<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Other options to hanging the mirror on a wall]]></title><description><![CDATA[<p dir="auto">Hey all,<br />
So I recently moved and my new apartment has all concrete walls.  I cant drill into the walls to hang up my mirror so I wanted to ask here if anyone has any other ideas for a way to display my mirror?  It weighs a solid 30lbs or so, so I was thinking of using an art easel perhaps?</p>
<p dir="auto">Thanks in advance!</p>
]]></description><link>https://forum.magicmirror.builders/topic/7027/other-options-to-hanging-the-mirror-on-a-wall</link><generator>RSS for Node</generator><lastBuildDate>Mon, 07 Sep 2026 12:33:49 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/7027.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 20 Apr 2018 16:56:39 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Other options to hanging the mirror on a wall on Thu, 26 Apr 2018 16:51:59 GMT]]></title><description><![CDATA[<p dir="auto">You could try mounting it flush with the back edge of a dresser. A couple of vertical supports that can be screwed into the back of the dresser can also be attached to the back of the mirror. You could probably get away with a couple of 1" x 1" x 12" wooden boards that are screwed into the mirror box and the back of your dresser.</p>
<p dir="auto">The whole thing can then be pushed up against a wall and you will have a mirror sitting on your dresser.</p>
<p dir="auto">Edited to add: Or spring for a couple of flat aluminum stock. 1" wide, 12" long, 1/8" thick or so. Drill holes, screw into dresser &amp; frame. This would add less space to the depth of your setup.</p>
]]></description><link>https://forum.magicmirror.builders/post/38943</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/38943</guid><dc:creator><![CDATA[bhepler]]></dc:creator><pubDate>Thu, 26 Apr 2018 16:51:59 GMT</pubDate></item><item><title><![CDATA[Reply to Other options to hanging the mirror on a wall on Wed, 25 Apr 2018 14:22:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/orayoflighto" aria-label="Profile: orayoflighto">@<bdi>orayoflighto</bdi></a> Appreciate it!  I was able to get my mirror hung up in the end with very tiny (yet amazingly sturdy) wall tacks.  Was helpful going through the other options though</p>
]]></description><link>https://forum.magicmirror.builders/post/38882</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/38882</guid><dc:creator><![CDATA[SexyTrogg]]></dc:creator><pubDate>Wed, 25 Apr 2018 14:22:10 GMT</pubDate></item><item><title><![CDATA[Reply to Other options to hanging the mirror on a wall on Sat, 21 Apr 2018 01:54:59 GMT]]></title><description><![CDATA[<p dir="auto">Some options where discussed here:</p>
<p dir="auto"><a href="https://forum.magicmirror.builders/topic/4529/question-about-mounting-a-mirror-in-a-dorm/10">https://forum.magicmirror.builders/topic/4529/question-about-mounting-a-mirror-in-a-dorm/10</a></p>
]]></description><link>https://forum.magicmirror.builders/post/38694</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/38694</guid><dc:creator><![CDATA[orayoflighto]]></dc:creator><pubDate>Sat, 21 Apr 2018 01:54:59 GMT</pubDate></item><item><title><![CDATA[Reply to Other options to hanging the mirror on a wall on Fri, 20 Apr 2018 20:11:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/charley" aria-label="Profile: Charley">@<bdi>Charley</bdi></a> The issue is that i’m only renting and it’s in my lease to not make any holes in the walls.  I have a concrete drill bit so I may end up just doing that anyways if I can’t come up with another solution.</p>
]]></description><link>https://forum.magicmirror.builders/post/38686</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/38686</guid><dc:creator><![CDATA[SexyTrogg]]></dc:creator><pubDate>Fri, 20 Apr 2018 20:11:39 GMT</pubDate></item><item><title><![CDATA[Reply to Other options to hanging the mirror on a wall on Fri, 20 Apr 2018 20:03:56 GMT]]></title><description><![CDATA[<p dir="auto">My mirror is hanging over an electric outlet. With a proper drill you can drill a hole in concrete.</p>
]]></description><link>https://forum.magicmirror.builders/post/38685</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/38685</guid><dc:creator><![CDATA[Charley]]></dc:creator><pubDate>Fri, 20 Apr 2018 20:03:56 GMT</pubDate></item></channel></rss>
