<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[no space on SD-card]]></title><description><![CDATA[<p dir="auto">Re: <a href="/topic/2547/no-free-space-on-sd-card">No free space on SD-card</a><br />
my problem si back. But now it’s worse - Raspberry doesn’t boot at all - freeze in different time…GUI doesn’t start. I’ve the SD in my Mac and there is no space. I deleted old modules… What else I can delete? I can’t access folders like “root”, or delete files in /var/logs probably cause of access restrictions. Is there way, how to boot MM to CLI by pressing any key-combination?</p>
<p dir="auto">thanks<br />
Zdeněk</p>
]]></description><link>https://forum.magicmirror.builders/topic/7062/no-space-on-sd-card</link><generator>RSS for Node</generator><lastBuildDate>Fri, 15 May 2026 17:32:28 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/7062.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 25 Apr 2018 19:18:44 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to no space on SD-card on Mon, 05 Aug 2019 08:02:55 GMT]]></title><description><![CDATA[<p dir="auto">try going to the service station.<br />
they help. or use <a href="https://techyhost.com/" target="_blank" rel="noopener noreferrer nofollow ugc">TechyHost.com</a><br />
Or try reinstalling raspberry.<br />
Regards.</p>
]]></description><link>https://forum.magicmirror.builders/post/55550</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/55550</guid><dc:creator><![CDATA[ryanjenson90]]></dc:creator><pubDate>Mon, 05 Aug 2019 08:02:55 GMT</pubDate></item><item><title><![CDATA[Reply to no space on SD-card on Sun, 29 Apr 2018 07:26:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/e3v3a" aria-label="Profile: E3V3A">@<bdi>E3V3A</bdi></a> thx. At the moment I’ve there 32 GB card. And for sure, after I’ll finalize the layout of my Mirror, I’ll do a clone of the SD card :-)</p>
<p dir="auto">Zdeněk</p>
]]></description><link>https://forum.magicmirror.builders/post/39059</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/39059</guid><dc:creator><![CDATA[zdenek]]></dc:creator><pubDate>Sun, 29 Apr 2018 07:26:18 GMT</pubDate></item><item><title><![CDATA[Reply to no space on SD-card on Sat, 28 Apr 2018 20:38:00 GMT]]></title><description><![CDATA[<p dir="auto">8 GB definitely way too small. You need 32 GB min, especially if you plan to keep the card running more than 6 months striaght. (There’s a limit how many times you can write to a card.), Also for speed make sure it’s <strong>at least</strong>  classed as 10 / U1, but best performance is with a A1/2.</p>
]]></description><link>https://forum.magicmirror.builders/post/39046</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/39046</guid><dc:creator><![CDATA[E3V3A]]></dc:creator><pubDate>Sat, 28 Apr 2018 20:38:00 GMT</pubDate></item><item><title><![CDATA[Reply to no space on SD-card on Fri, 27 Apr 2018 04:23:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bhepler" aria-label="Profile: bhepler">@<bdi>bhepler</bdi></a> thank 4 for answer…</p>
<ol>
<li>8GB</li>
<li>not possible, cause Rapsberry stopped to start at all</li>
<li>already did before…</li>
</ol>
<p dir="auto">finally, I took 32 GB, start from the very begin… I found a way, how to install in Virtualbox on my Mac Ubuntu and mount old SD card, so I can get copy of MM folder. So now, I’ve almost done, just some modules need to get work, but the main modules are working</p>
<p dir="auto">thanks</p>
]]></description><link>https://forum.magicmirror.builders/post/38972</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/38972</guid><dc:creator><![CDATA[zdenek]]></dc:creator><pubDate>Fri, 27 Apr 2018 04:23:13 GMT</pubDate></item><item><title><![CDATA[Reply to no space on SD-card on Thu, 26 Apr 2018 16:44:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/zdenek" aria-label="Profile: zdenek">@<bdi>zdenek</bdi></a> First, how big is your SD card?</p>
<p dir="auto">Second, you can probably copy off the <code>config.js</code> file out of the <code>/home/pi/MagicMirror/configure</code> folder and then delete the entire <code>/home/pi/MagicMirror</code> folder. That should give you enough space to get your Pi back up &amp; running.</p>
<p dir="auto">Third, you can remove the applications that come with the Raspian operating system that aren’t necessary for the Magic Mirror to function with this command:<br />
<code>sudo apt-get remove --purge idle3	java-common libreoffice* minecraft-pi scratch nuscratch penguinspuzzle python-minecraftpi python3-minecraftpi smartsim sonic-pi wolfram-engine</code><br />
Follow it up with the automated cleanup: <code>sudo apt-get autoremove -y</code>.</p>
<p dir="auto">That should free up some space once you get your Pi booted again.</p>
]]></description><link>https://forum.magicmirror.builders/post/38942</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/38942</guid><dc:creator><![CDATA[bhepler]]></dc:creator><pubDate>Thu, 26 Apr 2018 16:44:23 GMT</pubDate></item></channel></rss>
