<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MM and UBUNTU. Made for each other.]]></title><description><![CDATA[<h2>MM and UBUNTU. Made for each other.</h2>
<p dir="auto">This is not a tutorial. It’s more of a testimonial to the wonderful<br />
working relationship between MagicMirror and UBUNTU.</p>
<h2>Why?</h2>
<p dir="auto">I don’t know how many people are using MM with UBUNTU, but I am.</p>
<ul>
<li>I’m not using Pi’s anymore.</li>
<li>MM is very happy on ubuntu and runs like a champ.</li>
<li>A cheap laptop running ubuntu outperforms any Pi.</li>
<li>MMM-voice with Hello-Lucy runs amazingly well.</li>
</ul>
<h2>The old laptops I’m using this on.</h2>
<ul>
<li>MacBook(2005?) = Vanity mirror / Alarm Clock with Hello-Lucy</li>
<li>Compaq Presario CQ57 = Alarm Clock / Hello-Lucy</li>
<li>Dell Inspiron E1505 = Vanity mirror / Alarm Clock with Hello-Lucy</li>
<li>HP G60 Notebook = Alarm Clock / Hello-Lucy</li>
<li>ASUS Eee PC Seashell = Alarm Clock / Hello-Lucy</li>
</ul>
<p dir="auto">All of these are 10+ years old. I’ve had no trouble finding them on eBay<br />
and Craigslist for less than the price of a Pi3.</p>
<h2>Avoid Lenovo ThinkPads T410 &amp; T61</h2>
<p dir="auto">For whatever reason, ubuntu does not like these two machines. So, I didn’t<br />
bother with them. I use one now as a server machine under Windows 7.</p>
<h2>There’s no going back</h2>
<p dir="auto">Seriously, once you’ve experienced MagicMirror with UBUNTU you won’t go<br />
back to Raspbian, and once you’ve done the same on a cheap old laptop,<br />
you won’t go back to the Pi.</p>
<ul>
<li>The difference is astounding.</li>
<li>No video issues</li>
<li>No RAM issues (You can upgrade)</li>
<li>No system load issues</li>
<li>No heat issues</li>
<li>Most laptops have built-in WiFi</li>
<li>Most laptops have an integrated microphone</li>
</ul>
<h2>For what it’s worth</h2>
<p dir="auto">My recommendations:</p>
<p dir="auto">Because I have ubuntu on so many different machines, with relatively<br />
different specs, I settled on UBUNTU 16.04 LTS for all of them. I did this<br />
because it runs beautifully on every machine, even my i7 dev machine. The<br />
installations are virtually identical, making it exceptionally easy to move<br />
from one machine to another, for any reason.</p>
<p dir="auto">So, if you’re interested. Go to the ubuntu website and pick up your free<br />
version. Installation is fairly easy. They have a wonderful “how-to” guide<br />
that will help you with the installation.</p>
<p dir="auto">Install node. I do it this way for version 6<br />
<code>curl -sL https://deb.nodesource.com/setup_6.x | sudo -E bash -</code></p>
<p dir="auto">Install MagicMirror</p>
<h2>Thoughts you will have</h2>
<ul>
<li>Mykle was so right</li>
</ul>
<p dir="auto">Peace!</p>
]]></description><link>https://forum.magicmirror.builders/topic/6994/mm-and-ubuntu-made-for-each-other</link><generator>RSS for Node</generator><lastBuildDate>Tue, 14 Jul 2026 21:53:56 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/6994.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 16 Apr 2018 00:16:54 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MM and UBUNTU. Made for each other. on Sat, 18 Dec 2021 02:50:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> You are amazing! I wish I knew Linux as well I know Windows, but so it goes. Your suggestion worked! Thanks again!</p>
