ~ directory
cd ~
sonos.sh file contents:
cd ~/node-sonos-http-api
DISPLAY=:0 npm start
pm2 start sonos.sh
pm2 start mm
pm2 save
<p dir="auto">the first part I have done, and see the web browser with sonos related text, so indeed, that hard bit has been done… just lost in the wording above as to what I should do, and where to do it?</p>
<pre><code>pi@magicpi:~ $ git clone https://github.com/jishi/node-sonos-http-api.git
cd node-sonos-http-api
npm install --production
npm start
verify, open a browser, point to your MM’s IP like so:
http://192.168.0.207:5005/zones
you should see a page full of sonos related text, if so the hard part is done…
<p dir="auto">Thank you</p>
]]></description><link>https://forum.magicmirror.builders/topic/6990/create-another-pm2-script</link><generator>RSS for Node</generator><lastBuildDate>Fri, 10 Jul 2026 11:31:16 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/6990.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 15 Apr 2018 15:21:31 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Create another PM2 Script? on Thu, 19 Apr 2018 16:43:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bhepler" aria-label="Profile: bhepler">@<bdi>bhepler</bdi></a></p>
<p dir="auto">Thanks very much for that, appreciated.</p>
<p dir="auto">Inclusion of nano will help as that was not mentioned.</p>
]]></description><link>https://forum.magicmirror.builders/post/38627</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/38627</guid><dc:creator><![CDATA[Damian]]></dc:creator><pubDate>Thu, 19 Apr 2018 16:43:33 GMT</pubDate></item><item><title><![CDATA[Reply to Create another PM2 Script? on Thu, 19 Apr 2018 15:15:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/damian" aria-label="Profile: Damian">@<bdi>Damian</bdi></a> Sure, I can do that. Let me re-write this a bit.</p>
<p dir="auto">Step 1 - Create a script called <code>sonos.sh</code> in the home directory (<code>~</code>).</p>
<pre><code>cd ~
nano sonos.sh
<p dir="auto">Enter the following in the nano editor for the contents of your <code>sonos.sh</code> script:</p>
<pre><code>cd ~/node-sonos-http-api
<p dir="auto">Save the file and exit the nano editor.</p>
<p dir="auto">Step 2 - Make your script executable by entering <code>chmod +x sonos.sh</code></p>
<p dir="auto">Step 3 - Tell pm2 to manage your sonos script so that it is always running in the background:</p>
<pre><code>pm2 start sonos.sh
pm2 save
<p dir="auto">Verify that pm2 is managing both your <code>sonos.sh</code> script and the <code>mm.sh</code> script by typing <code>pm2 status all</code>. You should see two lines, one for each script.</p>
<p dir="auto">Step 4 - Clear the logs and bounce your mirror and verify that everything works as planned.</p>
<pre><code>pm2 flush
pm2 restart all
]]></description><link>https://forum.magicmirror.builders/post/38625</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/38625</guid><dc:creator><![CDATA[bhepler]]></dc:creator><pubDate>Thu, 19 Apr 2018 15:15:55 GMT</pubDate></item><item><title><![CDATA[Reply to Create another PM2 Script? on Mon, 16 Apr 2018 22:52:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bhepler" aria-label="Profile: bhepler">@<bdi>bhepler</bdi></a></p>
<p dir="auto">Thanks so much for your help on this as it was doing my head in…</p>
<p dir="auto">Ok… I entered everything exactly as you stated above… and found everything you stated… and then it worked - Thank you so much for that, I sincerely appreciate your help on this.</p>
<p dir="auto">Can I ask you one more favour please?</p>
<p dir="auto">Going by the instructions I followed above, which made no sence to me in the format it was written… can I ask you what your simple instructions would be to complete that part? In a more understandable format than what is written above, and how it is written.</p>
<p dir="auto">This would help others understanding how to make that PM2 Script, and not confuse them, and would also educate me on how I should have done it.</p>
<p dir="auto">Thanks again.</p>
cd ~
pm2 start sonos.sh
pm2 start mm
pm2 save
]]></description><link>https://forum.magicmirror.builders/post/38521</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/38521</guid><dc:creator><![CDATA[Damian]]></dc:creator><pubDate>Mon, 16 Apr 2018 22:52:51 GMT</pubDate></item><item><title><![CDATA[Reply to Create another PM2 Script? on Mon, 16 Apr 2018 17:07:00 GMT]]></title><description><![CDATA[<p dir="auto">Okay, a couple things. <code>sono.sh</code> is your script that starts your process. <code>~</code> is the shortcut to the pi user’s home directory, also known as <code>/home/pi</code>. In order to run scripts from the command line, you have to precede the script name with <code>./</code></p>
<p dir="auto">So let’s take a moment to verify the state of your pi. Change to the home directory and pull up the file list with a couple switches to see if <code>sonos.sh</code> exits:</p>
<pre><code>pi@raspi:~ $ cd ~
pi@raspi:~ $ ls -lh sonos.sh
-rwxr-xr-x 1 pi pi 26 April 15 11:50 sonos.sh
<p dir="auto">There will be some variation in your results. If you see the phrase “No such file or directory”, then the file does not exist at that location. Also, you may not have any “x” entries when you do see the file listed. If so, the file is not marked executable, so it won’t run. You can fix this by typing <code>chmod +x sonos.sh</code></p>
