<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-ModuleScheduler stops working if MMM-PIR is active]]></title><description><![CDATA[<p dir="auto">Hi everyone,</p>
<p dir="auto">I need some help here please :-)</p>
<p dir="auto">I’m on latest master and everything works fine. BUT when I active MMM-PIR, one of my MMM-ModuleScheduler schedules stops working. When I comment out MMM-PIR from the config everything works as expected.</p>
<p dir="auto">Any Idea what I could be doing wrong?</p>
<p dir="auto">Thanks!!</p>
<p dir="auto">Here is my config:</p>
 * MIT Licensed.
var config = {
	address: "", // Address to listen on, can be:
	port: 8080,
	ipWhitelist: [],  // Set [] to allow all IP addresses
	             //["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:10.10.10.51"],                                          // or add a specific IPv4 of 192.168.1.5 :
	language: "en",
	timeFormat: 24,
	units: "metric",
	electronOptions: {
		fullscreen: true,
			module: "alert"
      module: 'MMM-Remote-Control'
			module: 'MMM-ModuleScheduler',
					notification_schedule: [
					// RESTART THE MAGICMIRROR PROCESS AT 2am EVERY day
					{notification: 'REMOTE_ACTION', schedule: '0 2 * * *', payload: {action: "RESTART"}},
					// SHOW MODULES WITH THE CLASS 'go2work_scheduler' AT 06:00 AND HIDE AT 10:00 EVERY DAY
					global_schedule: {from: '0 6 * * *', to: '0 10 * * *', groupClass: 'go2work_scheduler' }
			module: "updatenotification",
			position: "top_bar"
			module: "clock",
			position: "top_left"
		  module: 'worldclock',
		  position: 'top_left', // This can be any of the regions, best results in top_left or top_right regions
		    timeFormat: 'HH:mm', //defined in moment.js format()
		    style: 'top', //predefined 4 styles; 'top', 'left','right','bottom'
		    clocks: [
		        title: "Bali", // Too long title could cause ugly text align.
		        timezone: "Asia/Makassar", //When omitted, Localtime will be displayed. It might be not your purporse, I bet.
		        flag: "id",
			header: "Termine",
			  displaySymbol: false,
						url: '',
						auth: {
						    user: '',
						    pass: '',
						    method: 'basic'
						url: '',
						auth: {
								user: '',
								pass: ''
								method: 'basic'
			header: "",
			  maximumEntries: "3",
						url: '',
						symbol: 'trash',
						auth: {
								user: '',
								pass: '',
								method: 'basic'
			module: "currentweather",
				locationID: "",  //ID from http://www.openweathermap.org/help/city_list.txt
				appid: ""
			module: "weatherforecast",
			header: "Weather Forecast",
				appid: ""
			module: "newsfeed",
			position: "bottom_bar",
				feeds: [
						title: "Der Postillion",
						url: "http://feeds.feedburner.com/blogspot/rkEL?format=xml"
						title: "Tagesschau",
						url: "http://www.tagesschau.de/xml/rss2"
				showSourceTitle: true,
				showPublishDate: true
    module: 'MMM-PIR',
    position: 'bottom_center',
        sensorPin: 22,
        delay: 30000,
        turnOffDisplay: true,
        showCountdown: false
			module: 'MMM-DWD-WarnWeather',
			position: 'top_right',
				region: '',
				changeColor: true,
				minutes: false,
				displayRegionName: true,
				interval: 10 * 60 * 1000, // every 10 minutes
				longversion: true,
				loadingText: 'Warnungen werden geladen...',
				noWarningText: 'Keine Warnungen'
			classes: 'test_scheduler',
				region: '',
        changeColor: true,
        minutes: false,
  		module: 'MMM-GoogleMapsTraffic',
			classes: 'scheduler',
				module_schedule: {from: '0 6 * * *', to: '0 10 * * *' },
	  		key: '',
	  		lat: ,
	  		lng: ,
	  		height: '300px',
	  		width: '300px'
			module: 'MMM-rfacts',
			position: 'bottom_bar'
		{ module: 'MMM-NiceThings',
			position: 'lower_third'
	 		module: 'DailyXKCD',
 			position: 'lower_third',
	 			invertColors: true,
				randomComic: true,
				titleFont: 'small',
	 			title: true,
	 			altText: false
<p dir="auto">Here is the pm2 out log:</p>
<pre><code>Starting MagicMirror: v2.3.1
Loading config ...