]]></description><link>https://forum.magicmirror.builders/post/97607</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/97607</guid><dc:creator><![CDATA[Cliff365]]></dc:creator><pubDate>Sat, 18 Dec 2021 02:50:47 GMT</pubDate></item><item><title><![CDATA[Reply to MM and UBUNTU. Made for each other. on Sat, 18 Dec 2021 03:19:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cliff365" aria-label="Profile: cliff365">@<bdi>cliff365</bdi></a> this post seems to imply installing as root and running as user or vice versa.</p>
<p dir="auto"><a href="https://forum.magicmirror.builders/topic/8464/back-screan-when-start-up-an-errors">https://forum.magicmirror.builders/topic/8464/back-screan-when-start-up-an-errors</a></p>
<p dir="auto">delete the mm folder and use my script</p>
<p dir="auto"><a href="https://github.com/sdetweil/MagicMirror_scripts" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/sdetweil/MagicMirror_scripts</a></p>
<p dir="auto">do NOT use sudo ,  and use a normal user, not logon as root</p>
]]></description><link>https://forum.magicmirror.builders/post/97604</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/97604</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 18 Dec 2021 03:19:39 GMT</pubDate></item><item><title><![CDATA[Reply to MM and UBUNTU. Made for each other. on Fri, 17 Dec 2021 22:29:15 GMT]]></title><description><![CDATA[<p dir="auto">Thanks <a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> , I entered the lines, but I had a bit of a problem getting MM to not restart while I tried to capture the logs. Hope this provides some insight:</p>
<pre><code>0|MagicMirror  | Starting server on port 8080 ...
0|MagicMirror  | [17.12.2021 16:25.52.307] [LOG]
0|MagicMirror  | Server started ...
0|MagicMirror  | [17.12.2021 16:25.52.312] [LOG]
0|MagicMirror  | Connecting socket for: updatenotification
0|MagicMirror  | [17.12.2021 16:25.52.316] [LOG]   Sockets connected &amp; modules started ...
0|MagicMirror  | (electron:4583): GLib-GIO-CRITICAL **: g_dbus_connection_register_object: assertion 'G_IS_DBUS_CONNECTION (connection)' failed
0|MagicMirror  | (electron:4583): GLib-GIO-CRITICAL **: g_dbus_connection_get_unique_name: assertion 'G_IS_DBUS_CONNECTION (connection)' failed
0|MagicMirror  | [4583:1217/162552.823896:ERROR:bus.cc(393)] Failed to connect to the bus: Failed to connect to socket /tmp/dbus-rSguYNpjNi: Connection refused
0|MagicMirror  | [4583:1217/162552.824839:ERROR:bus.cc(393)] Failed to connect to the bus: Failed to connect to socket /tmp/dbus-rSguYNpjNi: Connection refused
0|MagicMirror  | [17.12.2021 16:25.52.921] [LOG]
0|MagicMirror  | Launching application.
0|MagicMirror  | [4583:1217/162553.058857:ERROR:bus.cc(393)] Failed to connect to the bus: Failed to connect to socket /tmp/dbus-rSguYNpjNi: Connection refused
0|MagicMirror  | [4613:1217/162553.640227:ERROR:sandbox_linux.cc(376)] InitializeSandbox() called with multiple threads in process gpu-process.
0|MagicMirror  | [17.12.2021 16:26.01.616] [LOG]
0|MagicMirror  | Shutting down server...
0|MagicMirror  | [17.12.2021 16:26.01.618] [LOG]   Stopping module helper: updatenotification
PM2            | App [MagicMirror:0] exited with code [0] via signal [SIGINT]
PM2            | App [MagicMirror:0] starting in -fork mode-
PM2            | App [MagicMirror:0] online
0|MagicMirror  | &gt; magicmirror@2.17.1 start /home/cliff/MagicMirror
0|MagicMirror  | &gt; DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
0|MagicMirror  | [17.12.2021 16:26.06.425] [LOG]
0|MagicMirror  | Starting MagicMirror: v2.17.1
0|MagicMirror  | [17.12.2021 16:26.06.446] [LOG]
0|MagicMirror  | Loading config ...
0|MagicMirror  | [17.12.2021 16:26.06.466] [LOG]
0|MagicMirror  | Loading module helpers ...
