<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-Temperature&#x2F;Humidity Module (DHT11, DHT22 and AM2302 sensors.)]]></title><description><![CDATA[<p dir="auto">Temperature and Humidity monitoring Module for MagicMirror2 that works for DHT11, DHT22 and AM2302 sensors.<br />
Dependancy : rpi-dht-sensor<br />
For some reason, the module requires elevated permissions to run.(sudo npm start).</p>
<p dir="auto">It would be great if someone could help in this regard.</p>
<p dir="auto">Hope it comes of use to somebody else.</p>
<p dir="auto">Cheers.</p>
]]></description><link>https://forum.magicmirror.builders/topic/726/mmm-temperature-humidity-module-dht11-dht22-and-am2302-sensors</link><generator>RSS for Node</generator><lastBuildDate>Sat, 11 Apr 2026 13:50:01 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/726.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 28 Sep 2016 19:04:57 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-Temperature&#x2F;Humidity Module (DHT11, DHT22 and AM2302 sensors.) on Thu, 02 Jan 2020 05:56:04 GMT]]></title><description><![CDATA[<p dir="auto">Apparently, this project is dead. modules are missing all over the place, and unable to install…</p>
<p dir="auto">rpi-dht-sensor not found.<br />
npm install falls all over itself.</p>
<p dir="auto">Just a mess.</p>
]]></description><link>https://forum.magicmirror.builders/post/66962</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/66962</guid><dc:creator><![CDATA[BKeyport]]></dc:creator><pubDate>Thu, 02 Jan 2020 05:56:04 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Temperature&#x2F;Humidity Module (DHT11, DHT22 and AM2302 sensors.) on Tue, 08 Nov 2016 19:09:23 GMT]]></title><description><![CDATA[<p dir="auto">Right. I have the 4 pin version and this requires a resistor</p>
]]></description><link>https://forum.magicmirror.builders/post/7665</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/7665</guid><dc:creator><![CDATA[yawns]]></dc:creator><pubDate>Tue, 08 Nov 2016 19:09:23 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Temperature&#x2F;Humidity Module (DHT11, DHT22 and AM2302 sensors.) on Tue, 08 Nov 2016 18:59:46 GMT]]></title><description><![CDATA[<p dir="auto"><a href="http://www.circuitbasics.com/how-to-set-up-the-dht11-humidity-sensor-on-the-raspberry-pi/" target="_blank" rel="noopener noreferrer nofollow ugc">This</a> was my reference.  Both the models are similar, though the one without the PCB(4 pin model) might require some resistance. Not sure though…Need to dig Deeper :D<br />
Cheers :)</p>
]]></description><link>https://forum.magicmirror.builders/post/7663</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/7663</guid><dc:creator><![CDATA[psk]]></dc:creator><pubDate>Tue, 08 Nov 2016 18:59:46 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Temperature&#x2F;Humidity Module (DHT11, DHT22 and AM2302 sensors.) on Tue, 08 Nov 2016 14:13:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/psk" aria-label="Profile: psk">@<bdi>psk</bdi></a><br />
That depends on the sensor you buy. If you use a sensor with 4 pins you need the resistor. If you use the sensor with 3 pins mounted to a circuit board you don’t need the resistor.</p>
]]></description><link>https://forum.magicmirror.builders/post/7656</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/7656</guid><dc:creator><![CDATA[yawns]]></dc:creator><pubDate>Tue, 08 Nov 2016 14:13:56 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Temperature&#x2F;Humidity Module (DHT11, DHT22 and AM2302 sensors.) on Tue, 08 Nov 2016 13:56:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/d3r" aria-label="Profile: d3r">@<bdi>d3r</bdi></a>  Dht 22 and 11 series doesnt require one :)</p>
<p dir="auto">PS: Just saw the post.Was out of town for two weeks…</p>
