<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MM2 on Synology NAS]]></title><description><![CDATA[<p dir="auto">Hi all,</p>
<p dir="auto">I’m trying to install MM on my synology. The steps I already performed:</p>
<ul>
<li>Install nodejs on synology</li>
<li>Install MM in serveronly mode</li>
<li>Copied config file and tried to whitelist IP address</li>
</ul>
<p dir="auto">I now can access the page on xxx.xxx.x.x./MagicMirror/ but i get an error that the config file is missing although it is available.</p>
<p dir="auto">If I look at the console error I see that <a href="http://xxx.xxx.x.x" target="_blank" rel="noopener noreferrer nofollow ugc">http://xxx.xxx.x.x</a>./socket.io/socket.io.js is not loading. I already tried to change this to a CDN pointed location, with no luck.</p>
<p dir="auto">I’m kidda stuck here, can anybody help me on the way?</p>
<p dir="auto">Cheers,</p>
]]></description><link>https://forum.magicmirror.builders/topic/7204/mm2-on-synology-nas</link><generator>RSS for Node</generator><lastBuildDate>Sat, 11 Jul 2026 23:14:45 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/7204.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 20 May 2018 22:33:10 GMT</pubDate><ttl>60</ttl></channel></rss>