0|MagicMirror  | [17.12.2021 16:26.06.487] [LOG]
0|MagicMirror  | No helper found for module: alert.
0|MagicMirror  | [17.12.2021 16:26.06.550] [LOG]
0|MagicMirror  | Initializing new module helper ...
0|MagicMirror  | [17.12.2021 16:26.06.555] [LOG]
0|MagicMirror  | Module helper loaded: updatenotification
0|MagicMirror  | [17.12.2021 16:26.06.559] [LOG]   No helper found for module: clock.
0|MagicMirror  | [17.12.2021 16:26.06.563] [LOG]   All module helpers loaded.
0|MagicMirror  | [17.12.2021 16:26.06.846] [LOG]
0|MagicMirror  | [17.12.2021 16:26.06.895] [LOG]
0|MagicMirror  | [17.12.2021 16:26.06.900] [LOG]   Connecting socket for: updatenotification
0|MagicMirror  | [17.12.2021 16:26.06.905] [LOG]   Sockets connected &amp; modules started ...
0|MagicMirror  | (electron:4673): GLib-GIO-CRITICAL **: g_dbus_connection_register_object: assertion 'G_IS_DBUS_CONNECTION (connection)' failed
0|MagicMirror  | (electron:4673): GLib-GIO-CRITICAL **: g_dbus_connection_get_unique_name: assertion 'G_IS_DBUS_CONNECTION (connection)' failed
0|MagicMirror  | [4673:1217/162607.415011:ERROR:bus.cc(393)] Failed to connect to the bus: Failed to connect to socket /tmp/dbus-rSguYNpjNi: Connection refused
0|MagicMirror  | [4673:1217/162607.415886:ERROR:bus.cc(393)] Failed to connect to the bus: Failed to connect to socket /tmp/dbus-rSguYNpjNi: Connection refused
0|MagicMirror  | [17.12.2021 16:26.07.530] [LOG]
0|MagicMirror  | [4673:1217/162607.651240:ERROR:bus.cc(393)] Failed to connect to the bus: Failed to connect to socket /tmp/dbus-rSguYNpjNi: Connection refused
0|MagicMirror  | [4705:1217/162608.260106:ERROR:sandbox_linux.cc(376)] InitializeSandbox() called with multiple threads in process gpu-process.
0|MagicMirror  | [17.12.2021 16:26.09.807] [LOG]
0|MagicMirror  | [17.12.2021 16:26.09.811] [LOG]   Stopping module helper: updatenotification
^A0|MagicMirror  | [17.12.2021 16:26.14.742] [LOG]
0|MagicMirror  | [17.12.2021 16:26.14.762] [LOG]
0|MagicMirror  | [17.12.2021 16:26.14.779] [LOG]
0|MagicMirror  | [17.12.2021 16:26.14.787] [LOG]   No helper found for module: alert.
0|MagicMirror  | [17.12.2021 16:26.14.838] [LOG]
0|MagicMirror  | [17.12.2021 16:26.14.843] [LOG]
0|MagicMirror  | [17.12.2021 16:26.14.848] [LOG]   No helper found for module: clock.
0|MagicMirror  | [17.12.2021 16:26.14.851] [LOG]   All module helpers loaded.