]]></description><link>https://forum.magicmirror.builders/post/7655</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/7655</guid><dc:creator><![CDATA[psk]]></dc:creator><pubDate>Tue, 08 Nov 2016 13:56:30 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Temperature&#x2F;Humidity Module (DHT11, DHT22 and AM2302 sensors.) on Tue, 25 Oct 2016 16:26:57 GMT]]></title><description><![CDATA[<p dir="auto">I’m going to order the dht-22 soon. I was reading about the sensor set up and most guides mention using a resistor. Do you guys have one in your set up?</p>
]]></description><link>https://forum.magicmirror.builders/post/6872</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/6872</guid><dc:creator><![CDATA[d3r]]></dc:creator><pubDate>Tue, 25 Oct 2016 16:26:57 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Temperature&#x2F;Humidity Module (DHT11, DHT22 and AM2302 sensors.) on Thu, 20 Oct 2016 16:16:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/psk" aria-label="Profile: psk">@<bdi>psk</bdi></a> , when i execute your command in my pi3 from putty. will get below error.<br />
<img src="/uploads/files/1476980029062-upload-94e2d7d2-b3a1-493a-a093-7ac8645113c3.png" alt="0_1476980028924_upload-94e2d7d2-b3a1-493a-a093-7ac8645113c3" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/6562</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/6562</guid><dc:creator><![CDATA[jsyzthz]]></dc:creator><pubDate>Thu, 20 Oct 2016 16:16:00 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Temperature&#x2F;Humidity Module (DHT11, DHT22 and AM2302 sensors.) on Wed, 19 Oct 2016 13:12:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jsyzthz" aria-label="Profile: jsyzthz">@<bdi>jsyzthz</bdi></a> Unfortunately neither did I have any luck executing with sudo while using ‘DISPLAY=:0’ .</p>
<p dir="auto">For auto start I used <a href="https://github.com/MichMich/MagicMirror/wiki/Auto-Starting-MagicMirror" target="_blank" rel="noopener noreferrer nofollow ugc">PM2</a>.</p>
<p dir="auto">This is my <a href="http://mm.sh" target="_blank" rel="noopener noreferrer nofollow ugc">mm.sh</a> file</p>
<pre><code>cd ~/MagicMirror
DISPLAY=:0 sudo npm start
<p dir="auto">P.S : I haven’t yet tried <a href="https://forum.magicmirror.builders/topic/738/mmm-dht22-humidity-and-temperature-module">this</a> alternative by Bangee. But it sure looks promising  in this scenario where we need the mirror to start from ssh(or Terminal) while specifying the display device.</p>
<p dir="auto">If i come across any workarounds, I’ll update.<br />
Cheers.</p>
]]></description><link>https://forum.magicmirror.builders/post/6501</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/6501</guid><dc:creator><![CDATA[psk]]></dc:creator><pubDate>Wed, 19 Oct 2016 13:12:38 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Temperature&#x2F;Humidity Module (DHT11, DHT22 and AM2302 sensors.) on Mon, 17 Oct 2016 14:39:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jsyzthz" aria-label="Profile: jsyzthz">@<bdi>jsyzthz</bdi></a> checkt this out: <a href="https://forum.magicmirror.builders/topic/738/mmm-dht22-humidity-and-temperature-module">https://forum.magicmirror.builders/topic/738/mmm-dht22-humidity-and-temperature-module</a></p>
]]></description><link>https://forum.magicmirror.builders/post/6435</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/6435</guid><dc:creator><![CDATA[Bangee]]></dc:creator><pubDate>Mon, 17 Oct 2016 14:39:48 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Temperature&#x2F;Humidity Module (DHT11, DHT22 and AM2302 sensors.) on Mon, 17 Oct 2016 14:33:43 GMT]]></title><description><![CDATA[<p dir="auto">i found MMM cannot auto startup if use it. because it must be run with sudo. but i don’t know how to run sudo with ‘DISPLAY=:0’? <a class="plugin-mentions-user plugin-mentions-a" href="/user/psk" aria-label="Profile: psk">@<bdi>psk</bdi></a></p>
