<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Newsfeed : How to keep &quot;showDescription&quot; after leaving the full article?]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">I would like to see the description of the news in the newsfeed all the time.<br />
So, like mentioned in the options, I changed the “showDescription = false” in the newsfeed.js to “true”.<br />
It works fine. I can see the description of every article without doing anything, even when the articles update.</p>
<p dir="auto">The problem is when I use the command “ARTICLE_MORE_DETAILS” to open the full article. It works like a charm, but when I close the full article I use the command “ARTICLE_LESS_DETAILS”. It goes back to the newsfeed but unfortunately without showing the descriptions anymore. I only see the headlines (like “showDescription = false” although “true” is still set of course).</p>
<p dir="auto">If I use the command “ARTICLE_MORE_DETAILS” again, the description opens, but the article is freezed - like coded.</p>
<p dir="auto">Do you have any idea, how I can leave the full article going back to the “show-description-version”?<br />
Or instead, how can I remove the freeze?</p>
<p dir="auto">Thanks a lot.<br />
Greetings</p>
<p dir="auto">Mr.Coffee</p>
]]></description><link>https://forum.magicmirror.builders/topic/7116/newsfeed-how-to-keep-showdescription-after-leaving-the-full-article</link><generator>RSS for Node</generator><lastBuildDate>Sat, 11 Apr 2026 23:21:35 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/7116.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 05 May 2018 23:31:56 GMT</pubDate><ttl>60</ttl></channel></rss>