]]></description><link>https://forum.magicmirror.builders/post/97601</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/97601</guid><dc:creator><![CDATA[Cliff365]]></dc:creator><pubDate>Fri, 17 Dec 2021 22:29:15 GMT</pubDate></item><item><title><![CDATA[Reply to MM and UBUNTU. Made for each other. on Fri, 17 Dec 2021 21:23:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cliff365" aria-label="Profile: cliff365">@<bdi>cliff365</bdi></a> is it before adding any modules? or after?</p>
<p dir="auto">if after see here<br />
<a href="https://forum.magicmirror.builders/topic/15778/fix-for-black-screen-in-2-16-and-later">https://forum.magicmirror.builders/topic/15778/fix-for-black-screen-in-2-16-and-later</a></p>
<p dir="auto">if before do</p>
<pre><code>pm2 stop all
pm2 flush
pm2 start 0
pm2 logs --lines=50
]]></description><link>https://forum.magicmirror.builders/post/97600</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/97600</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 17 Dec 2021 21:23:18 GMT</pubDate></item><item><title><![CDATA[Reply to MM and UBUNTU. Made for each other. on Fri, 17 Dec 2021 20:04:45 GMT]]></title><description><![CDATA[<p dir="auto">I know this thread is quite old, hoping <a class="plugin-mentions-user plugin-mentions-a" href="/user/mykle1" aria-label="Profile: Mykle1">@<bdi>Mykle1</bdi></a> or someone still looks at it.</p>
<p dir="auto">I followed the instructions and have a MM running on my Acer Revo. However, when I start MagicMirror, all I see is a blank screen. I have pm2 and electron installed, where do I find the logfile to try to track down the issue?</p>
]]></description><link>https://forum.magicmirror.builders/post/97597</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/97597</guid><dc:creator><![CDATA[Cliff365]]></dc:creator><pubDate>Fri, 17 Dec 2021 20:04:45 GMT</pubDate></item><item><title><![CDATA[Reply to MM and UBUNTU. Made for each other. on Fri, 12 Apr 2019 02:22:35 GMT]]></title><description><![CDATA[<h3>By popular demand</h3>
<p dir="auto">Install ubuntu 16.04LTS (internet connection HIGHLY recommended)</p>
<p dir="auto">You MUST (check box) “Install 3rd Party Drivers” during installation</p>
<p dir="auto">Fully update the installation via the software manager after installation (It often needs to)</p>
<p dir="auto"><strong>Install node (includes npm) (I use node  8 )</strong></p>
<ol>
<li><code>curl -sL https://deb.nodesource.com/setup_8.x | sudo -E bash -</code></li>
</ol>
<p dir="auto">It will ask you if you want to install curl (gives you the command). Do so. Then run #1 again</p>
<ol start="2">
<li>This will complete the installation of node and npm</li>
</ol>
<p dir="auto"><code>sudo apt-get install -y nodejs</code></p>
<ol start="3">
<li>Check for success of node and npm installation in your terminal.</li>
</ol>
<p dir="auto">run<code> node -v</code> (this will show your version)<br />
run <code>npm -v</code>  (this will show your version)</p>
<p dir="auto"><strong>Now install MM</strong></p>
<p dir="auto">Run <code>git clone https://github.com/MichMich/MagicMirror.git</code> in your terminal</p>
<p dir="auto">You may be asked to install git here. Do so. Use the command presented to you in the terminal</p>
<p dir="auto">Then run <code>git clone https://github.com/MichMich/MagicMirror.git</code> again</p>
<p dir="auto">Then <code>cd MagicMirror</code> and run <code>npm install</code></p>
<p dir="auto">Then run your mirror <code>npm start</code></p>
]]></description><link>https://forum.magicmirror.builders/post/55777</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/55777</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Fri, 12 Apr 2019 02:22:35 GMT</pubDate></item><item><title><![CDATA[Reply to MM and UBUNTU. Made for each other. on Tue, 09 Apr 2019 22:08:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/justjim1220" aria-label="Profile: justjim1220">@<bdi>justjim1220</bdi></a></p>
<p dir="auto">Yes, as I said, I too had ubuntu 18.xx and MM up and running. I just prefer NOT to deal with any vulnerabilities which 16.04 doesn’t have. I don’t know of any benefit to running 18.xx over 16.04 and, as I stated, I’m not a fan of the new UI in 18.xx. I ran MM over Windows when I first started. The disadvantages quickly became apparent. Hello-Lucy never would have happened if I didn’t leave Windows behind. I never looked back. :-)</p>
