<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Raspbian on Apple hardware - can&#x27;t install MM because it&#x27;s &quot;not a Pi 2&#x2F;3&quot;]]></title><description><![CDATA[<p dir="auto">Hi there</p>
<p dir="auto">I just installed Raspbian on a USB stick so that I can prototype my MM without having to run the Pi, be in the presence of the specific monitor, etc - but upon trying to install MM, it fails immediately because the hardware platform is not recognised as a Pi 2 or 3.</p>
<p dir="auto">Is there any way round this? Spoofing MM, or commenting out the code that identifies the Pi version?</p>
<p dir="auto">Any help much appreciated, I am essentially All Noob.</p>
]]></description><link>https://forum.magicmirror.builders/topic/7009/raspbian-on-apple-hardware-can-t-install-mm-because-it-s-not-a-pi-2-3</link><generator>RSS for Node</generator><lastBuildDate>Wed, 10 Jun 2026 09:09:07 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/7009.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 18 Apr 2018 16:20:01 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Raspbian on Apple hardware - can&#x27;t install MM because it&#x27;s &quot;not a Pi 2&#x2F;3&quot; on Wed, 18 Apr 2018 19:45:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/yawns" aria-label="Profile: yawns">@<bdi>yawns</bdi></a> …update,</p>
<p dir="auto">downloaded installers/raspberry.sh, removed the lines in which the script sniffs your pi, saved it to my dropbox and ran it from there. Installing now, will update if successful.</p>
<p dir="auto">update: unsuccessful. Was going great until it hit the same problem - “npm - command not found. Unable to install dependencies.”</p>
<p dir="auto">I wonder why npm is not flying on this port of Pixel.</p>
]]></description><link>https://forum.magicmirror.builders/post/38602</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/38602</guid><dc:creator><![CDATA[bnsrx]]></dc:creator><pubDate>Wed, 18 Apr 2018 19:45:08 GMT</pubDate></item><item><title><![CDATA[Reply to Raspbian on Apple hardware - can&#x27;t install MM because it&#x27;s &quot;not a Pi 2&#x2F;3&quot; on Wed, 18 Apr 2018 19:00:38 GMT]]></title><description><![CDATA[<p dir="auto">Thanks. Here’s a question though… having installed node.js on my Pixel Mac, I can’t just type “npm install &amp;&amp; npm start” - npm isn’t recognised. If I type node -v it doesn’t recognise that, or npm -v - but it does recognise nodejs -v.</p>
<p dir="auto">If I type nodejs and enter that…app?, and I then type npm install &amp;&amp; npm start, I get the response “npm should be run outside of your node repl, in your normal shell”.</p>
<p dir="auto">Any thoughts much appreciated.</p>
]]></description><link>https://forum.magicmirror.builders/post/38599</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/38599</guid><dc:creator><![CDATA[bnsrx]]></dc:creator><pubDate>Wed, 18 Apr 2018 19:00:38 GMT</pubDate></item><item><title><![CDATA[Reply to Raspbian on Apple hardware - can&#x27;t install MM because it&#x27;s &quot;not a Pi 2&#x2F;3&quot; on Wed, 18 Apr 2018 18:57:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bnsrx" aria-label="Profile: bnsrx">@<bdi>bnsrx</bdi></a> I think it’s worth a try, yes</p>
]]></description><link>https://forum.magicmirror.builders/post/38598</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/38598</guid><dc:creator><![CDATA[yawns]]></dc:creator><pubDate>Wed, 18 Apr 2018 18:57:37 GMT</pubDate></item><item><title><![CDATA[Reply to Raspbian on Apple hardware - can&#x27;t install MM because it&#x27;s &quot;not a Pi 2&#x2F;3&quot; on Wed, 18 Apr 2018 17:13:15 GMT]]></title><description><![CDATA[<p dir="auto">I did the curl install. Think I’ll have better luck on the git clone?</p>
]]></description><link>https://forum.magicmirror.builders/post/38593</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/38593</guid><dc:creator><![CDATA[bnsrx]]></dc:creator><pubDate>Wed, 18 Apr 2018 17:13:15 GMT</pubDate></item><item><title><![CDATA[Reply to Raspbian on Apple hardware - can&#x27;t install MM because it&#x27;s &quot;not a Pi 2&#x2F;3&quot; on Wed, 18 Apr 2018 17:04:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bnsrx" aria-label="Profile: bnsrx">@<bdi>bnsrx</bdi></a> did you git clone and npm install afterwards or did you try the automatic installation via curl?</p>
]]></description><link>https://forum.magicmirror.builders/post/38592</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/38592</guid><dc:creator><![CDATA[yawns]]></dc:creator><pubDate>Wed, 18 Apr 2018 17:04:43 GMT</pubDate></item></channel></rss>