]]></description><link>https://forum.magicmirror.builders/post/6434</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/6434</guid><dc:creator><![CDATA[jsyzthz]]></dc:creator><pubDate>Mon, 17 Oct 2016 14:33:43 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Temperature&#x2F;Humidity Module (DHT11, DHT22 and AM2302 sensors.) on Sun, 02 Oct 2016 21:30:40 GMT]]></title><description><![CDATA[<p dir="auto">Tanks <a class="plugin-mentions-user plugin-mentions-a" href="/user/psk" aria-label="Profile: psk">@<bdi>psk</bdi></a></p>
]]></description><link>https://forum.magicmirror.builders/post/5710</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/5710</guid><dc:creator><![CDATA[H3L1o150]]></dc:creator><pubDate>Sun, 02 Oct 2016 21:30:40 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Temperature&#x2F;Humidity Module (DHT11, DHT22 and AM2302 sensors.) on Mon, 03 Oct 2016 12:26:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/h3l1o150" aria-label="Profile: H3L1o150">@<bdi>H3L1o150</bdi></a>  currently, to define the pin to which sensor is connected, you need to edit the <code>node_helper.js</code> file ind MMM-Temperature-Humidity directory and edit line number 12.<br />
<code>var dht = new rpiDhtSensor.DHT11(2);</code>    to     <code>var dht = new rpiDhtSensor.DHT11(21);</code></p>
<p dir="auto">you can leave the config as</p>
<pre><code>            {
			module: 'MMM-Temperature-Humidity',
			position: 'bottom_right',
				refreshInterval: 10000,
				temperaturePrefix: "Room temperature: ",
				temperatureSuffix: "°C",
				humidityPrefix: "Humidity: ",
				humiditySuffix: "%"
<p dir="auto">guess this needs to be improved in future release… :D</p>
<hr />
<p dir="auto"><strong>Note from admin:</strong> Please use <a href="https://github.com/adam-p/markdown-here/wiki/Markdown-Cheatsheet#code" target="_blank" rel="noopener noreferrer nofollow ugc">Markdown</a> on code snippets for easier reading!</p>
]]></description><link>https://forum.magicmirror.builders/post/5707</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/5707</guid><dc:creator><![CDATA[psk]]></dc:creator><pubDate>Mon, 03 Oct 2016 12:26:56 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Temperature&#x2F;Humidity Module (DHT11, DHT22 and AM2302 sensors.) on Sun, 02 Oct 2016 20:12:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/yawns" aria-label="Profile: yawns">@<bdi>yawns</bdi></a> Tanks for the help</p>
<p dir="auto">maybe i’m wrong in code. with me show a white screen</p>
]]></description><link>https://forum.magicmirror.builders/post/5706</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/5706</guid><dc:creator><![CDATA[H3L1o150]]></dc:creator><pubDate>Sun, 02 Oct 2016 20:12:52 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Temperature&#x2F;Humidity Module (DHT11, DHT22 and AM2302 sensors.) on Sun, 02 Oct 2016 19:50:42 GMT]]></title><description><![CDATA[<p dir="auto">I never played around with this module. But I would use this:</p>
<p dir="auto"><code>{  module: 'MMM-Temperature-Humidity',  position: 'top_right' }</code></p>
<p dir="auto">And then you edit node_helper.js to set for DHT11 or DHT22 and the correct pin in ( )</p>
]]></description><link>https://forum.magicmirror.builders/post/5704</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/5704</guid><dc:creator><![CDATA[yawns]]></dc:creator><pubDate>Sun, 02 Oct 2016 19:50:42 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Temperature&#x2F;Humidity Module (DHT11, DHT22 and AM2302 sensors.) on Mon, 03 Oct 2016 12:26:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/yawns" aria-label="Profile: yawns">@<bdi>yawns</bdi></a> so i left the config.js file like that?</p>
<pre><code>  {
          position: 'top_right',
<hr />