Loading module helpers ...
Module helper loaded: MMM-Remote-Control
Module helper loaded: MMM-ModuleScheduler
No helper found for module: worldclock.
Module helper loaded: MMM-PIR
Module helper loaded: MMM-DWD-WarnWeather
No helper found for module: MMM-GoogleMapsTraffic.
Module helper loaded: MMM-rfacts
Module helper loaded: MMM-NiceThings
Module helper loaded: DailyXKCD
All module helpers loaded.
You're using a full whitelist configuration to allow for all IPs
Server started ...
Connecting socket for: MMM-Remote-Control
Starting node helper for: MMM-Remote-Control
Connecting socket for: MMM-ModuleScheduler
Starting node helper for: MMM-ModuleScheduler
Starting module: newsfeed
Connecting socket for: MMM-PIR
Starting module helper: MMM-PIR
Connecting socket for: MMM-DWD-WarnWeather
MMM-DWD-WarnWeather helper started...
Connecting socket for: MMM-rfacts
Starting module: MMM-rfacts
Connecting socket for: MMM-NiceThings
Starting node_helper for: MMM-NiceThings
Connecting socket for: DailyXKCD
Starting node helper: DailyXKCD
Sockets connected &amp; modules started ...
Launching application.
MMM-ModuleScheduler is removing all scheduled jobs
MMM-ModuleScheduler received CREATE_NOTIFICATION_SCHEDULE
MMM-ModuleScheduler is scheduling REMOTE_ACTION using "0 2 * * *
MMM-ModuleScheduler has scheduled REMOTE_ACTION
MMM-ModuleScheduler will next send REMOTE_ACTION at Mon Apr 23 2018 02:00:00 GMT+0200 (CEST)
Create new calendar fetcher for url: - Interval: 300000
Create new news fetcher for url: http://feeds.feedburner.com/blogspot/rkEL?format=xml - Interval: 300000
Create new news fetcher for url: http://www.tagesschau.de/xml/rss2 - Interval: 300000
I made this website for you.
Notification: GET_COMIC Payload: [object Object]
]]></description><link>https://forum.magicmirror.builders/topic/7040/mmm-modulescheduler-stops-working-if-mmm-pir-is-active</link><generator>RSS for Node</generator><lastBuildDate>Sat, 15 Aug 2026 07:47:52 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/7040.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 22 Apr 2018 17:53:11 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-ModuleScheduler stops working if MMM-PIR is active on Sat, 28 Apr 2018 20:29:10 GMT]]></title><description><![CDATA[<p dir="auto">Don’t forget to check the error logs and dmesg.</p>
]]></description><link>https://forum.magicmirror.builders/post/39044</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/39044</guid><dc:creator><![CDATA[E3V3A]]></dc:creator><pubDate>Sat, 28 Apr 2018 20:29:10 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-ModuleScheduler stops working if MMM-PIR is active on Fri, 27 Apr 2018 22:08:16 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/user/flo269" aria-label="Profile: flo269">@<bdi>flo269</bdi></a> - are you able to review the console in the browser and see if there are any errors there?</p>
]]></description><link>https://forum.magicmirror.builders/post/39021</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/39021</guid><dc:creator><![CDATA[ianperrin]]></dc:creator><pubDate>Fri, 27 Apr 2018 22:08:16 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-ModuleScheduler stops working if MMM-PIR is active on Thu, 26 Apr 2018 16:42:19 GMT]]></title><description><![CDATA[<p dir="auto">Hello again!</p>
<p dir="auto">Does anyone have any idea where I could look or what I could do? :-)</p>
<p dir="auto">Yesterday I even setup everything from scratch (same config though) and had the same issue again…</p>
<p dir="auto">Any hint/help is highly appreiciated!</p>
<p dir="auto">Cheers<br />
Flo</p>
]]></description><link>https://forum.magicmirror.builders/post/38941</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/38941</guid><dc:creator><![CDATA[flo269]]></dc:creator><pubDate>Thu, 26 Apr 2018 16:42:19 GMT</pubDate></item></channel></rss>