]]></description><link>https://forum.magicmirror.builders/post/55692</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/55692</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Tue, 09 Apr 2019 22:08:56 GMT</pubDate></item><item><title><![CDATA[Reply to MM and UBUNTU. Made for each other. on Tue, 09 Apr 2019 05:08:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mykle1" aria-label="Profile: Mykle1">@<bdi>Mykle1</bdi></a></p>
<p dir="auto">I had version 18.xx installed, up and going just fine on my dev machine</p>
<p dir="auto">I am used to dealing with vulnerabilities, since I mainly work with Windows</p>
<p dir="auto">But, I just have my mindset to run <code>npm audit fix --force</code> &amp; <code>npm i lodash@4.17.5 -g</code> &amp; <code>npm i acorn@^6.0.0 -g</code> after every install of MM2. only takes a few minutes extra and it fixes all the vulnerabilities. Except for a few that come with some of the modules. With Ubuntu 18.xx, if I remember, I think just the <code>npm audit fix --force</code> was all I needed to do.</p>
]]></description><link>https://forum.magicmirror.builders/post/55658</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/55658</guid><dc:creator><![CDATA[justjim1220]]></dc:creator><pubDate>Tue, 09 Apr 2019 05:08:04 GMT</pubDate></item><item><title><![CDATA[Reply to MM and UBUNTU. Made for each other. on Tue, 09 Apr 2019 05:02:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mykle1" aria-label="Profile: Mykle1">@<bdi>Mykle1</bdi></a>  Nice Find! :)</p>
]]></description><link>https://forum.magicmirror.builders/post/55657</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/55657</guid><dc:creator><![CDATA[justjim1220]]></dc:creator><pubDate>Tue, 09 Apr 2019 05:02:17 GMT</pubDate></item><item><title><![CDATA[Reply to MM and UBUNTU. Made for each other. on Tue, 09 Apr 2019 04:26:44 GMT]]></title><description><![CDATA[<p dir="auto">not gonna lie, i actually have a i5 mini pc laying around and have been fiddling with the pis for weeks now trying to get everything dialed in and your post got me a little pumped to be able to use this pc i got.</p>
<p dir="auto">i got ubuntu installed no problem…</p>
<p dir="auto">i know NOTHING about it so i couldnt even get past how to install the wireless adapter lol…</p>
<p dir="auto">so im scrapping this and going back to install raspbian on the pc and will try it at that point.</p>
]]></description><link>https://forum.magicmirror.builders/post/55655</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/55655</guid><dc:creator><![CDATA[batfastard]]></dc:creator><pubDate>Tue, 09 Apr 2019 04:26:44 GMT</pubDate></item><item><title><![CDATA[Reply to MM and UBUNTU. Made for each other. on Sat, 23 Mar 2019 21:21:28 GMT]]></title><description><![CDATA[<h2>Recommendation Update</h2>
<p dir="auto">Actually, this is more of a recommendation confirmation. While you can use ubuntu 18.xx and MM together, I don’t recommend it. I just did a clean install of ubuntu 18.04. Newest stable node and npm. MM v2.6.0.  Yes, it runs MM but I don’t see any benefit to using ubuntu 18.xx over 16.04 LTS. I don’t like the changes to the UI in 18.xx and I really don’t like dealing with all the vulnerabilities.</p>
<p dir="auto">Ubuntu 16.04 LTS has a more intuitive UI (IMHO) and there are NO vulnreablilities to deal with. NONE!</p>
<p dir="auto">So, for the time being, I’m staying with Ubuntu 16.04 LTS. It’s trouble free and MM loves it, too.</p>
<p dir="auto">I did a test install of Ubuntu 18.04 on a machine I found in someone’s trash. That’s when the vulnerabilities reminded me of why I don’t like 18.xx. Look at the specs. One man’s trash is another man’s treasure.</p>