]]></description><link>https://forum.magicmirror.builders/post/5703</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/5703</guid><dc:creator><![CDATA[H3L1o150]]></dc:creator><pubDate>Mon, 03 Oct 2016 12:26:28 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Temperature&#x2F;Humidity Module (DHT11, DHT22 and AM2302 sensors.) on Sun, 02 Oct 2016 19:40:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/h3l1o150" aria-label="Profile: H3L1o150">@<bdi>H3L1o150</bdi></a><br />
No, you need to edit the file node_helper.js in the modules folder<br />
Currently you cannot define the pin and the sensor type in the config section. But I think this should be improved in a future release</p>
]]></description><link>https://forum.magicmirror.builders/post/5702</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/5702</guid><dc:creator><![CDATA[yawns]]></dc:creator><pubDate>Sun, 02 Oct 2016 19:40:12 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Temperature&#x2F;Humidity Module (DHT11, DHT22 and AM2302 sensors.) on Sun, 02 Oct 2016 19:33:53 GMT]]></title><description><![CDATA[<p dir="auto">Hi, i am really new on this, someone can help me, with the code on config.js file?</p>
<pre><code>     {
                position: 'bottom_bar',
<p dir="auto">thanks</p>
]]></description><link>https://forum.magicmirror.builders/post/5701</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/5701</guid><dc:creator><![CDATA[H3L1o150]]></dc:creator><pubDate>Sun, 02 Oct 2016 19:33:53 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Temperature&#x2F;Humidity Module (DHT11, DHT22 and AM2302 sensors.) on Fri, 30 Sep 2016 17:39:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jsyzthz" aria-label="Profile: jsyzthz">@<bdi>jsyzthz</bdi></a> Glad I could help :D :D</p>
]]></description><link>https://forum.magicmirror.builders/post/5584</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/5584</guid><dc:creator><![CDATA[psk]]></dc:creator><pubDate>Fri, 30 Sep 2016 17:39:54 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Temperature&#x2F;Humidity Module (DHT11, DHT22 and AM2302 sensors.) on Fri, 30 Sep 2016 09:32:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/psk" aria-label="Profile: psk">@<bdi>psk</bdi></a>  i use the first command. it woks now.thx!</p>
]]></description><link>https://forum.magicmirror.builders/post/5573</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/5573</guid><dc:creator><![CDATA[jsyzthz]]></dc:creator><pubDate>Fri, 30 Sep 2016 09:32:37 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Temperature&#x2F;Humidity Module (DHT11, DHT22 and AM2302 sensors.) on Mon, 03 Oct 2016 12:26:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jsyzthz" aria-label="Profile: jsyzthz">@<bdi>jsyzthz</bdi></a><br />
I’m not sure whether to rebuild in MMM-Temperature-humidity directory or the Magic Mirror directory.<br />
Try executing in the MagicMirror directory first.</p>
<p dir="auto"><code>npm rebuild --runtime=electron --target=1.4.0 --disturl=https://atom.io/download/atom-shell --build-from-source</code></p>
<p dir="auto">Also you can find the electron version by : npm list</p>
<p dir="auto">Just in case, i had this in my commands history :D<br />
<code>npm rebuild --runtime=electron --target=1.3.4 --disturl=https://atom.io/download/atom-shell --abi=49 -d</code></p>
]]></description><link>https://forum.magicmirror.builders/post/5523</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/5523</guid><dc:creator><![CDATA[psk]]></dc:creator><pubDate>Mon, 03 Oct 2016 12:26:03 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Temperature&#x2F;Humidity Module (DHT11, DHT22 and AM2302 sensors.) on Mon, 03 Oct 2016 12:25:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jsyzthz" aria-label="Profile: jsyzthz">@<bdi>jsyzthz</bdi></a>  I ran into the same while setting up!</p>
