<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Led without Bread-boards !]]></title><description><![CDATA[<p dir="auto">Hi folks :</p>
<p dir="auto">is there any possibility that I can add led lights to my magicmirror through USB or without Bread-boards n gpio?  is there any module for that?</p>
]]></description><link>https://forum.magicmirror.builders/topic/7176/led-without-bread-boards</link><generator>RSS for Node</generator><lastBuildDate>Tue, 19 May 2026 10:32:03 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/7176.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 15 May 2018 11:01:12 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Led without Bread-boards ! on Tue, 05 Jun 2018 07:51:30 GMT]]></title><description><![CDATA[<p dir="auto">Hello</p>
<p dir="auto">I made a small module for the mmm to pilot led strip but you need breadboard transistor and resistance</p>
<p dir="auto">Tell me if you want me to explain more</p>
]]></description><link>https://forum.magicmirror.builders/post/40206</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/40206</guid><dc:creator><![CDATA[bimbim2401]]></dc:creator><pubDate>Tue, 05 Jun 2018 07:51:30 GMT</pubDate></item><item><title><![CDATA[Reply to Led without Bread-boards ! on Wed, 16 May 2018 12:51:37 GMT]]></title><description><![CDATA[<p dir="auto">I agree with maxbachmann. Go for Philips Hue for example. You can control with your smartphone and with Alexa</p>
]]></description><link>https://forum.magicmirror.builders/post/39529</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/39529</guid><dc:creator><![CDATA[yawns]]></dc:creator><pubDate>Wed, 16 May 2018 12:51:37 GMT</pubDate></item><item><title><![CDATA[Reply to Led without Bread-boards ! on Wed, 16 May 2018 12:15:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/4lice" aria-label="Profile: 4lice">@<bdi>4lice</bdi></a> When you only want to control the color in a easy way you could just use one of those led stripes that already have a remote control to set the colors. If you want to control them with the raspberry pi it’s definetly easier to use the GPIO pins than USB ;) Why you want to use USB over the GPIO Pins? Breadboard is generally a fast build thing you use for testing purposes. You will have to consider that when using long LED stripes you definetly need more power than a raspberry pi can deilver so you will need to use a external power supply for them.</p>
]]></description><link>https://forum.magicmirror.builders/post/39528</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/39528</guid><dc:creator><![CDATA[maxbachmann]]></dc:creator><pubDate>Wed, 16 May 2018 12:15:49 GMT</pubDate></item><item><title><![CDATA[Reply to Led without Bread-boards ! on Wed, 16 May 2018 11:24:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/maxbachmann" aria-label="Profile: maxbachmann">@<bdi>maxbachmann</bdi></a>  I really wants to decorate my rooms with looong LED strings and stripes but not bulbs I want make small LED light flakes for Christmas, wedding holidays and ceremonies …<br />
but I don’t want using GPIO or the sheet white bread-board anymore I wanna using USB so how to control it with voice or Toggle button through mobile or something like that?</p>
]]></description><link>https://forum.magicmirror.builders/post/39526</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/39526</guid><dc:creator><![CDATA[4lice]]></dc:creator><pubDate>Wed, 16 May 2018 11:24:10 GMT</pubDate></item><item><title><![CDATA[Reply to Led without Bread-boards ! on Tue, 15 May 2018 22:49:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/4lice" aria-label="Profile: 4lice">@<bdi>4lice</bdi></a> there is not really a module that comes to my mind. However you should probably specify a bit more what you even want to achieve. There are tons of possibilities what you might want to do with leds. When people know what you actually want it’s a lot easier to provide you with tips on how to build it :)</p>
]]></description><link>https://forum.magicmirror.builders/post/39514</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/39514</guid><dc:creator><![CDATA[maxbachmann]]></dc:creator><pubDate>Tue, 15 May 2018 22:49:12 GMT</pubDate></item></channel></rss>