<p dir="auto"><img src="/assets/uploads/files/1553376080365-garbagepc.png" alt="0_1553376079773_GarbagePC.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/54801</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/54801</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Sat, 23 Mar 2019 21:21:28 GMT</pubDate></item><item><title><![CDATA[Reply to MM and UBUNTU. Made for each other. on Sat, 29 Dec 2018 03:19:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bhepler" aria-label="Profile: bhepler">@<bdi>bhepler</bdi></a> said in <a href="/post/48750">MM and UBUNTU. Made for each other.</a>:</p>
<p dir="auto">Sigh. I suppose I can try again. Did you have to do any fiddling to get the OS to use a graphics driver?</p>
<p dir="auto">No sir. I did a standard install of ubuntu 16.04LTS (I only use this version. I tried 18.xx and had trouble) During the setup of the installation there is a click box for “use third party drivers” or something to that effect. I always click (enable) that option. I don’t know if it’s worth mentioning but I always use a wired internet connection during installation. It’s just faster that way as it updates everything.</p>
<p dir="auto">Let me know how you make out. :thumbsup:</p>
]]></description><link>https://forum.magicmirror.builders/post/48777</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/48777</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Sat, 29 Dec 2018 03:19:23 GMT</pubDate></item><item><title><![CDATA[Reply to MM and UBUNTU. Made for each other. on Fri, 28 Dec 2018 20:12:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mykle1" aria-label="Profile: mykle1">@<bdi>mykle1</bdi></a> - Sigh. I suppose I can try again. Did you have to do any fiddling to get the OS to use a graphics driver?</p>
]]></description><link>https://forum.magicmirror.builders/post/48750</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/48750</guid><dc:creator><![CDATA[bhepler]]></dc:creator><pubDate>Fri, 28 Dec 2018 20:12:22 GMT</pubDate></item><item><title><![CDATA[Reply to MM and UBUNTU. Made for each other. on Mon, 28 Jan 2019 02:16:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bhepler" aria-label="Profile: bhepler">@<bdi>bhepler</bdi></a> said in <a href="/post/48618">MM and UBUNTU. Made for each other.</a>:</p>
<p dir="auto">Intel Atom processor and integrated graphics is not suitable for Ubuntu and therefore the MagicMirror.</p>
<p dir="auto">The only two laptops that I’ve had trouble with are both ThinkPads. I struggled with them and eventually gave up.</p>
<p dir="auto">However, I did have success with a little piece of $h1t with specs similar to what you mentioned.</p>
<p dir="auto"><a href="https://www.youtube.com/watch?v=QZ8t3UoKYu0" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.youtube.com/watch?v=QZ8t3UoKYu0</a></p>
<p dir="auto">Total cost = $11</p>
<p dir="auto"><strong>Specs:</strong></p>
<p dir="auto">ASUS Eee PC<br />
Intel Atom CPU N570 @ 1.66GHz x 4<br />
2GB of RAM<br />
Intel Pineview M Graphics<br />
Display 8.5" width by 5.25" height<br />
250GB HD<br />
Integrated microphone<br />
Built-in WiFi<br />
VGA port (for external monitor)</p>
<p dir="auto">$11 on craigslist</p>
<p dir="auto">64-bit Ubuntu 14.04 LTS<br />
MagicMirror v2.1.3</p>
<p dir="auto">Modules:</p>
<p dir="auto">MMM-Advice<br />
AlarmClock<br />
calendar<br />
clock<br />
compliments<br />
Cocktails<br />
EARTH<br />
EasyBack<br />
Events<br />
FMI (Find My iPhone)<br />
ImageSlideshow<br />
Lunartic<br />
newsfeed<br />
NOAA3<br />
PC-Stats<br />
voice w/ Hello-Lucy<br />
WunderGround</p>
]]></description><link>https://forum.magicmirror.builders/post/48621</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/48621</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Mon, 28 Jan 2019 02:16:06 GMT</pubDate></item><item><title><![CDATA[Reply to MM and UBUNTU. Made for each other. on Thu, 27 Dec 2018 01:35:44 GMT]]></title><description><![CDATA[<p dir="auto">I did learn the hard way that a miniPC running an Intel Atom processor and integrated graphics is not suitable for Ubuntu and therefore the MagicMirror. The IGP does not have drivers in Ubuntu 14, 16, nor 18 and uses most of its power to render the desktop.</p>
<p dir="auto">I might put the server version on it and turn it into a gateway or something.</p>