<p dir="auto">try this. Go to MMM-Temperature-Humidity,</p>
<p dir="auto">My Electron version is 1.4.0. If yours is different, replace accordingly. :D</p>
<p dir="auto">This is a <a href="https://github.com/EmergingTechnologyAdvisors/node-serialport/issues/904" target="_blank" rel="noopener noreferrer nofollow ugc">known issue</a> which is caused by the serialport module using native code that is built for a different version of Node. You can read a bit more about addons <a href="https://nodejs.org/api/addons.html" target="_blank" rel="noopener noreferrer nofollow ugc">here</a>, if you’re interested; they’re just modules written in C/C++ that can interface with Node so the module can interface with the hardware more easily.</p>
<p dir="auto">Credits : <a href="http://stackoverflow.com" target="_blank" rel="noopener noreferrer nofollow ugc">stackoverflow.com</a></p>
<hr />
]]></description><link>https://forum.magicmirror.builders/post/5520</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/5520</guid><dc:creator><![CDATA[psk]]></dc:creator><pubDate>Mon, 03 Oct 2016 12:25:47 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Temperature&#x2F;Humidity Module (DHT11, DHT22 and AM2302 sensors.) on Thu, 29 Sep 2016 13:47:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/psk" aria-label="Profile: psk">@<bdi>psk</bdi></a>  i’m following your steps.but got some errors<br />
<img src="/uploads/files/1475156460397-upload-b782b89f-2067-4c7d-92ed-d69124b72d1c.png" alt="0_1475156462089_upload-b782b89f-2067-4c7d-92ed-d69124b72d1c" class=" img-fluid img-markdown" /><br />
can you help me to take a look? thanks!</p>
]]></description><link>https://forum.magicmirror.builders/post/5517</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/5517</guid><dc:creator><![CDATA[jsyzthz]]></dc:creator><pubDate>Thu, 29 Sep 2016 13:47:44 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Temperature&#x2F;Humidity Module (DHT11, DHT22 and AM2302 sensors.) on Mon, 03 Oct 2016 12:25:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bangee" aria-label="Profile: Bangee">@<bdi>Bangee</bdi></a>  According to <a href="http://www.airspayce.com/mikem/bcm2835/" target="_blank" rel="noopener noreferrer nofollow ugc">bcm2835  v1.50-</a></p>
<p dir="auto">"<strong>Running as root</strong><br />
Prior to the release of Raspbian Jessie in Feb 2016, access to any peripheral device via <code>/dev/mem</code> on the RPi required the process to run as root. Raspbian Jessie permits non-root users to access the GPIO peripheral (only) via <code>/dev/gpiomem</code>, and this library supports that limited mode of operation.</p>
<p dir="auto">If the library runs with effective UID of 0 (ie root), then <code>bcm2835_init()</code> will attempt to open <code>/dev/mem</code>, and, if successful, it will permit use of all peripherals and library functions.</p>
<p dir="auto">If the library runs with any other effective UID (ie not root), then <code>bcm2835_init()</code> will attempt to open <code>/dev/gpiomem</code>, and, if successful, will only permit GPIO operations. In particular, <code>bcm2835_spi_begin()</code> and <code>bcm2835_i2c_begin()</code> will return false and all other non-gpio operations may fail silently or crash."</p>
<p dir="auto">So i guess we have run with sudo until some other library comes up :D</p>
<p dir="auto">PS: I should!! Its too hot in here… :D :D</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cowboysdude" aria-label="Profile: cowboysdude">@<bdi>cowboysdude</bdi></a>  Thanks! Cheers :D</p>
]]></description><link>https://forum.magicmirror.builders/post/5510</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/5510</guid><dc:creator><![CDATA[psk]]></dc:creator><pubDate>Mon, 03 Oct 2016 12:25:33 GMT</pubDate></item></channel></rss>
