<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-Reddit not working due to &#x27;width&#x27; being undefined]]></title><description><![CDATA[<p dir="auto"><img src="/assets/uploads/files/1526783903320-error.png" alt="0_1526783900889_error.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">A screenshot of the error I am getting. This was working before but now it is not. Unsure of how to proceed. Thank you for any help.</p>
]]></description><link>https://forum.magicmirror.builders/topic/7196/mmm-reddit-not-working-due-to-width-being-undefined</link><generator>RSS for Node</generator><lastBuildDate>Tue, 09 Jun 2026 14:47:19 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/7196.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 20 May 2018 02:39:25 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-Reddit not working due to &#x27;width&#x27; being undefined on Sun, 20 May 2018 03:02:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cowboysdude" aria-label="Profile: cowboysdude">@<bdi>cowboysdude</bdi></a> Thanks for the help. It seems that 50 was too large of a number. Maybe it couldn’t get 50 with the number of subreddits I choose or whatever. Now at 25, and everything else the same, it is running.</p>
]]></description><link>https://forum.magicmirror.builders/post/39673</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/39673</guid><dc:creator><![CDATA[Sitm09]]></dc:creator><pubDate>Sun, 20 May 2018 03:02:36 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Reddit not working due to &#x27;width&#x27; being undefined on Sun, 20 May 2018 02:53:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cowboysdude" aria-label="Profile: cowboysdude">@<bdi>cowboysdude</bdi></a> said in <a href="/post/39670">MMM-Reddit not working due to ‘width’ being undefined</a>:</p>
<p dir="auto">{<br />
module: “MMM-Reddit”,<br />
position: “top_right”,<br />
config: {<br />
subreddit: ‘earthporn’,<br />
displayType: ‘image’,<br />
imageQuality: ‘high’,<br />
count: 10,<br />
show: 1,<br />
width: 500,<br />
showAll: true,<br />
}<br />
},</p>
<p dir="auto">Some reason, this worked. Maybe a subreddit is messed up up for some reason. Thanks</p>
]]></description><link>https://forum.magicmirror.builders/post/39672</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/39672</guid><dc:creator><![CDATA[Sitm09]]></dc:creator><pubDate>Sun, 20 May 2018 02:53:19 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Reddit not working due to &#x27;width&#x27; being undefined on Sun, 20 May 2018 02:47:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cowboysdude" aria-label="Profile: cowboysdude">@<bdi>cowboysdude</bdi></a> <img src="/assets/uploads/files/1526784265891-config_reddit.png" alt="0_1526784263531_config_reddit.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">I reset the position back to a default region in the main.css (after the screenshot), but I still get the same error as prompted by your suggestion to go back to the defaults.  Before, I’ve been using this config for the module but it’s been working however.</p>
]]></description><link>https://forum.magicmirror.builders/post/39671</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/39671</guid><dc:creator><![CDATA[Sitm09]]></dc:creator><pubDate>Sun, 20 May 2018 02:47:59 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Reddit not working due to &#x27;width&#x27; being undefined on Sun, 20 May 2018 02:42:06 GMT]]></title><description><![CDATA[<p dir="auto">Try something simple like put this in your config.js file<br />
{<br />
config: {<br />
count: 10,<br />
show: 1,<br />
width: 500,<br />
}<br />
},</p>
<p dir="auto">which is pretty much the default example…try that and see if that works first…</p>
]]></description><link>https://forum.magicmirror.builders/post/39670</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/39670</guid><dc:creator><![CDATA[cowboysdude]]></dc:creator><pubDate>Sun, 20 May 2018 02:42:06 GMT</pubDate></item></channel></rss>