]]></description><link>https://forum.magicmirror.builders/post/48618</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/48618</guid><dc:creator><![CDATA[bhepler]]></dc:creator><pubDate>Thu, 27 Dec 2018 01:35:44 GMT</pubDate></item><item><title><![CDATA[Reply to MM and UBUNTU. Made for each other. on Tue, 25 Dec 2018 22:52:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mdhenriksen" aria-label="Profile: mdhenriksen">@<bdi>mdhenriksen</bdi></a> said in <a href="/post/48551">MM and UBUNTU. Made for each other.</a>:</p>
<p dir="auto">Using MMM-pages and MMM-voice, so a more powerful CPU would be preferred.</p>
<p dir="auto">That is largely the reason I moved away from the Pi. (I still have my first Pi mirror). I’ve been using MMM-voice and Hello-Lucy for about a year now and I could not be more pleased with the results and the performance.</p>
]]></description><link>https://forum.magicmirror.builders/post/48552</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/48552</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Tue, 25 Dec 2018 22:52:07 GMT</pubDate></item><item><title><![CDATA[Reply to MM and UBUNTU. Made for each other. on Tue, 25 Dec 2018 22:47:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mykle1" aria-label="Profile: mykle1">@<bdi>mykle1</bdi></a> said in <a href="/post/48550">MM and UBUNTU. Made for each other.</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mdhenriksen" aria-label="Profile: mdhenriksen">@<bdi>mdhenriksen</bdi></a></p>
<p dir="auto">I have not found heat to be an issue at all. In fact, by removing the motherboard from the case, the temps are actually lower, even when placed behind a mirror. As long as the construction of the mirror is well ventilated, I don’t think that would ever be an issue.</p>
<p dir="auto">I do not remove the fan. I’ve found that in a normal environment, (people, tv, ambient noises, etc…) the fan noise isn’t even noticeable. Only when the house, or room, is completely silent is the fan audible. For me, this is not an issue when a mobo mirror outperforms any Pi mirror, hands down.</p>
<p dir="auto">Note: There are silent fans these days but I have never used them with a mirror. I’ve never felt the need to but that is certainly an option for anyone.</p>
<p dir="auto">Nice to know! Got a old laptop I’m gonna try it with then! Using MMM-pages and MMM-voice, so a more powerful CPU would be preferred.</p>
]]></description><link>https://forum.magicmirror.builders/post/48551</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/48551</guid><dc:creator><![CDATA[mdhenriksen]]></dc:creator><pubDate>Tue, 25 Dec 2018 22:47:57 GMT</pubDate></item><item><title><![CDATA[Reply to MM and UBUNTU. Made for each other. on Tue, 25 Dec 2018 22:46:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mdhenriksen" aria-label="Profile: mdhenriksen">@<bdi>mdhenriksen</bdi></a></p>
]]></description><link>https://forum.magicmirror.builders/post/48550</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/48550</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Tue, 25 Dec 2018 22:46:06 GMT</pubDate></item><item><title><![CDATA[Reply to MM and UBUNTU. Made for each other. on Tue, 25 Dec 2018 22:00:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mykle1" aria-label="Profile: Mykle1">@<bdi>Mykle1</bdi></a> Using old laptops makes sense to me too. <strong>But i do have one question;</strong> how do you manage heat and fan noise? I’m concerned that an old laptop gets hotter than a Pi behind a mirror and if its using a HDD and has a fan it must either get noisy or hot (if you disconnect the fan)</p>
]]></description><link>https://forum.magicmirror.builders/post/48546</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/48546</guid><dc:creator><![CDATA[mdhenriksen]]></dc:creator><pubDate>Tue, 25 Dec 2018 22:00:30 GMT</pubDate></item><item><title><![CDATA[Reply to MM and UBUNTU. Made for each other. on Mon, 23 Apr 2018 19:51:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kruemel" aria-label="Profile: kruemel">@<bdi>kruemel</bdi></a></p>
<p dir="auto">How do you wake the screen up like a PIR-Sensor does?</p>
<p dir="auto">I use voice commands with Hello-Lucy to put my displays to sleep and to wake them up. I use this on my Pi mirror. <a href="https://github.com/alexyak/motiondetector" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/alexyak/motiondetector</a></p>