<p dir="auto">I’m a little unclear as to what commands exactly are in your <code>sonos.sh</code> file. Could you please enter <code>cat sonos.sh</code> and reply with the results?</p>
<p dir="auto">Adding the script to pm2 is done by typing <code>pm2 start sonos.sh</code>. You can then verify that pm2 has picked it up by typing <code>pm2 status all</code>. That will give you a list of the processes that pm2 is controlling. You should see both your <code>mm.sh</code> process and your <code>sonos.sh</code> process.</p>
<p dir="auto">Give that a go and report back to us.</p>
]]></description><link>https://forum.magicmirror.builders/post/38516</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/38516</guid><dc:creator><![CDATA[bhepler]]></dc:creator><pubDate>Mon, 16 Apr 2018 17:07:00 GMT</pubDate></item><item><title><![CDATA[Reply to Create another PM2 Script? on Mon, 16 Apr 2018 12:08:10 GMT]]></title><description><![CDATA[<p dir="auto">@Mods</p>
<p dir="auto">Appreciate I have posted this twice in 2 seperate posts - but other one is FAO the Developer in his original post of 1 year ago, and to the poster who replied with his fix.</p>
<p dir="auto">This post goes to anyone here who can help me with making and executing a script, going by the example given for this module.</p>
]]></description><link>https://forum.magicmirror.builders/post/38484</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/38484</guid><dc:creator><![CDATA[Damian]]></dc:creator><pubDate>Mon, 16 Apr 2018 12:08:10 GMT</pubDate></item><item><title><![CDATA[Reply to Create another PM2 Script? on Mon, 16 Apr 2018 11:46:26 GMT]]></title><description><![CDATA[<p dir="auto">Okay, so I opened up my directory… created a new file in /home/pi and named it <a href="http://sonos.sh" target="_blank" rel="noopener noreferrer nofollow ugc">sonos.sh</a>… going by the jumbled up way things have been written in the example above, I have tried every combination to try and make sense of what it is saying to type  into terminal</p>
<p dir="auto">cd ~ <a href="http://sonos.sh" target="_blank" rel="noopener noreferrer nofollow ugc">sonos.sh</a> file contents<br />
<a href="http://sonos.sh" target="_blank" rel="noopener noreferrer nofollow ugc">sonos.sh</a></p>
<p dir="auto">I will no doubt be going around in circles here trying to decypher the instructions, so can I ask anyone to please decypher this for me and tell me what and where to enter these? do I manually input them into the <a href="http://sonos.sh" target="_blank" rel="noopener noreferrer nofollow ugc">sonos.sh</a> file? do I get terminal to enter them?<br />
I a<br />
l already set up PM2 over a year ago to autostart MM, and sure it was never as hard as this?</p>
<p dir="auto">this is what I get when trying</p>
<pre><code>pi@raspi:~ $ cd ~sonos.sh
bash: cd: ~sonos.sh: No such file or directory
pi@raspi:~ $ sonos.sh
bash: sonos.sh: command not found
pi@raspi:~ $ sonos.sh file contents:
pi@raspi:~ $ cd ~/node-sonos-http-api
pi@raspi:~/node-sonos-http-api $ DISPLAY=:0 npm start
&gt; sonos-http-api@1.6.0 start /home/pi/node-sonos-http-api
&gt; node server.js
2018-04-16T11:21:47.702Z INFO Could not find file /home/pi/node-sonos-http-api/settings.json
2018-04-16T11:21:48.670Z INFO Presets loaded: { example:
   { players:
      [ { roomName: 'Bathroom', volume: 10 },
        { roomName: 'Kitchen', volume: 10 },
        { roomName: 'Office', volume: 10 },
        { roomName: 'Bedroom', volume: 10 },
        { roomName: 'TV Room', volume: 15 } ],
     playMode: { shuffle: true, repeat: 'all', crossfade: false },
     pauseOthers: false } }
2018-04-16T11:21:54.317Z ERROR Port 5005 seems to be in use already. Make sure the sonos-http-api isn't
    already running, or that no other server uses that port. You can specify an alternative http port
    with property "port" in settings.json
npm ERR! Linux 4.9.35-v7+
npm ERR! argv "/usr/bin/node" "/usr/bin/npm" "start"
npm ERR! node v6.14.1
npm ERR! npm  v3.10.10
npm ERR! code ELIFECYCLE
npm ERR! sonos-http-api@1.6.0 start: `node server.js`
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the sonos-http-api@1.6.0 start script 'node server.js'.
npm ERR! If you do, this is most likely a problem with the sonos-http-api package,
npm ERR! not with npm itself.
npm ERR!     node server.js
npm ERR!     npm bugs sonos-http-api
npm ERR! Or if that isn't available, you can get their info via:
npm ERR!     npm owner ls sonos-http-api
npm ERR!     /home/pi/node-sonos-http-api/npm-debug.log
pi@papaspi:~/node-sonos-http-api $ pm2 start sonos.sh
[PM2][ERROR] script not found : /home/pi/node-sonos-http-api/sonos.sh
│ Name │ mode │ status │ ↺ │ cpu │ memory │
│ mm   │ fork │ online │ 0 │ 0%  │ 0 B    │
 Use `pm2 show ` to get more details about an app
pi@raspi:~/node-sonos-http-api $</code></pre>
]]></description><link>https://forum.magicmirror.builders/post/38483</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/38483</guid><dc:creator><![CDATA[Damian]]></dc:creator><pubDate>Mon, 16 Apr 2018 11:46:26 GMT</pubDate></item></channel></rss>