]]></description><link>https://forum.magicmirror.builders/post/38791</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/38791</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Mon, 23 Apr 2018 19:51:33 GMT</pubDate></item><item><title><![CDATA[Reply to MM and UBUNTU. Made for each other. on Mon, 23 Apr 2018 10:19:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mykle1" aria-label="Profile: Mykle1">@<bdi>Mykle1</bdi></a> How do you did the wake up with a webcam?<br />
Let’s say a notebook has always an integrated webcam on top of the display. How do you wake the screen up like a PIR-Sensor does?</p>
]]></description><link>https://forum.magicmirror.builders/post/38767</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/38767</guid><dc:creator><![CDATA[kruemel]]></dc:creator><pubDate>Mon, 23 Apr 2018 10:19:18 GMT</pubDate></item><item><title><![CDATA[Reply to MM and UBUNTU. Made for each other. on Wed, 18 Apr 2018 15:08:59 GMT]]></title><description><![CDATA[<p dir="auto">Raspberry pi is fine to mount a prototype, but with MM and Kalliope shows freezing moments …<br />
On the laptop: everything is easy and the answer is immediate.<br />
My next MM with Kalliope (voice) will be in a mini PC. More expensive, yes, but it compensates the normal fluency that these app requires</p>
]]></description><link>https://forum.magicmirror.builders/post/38589</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/38589</guid><dc:creator><![CDATA[pepebc]]></dc:creator><pubDate>Wed, 18 Apr 2018 15:08:59 GMT</pubDate></item><item><title><![CDATA[Reply to MM and UBUNTU. Made for each other. on Tue, 17 Apr 2018 22:42:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/barnosch" aria-label="Profile: barnosch">@<bdi>barnosch</bdi></a> said in <a href="/post/38479">MM and UBUNTU. Made for each other.</a>:</p>
<p dir="auto">Habe you compared the Laptops Power consumption with the raspberries? ;)<br />
For sure it runs way better, but if you use just normal stuff, it is absolute not necessary imho.<br />
Most of us use the mirror on the wall, without tons of cables (execpt Power) viewable. With a Laptop you have to be more tricky.</p>
<p dir="auto">You’re not just running a raspberry. You’re also powering a display. I have not compared but I am sure there is a nominal difference. If there is a difference, the performance boost outweighs the cost difference.</p>
<p dir="auto">Normal stuff? There are single modules that the Pi struggles with. I don’t accept stuttering transitions, RAM inadequacies, system overload and heat issues just to use a Pi.</p>
<p dir="auto">I don’t know how you speak for “most of us”, but ok. Disassemble the laptop. Fits behind mirror as easily as a Pi. Only the power cord showing. How is this different from a Pi mirror? It’s not.</p>
]]></description><link>https://forum.magicmirror.builders/post/38482</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/38482</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Tue, 17 Apr 2018 22:42:40 GMT</pubDate></item><item><title><![CDATA[Reply to MM and UBUNTU. Made for each other. on Tue, 17 Apr 2018 22:42:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kruemel" aria-label="Profile: kruemel">@<bdi>kruemel</bdi></a> said in <a href="/post/38468">MM and UBUNTU. Made for each other.</a>:</p>
<p dir="auto">And what are your solutions for GPIO related stuff like temperatur sensor or PIR-Sensor (infrared or radar).<br />
Do you always use the laptop screen or how does this look?</p>
<p dir="auto">I don’t need a GPIO solution for temperature sensors. My thermostat already tells me that information. PIR sensor for motion? Not necessary. A simple usb webcam will do the trick. You can use the laptop display or you can use an external monitor when the laptop board supports that. I haven’t seen one that doesn’t.</p>
]]></description><link>https://forum.magicmirror.builders/post/38480</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/38480</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Tue, 17 Apr 2018 22:42:05 GMT</pubDate></item></channel></rss>
